3 posts / 0 new
martinwinlow
CAN Bus Pass-Through Cable - Run OVMS & caniOn Simultaneously
I guess the title says it all…
Is this possible? Could it be done by just paralleling the 4 conductors from one device to the other?
MW
Saftwerk
CAN parallel? YES!
I'm working on a conplete different project and YES all 4 wires parallel should work:
12V Power, 0V GND, CanHI, CanLO
Some devices have a 120 ohm termination resistor between CanHI and CanLO : Your extra device should NOT have this resistor.
You can't damage anything if there is a 120 ohm too much on the wires.
Ihe only thing that can happen: The car communication hangs up.
If the car does not work as normal, then remove your device. (maybe a CAR-Reset could be needed)
Greetings
Saftwerk
(Tesla Roadster)
martinwinlow
Thanks. MW
Thanks. MW
