3 posts / 0 new
mmaradni
Hyundai Kona
Dears,
is OVMS support Hyundai Kona EV, and can i remote start the car with it..?
other question, can i replace the sim without break the warranty.?
glynhudson
Yes, the Kona is supported.
Yes, the Kona is supported. But you need to select the e-Nito vehicle. Both vehicles share the same platform. You can't remotely start the car, see the table at the bottom of this page for what functions are supported on the e-niro / Kona: https://shop.openenergymonitor.com/open-vehicle-monitoring-ovms-wifi-3g-...
You can use whatever SIM you want, you will need to set the APN settings.
juanheredia
Check this out https://www
Check this out https://www.openvehicles.com/node/2331
I'm testing with my Kona 39,2kWh
