11 posts / 0 new
markwj
markwj's picture
General suggestions for adding support for a new vehicle to OVMS
Before we start, I would like to say thank you. Your time is valuable and your contributions are appreciated. OVMS is an open source community project, and we rely on our developers to take this project forward. New vehicle support comes from the owners of those vehicles developing that support, along with the help of other experienced developers working on other vehicles or framework components. We work together to extend the project.
1. The first step is to sign up for the developer's mailing list, and let people here know that you are working on a particular car. Perhaps other owners are also interested and can help.
2. Next is physical hardware reconnaissance. You need to find out what sort of communications buses your car has, what vehicle modules (ECUs) are connected, what speed the buses run at, where the diagnostic connectors are, and what each pin does. The OBDII connector is pretty standard in modern cars, but is often not the only connector. It is often common to see many different types of communication buses such as CAN, LIN, K-Line, and others. Of particular interest is any communication buses connecting the car to its user visible displays or telematics modules. Google is your friend here. You can also look for service manuals, or talk to your friendly mechanic. The absolute last resort is to get out a multimeter, trace cables and measure signals. For OVMS, you are in particular looking for CAN bus networks.
3. The next step is to look for documented signals on those communications buses. Network traffic is commonly either polled (the diagnostic tool sends a request for a particular piece of information, and the vehicle module replies with the current value), or active (the information is broadcast repeatedly, usually at a set interval). Most cars use a combination of both. Sometimes these are published as online resources on enthusiast websites, and other times the manufacturer or diagnostic tool supplier has the information. There are standardised formats for this (such as DBC for active networks, and PIDs for polled).
4. You then need to look for existing diagnostic screens and information. As well as the general user interface of the car (temperature displays, speedometer, etc), there may also be maintenance screens and lower level diagnostics. These are incredibly useful for the work you will be doing.
5. OK, now it is time to step away from the Internet and go to the actual car. You are going to want to record the traffic on the car communication buses, while doing different activities (such as charging the car, parked idle, driving, reversing, turning, etc). We call these "CAN bus dumps". Write down notes next to each dump, describing what you were doing, where, when, and what the key metrics shown in the car were (state of charge, odometer, speed, type of charge, charge rate, etc). The tools I use for this are OVMS (with an appropriate cable to connect it to the car networks) and SavvyCAN (a cross platform application you can run on a laptop) - you can connect the two over WiFi. It is a good idea to have the car reachable by wifi, which allows you to do a lot of work from inside your house (rather than in the driver's seat with the laptop propped up on the steering wheel).
6. Now is the time to look for specific metrics. You can find the full list in the OVMS documentation, but we suggest you start with basic things like car on/off state, gear selection, speed, State of Charge (SOC), range displays, etc. I always go for SOC as my first target, as it gives instant gratification. At this stage, you will be looking for a particular metric, and you are going to be comparing what signals are on the car's communication buses against what is displayed on the car's diagnostic display. This may not be a 1-to-1 relationship. For example, the odometer may display to the nearest kilometre, but the metric on the car communication bus may be in 1/10ths of a mile. Other metrics are in floating point, or different byte orders. Often the change in a metric is the biggest clue - a SOC would increase during a charge and decrease during a drive, for example. SavvyCAN can help with this. When a door opens, you would expect the appropriate signal on the CAN bus to change appropriately.
7. Once you've found a few metrics, it is time to add support. You will need some programming knowledge here, and be very familiar with computers. We use the C++ language, which is like C on steroids - vehicle modules are not complex and there are plenty of example vehicles to learn from. Setup your build environment (the developer's guide has the detail for this), clone the OVMS firmware to your own GitHub account, and try to build the standard firmware and flash it to your module. Then, add a stub for your vehicle. Just a piece of code that allows you to select the vehicle but does nothing (you will create components/vehicle_ and modify main/Kconfig to add it as an optional vehicle). Modify your vehicle module to initialise the appropriate CAN bus support, and decode the metrics you know. Flash it to your module, then fire up the App and get the instant gratification of being able to see your battery level (for example). You won't have every metric supported at this time - just get a few working and you'll be encouraged to find more.
8. Now it is time to contribute. Add, commit, and publish your changes to your own GitHub repository, then use the GitHub tools to send in a pull request (for us to merge your code back). Please don't forget to add some documentation, so others can share in what you have achieved.
9. From that point on, it is an iterative journey. Discovering and adding more metrics, and then starting to look for things like door lock/unlock functionality, etc. I find this a fascinating journey - the process of discovery is to me even more rewarding than the final vehicle support.
Again, thank you for your contributions, and happy hacking!
Mark.
elbow
how to subscribe to the developers list?
hi,
The guide says first step to subscribe to the developer list.  How do you actually do this?
I subscribed through the mailman interface but never heard back.  I sent an email to ovmsdev-owner@lists.openvehicles.com and didn't receive a reply.
Thanks
elbow
Fixed
Turns out there was a problem with the mailman stuff which Mark fixed and I was able to get subscribed,
dernotte
Hi markwj,
Hi markwj,
Even if what you describe here makes plenty of sense, I think it would be great if it could be a little more OVMS related. I would like to see a list of command to run in the shell window to start investigation, and the logical progression. ie For identifying the list of ECU, you must run the following command. Once you have the ECU ID, run this command to identify PID. In order to discover all PID for a given ECU, must must run this command, etc....
Shane
Coding help
can any one help me with a bit of code to retrieve ve some data from ecu can1/6f2  00 4c 00 00 01 97 bc 00 as i cant poll this ecu it just broadcasts when its active, ive tried polling it but does not respond, i need to choose one byte and allocate it to a PID. i have no poblem coding for the polling but need some help how to write the code for broacast data!
markwj
markwj's picture
Best to ask on the developers
Best to ask on the developers mailing list.
Vasco65
MG 5 support?
I've just joined the group, hoping to find information about support for the MG5, but I can't find any.  Does anyone know if this car will be supported by OVMS?  Lots are being sold in the UK, I'm sure many owners will be interested.
Proooosit
Maxus Euniq Mpv someone know anything??
I Soon buy a Maxus Euniq Mpv that var have all i wish almost, but No app support i wish to turn on heat and ac and wish to se % of Charge it be thery nice if that is possible with Ovms.
Roald Nakstad
Support for OBD-II / EOBD Electric (Stellantis/PSA based)
Hi
I own a Peugeot e-2008,  2020 model year. Car works fine, but the myPeugeot app sucks. It,s slow/unresponcive an lack a lot of functions. And worst of all, it only support mobile 2G and 3G, so in a year when 2G is switched off, here in Norway it totally stop working.
So I hope anywone is working to get these cars impementedt in OVMS. I have already two OVMS running in a Smart EV 2013 and a Leaf 2013 and are werry satisfied on those two.
I bougt a Bluetooth OBDII device for use with powercruisecontrol.com, and with that donge I can also use the free verson of Car Scanner on my iPhone to read out a lot of data,  live cell voltages soc, soh, delta voltage ++++  So I know that a lot of information is available.
And when chosing profile in Car Scanner, the same profile is for many makes/models, so I believe by make It work in OVMS would open up for a lot of new customers:
Peugeot 208 (e-208), Peugeot e2008 (e-2008), e-Expert/e-Traveller, Opel CORSAE (Corsa-e, e-Corsa), Opel MOKKA (Mokka-e, e-Mokka), Zafira-e Life/Vivaro-e, Astra-E, Citroën eC4 (ё-C4, C4), DS3 Crossback e-TENSE, ë-Jumpy/e-Spacetourer, Vauxhall Vivaro-e, Toyota Proace Electric, Jeep Avenger EV, Fiat 600e, Alfa Romeo Junior EV, Lancia Ypsilon EV
I'm not a developer, but could help with data capturing and testing.
jtq4u
Another +1 for the e-208 e
Another +1 for the e-208 e-2008.
I am a techie but have never contributed to this forum before, happy to help if led by someone longer in the tooth!
Phoca
+1 for the e-2008.
+1 for the e-2008.
