4 posts / 0 new
1979-mini
Shell Command for Resetting Wifi Status
I was trying to get the OTA update to work over wifi, and I switched the wifi status from Access Point and Client Mode, to just Client Mode. Now I cannot access the OVMS using wifi.
Is there a Shell Command I can send using the Android App to set the wifi status back to Access Point and Client Mode, without having to do a factory reset?
Also, is there a Shell Command that does a factory reset?
1979-mini
SOLUTION: Enter "wifi mode
SOLUTION: Enter "wifi mode apclient <name of the wifi network on OVMS>" in the messages tab on the Android App
grnbrg
If you know the IP address
If you know the IP address assigned by your router, you can connect to it in client mode, as well.
(ie: On my home network, I have been using http://10.2.1.2/)
1979-mini
Thanks. I never thought of
Thanks. I never thought of that idea.....
