Firmware version 3.2.015 has been released to all users. This includes the following main changes:
2020-09-02 MWJ 3.2.015 OTA release
- Notify: add explicit channel exclusion config syntax
config set notify <subtype> <…>
<…> options are now:
a) explicit inclusion: e.g. 'ovmsv2,ovmsv3' (only enable these)
b) explicit exclusion: e.g. '*,-ovmsv2,-ovmsv3' (only disable these)
'-' to disable all, empty/'*' to enable all
- Renault Twizy: add eDriver/Virtual BMS data to RT-BAT-C & RT-BAT-P logs
- Nissan Leaf: fixes for issues related to using EV CAN bus (was CAR CAN prior to 3.2.014)
- Wifi client: support static IP configuration, manually set or automatically applied by SSID
New commands:
wifi ip static [<ip> <subnet> <gateway>]
wifi ip dhcp
New configs:
wifi.ssid "<ssid>.ovms.staticip" "<ip>,<subnet>,<gateway>"
Thank you to all the developers involved in this.
Useless
