Vehicle firmware v2.6.5 has been pushed to github. It is tagged (as v2.6.5) and we have uploaded pre-built .hex files in the vehicle/firmware directory.
2014-03-10 2.6.5       Firmware 2.6.5
                       # Change car_tmotor to signed int
                       # Call vehicle_fn_poll0() in OVMS_POLLER, if no poll list defined
                       # Twizy release 3.2.0
                       #   EEPROM CFG profile storage (3 custom profiles)
                       #   CFG profile management commands: LOAD, SAVE, INFO
                       #   CFG profile selection & display via simpl
                       # Tesla Roadster: Treat TBattery as signed
                       # ACC: Add a RADIUS parameter, supporting geo-fencing per acc locations
                       # ACC: Route MSG commands through to ACC (for special handling)
                       # ACC: Support charge, stop, and cooldown overrides
2014-01-19 2.6.2       Firmware 2.6.2
                       # Remove duplicate car_stale_* decrements in individual vehicle modules
                       # Updates to vehicle_thinkcity
                       # Mitsubishi: tbergo changes 1.5 ... 1.8
                       # Move can bus low level register access to vehicle.c,
                       #   (out of individual vehicle modules)
                       # OBDII: Implementation using new vehicle polling framework
                       # Structural changes to support new vehicle polling framework
                       # Changes to crypt_md5 library to save 62 bytes of initialised ram
                       # GSM clock polling, Request, and sync, GSM time
                       # Fix to doors2 bits
                       # Some work on nissan leaf
                       # Fixed QC detection and 12V alarm issue
                       # Twizy V3.0.2: CFG TSMAP allows 0..100 for levels 2..4
                       # Twizy version 3.1.0:
                       #   TSMAP: levels 1..4 now allow 0%
                       #   Power map generator extended for pwr max lo/hi, added sanity check
                       #   Renamed command "POWER" to "DRIVE", "TORQUE" to "POWER",
                       #   Changed param handling
                       # Twizy 3.1.1:
                       #   SDO segmented upload support (readsdo_buf)
                       #   new command: CFG READS (read string), CFG WRITEO (write only)
                       #   Error counter hardening (counter reset by CFG command)
                       # Twizy V3.1.2:
                       #   access to SEVCON logs / monitoring
                       #   new command: MSG 209 = CMD_ResetLogs
                       #   new command: MSG 210 = CMD_QueryLogs
                       #   active faults log included with fault alert
                       #   added Twizy client scripts
                       # Switch to extended mode compilation
                       # car_ambient_temp, car_tpem, car_tmotor and car_tpms_t to signed int
como lo bajo
