I have the smart ED 451. It has a 18 KWh battery and charges very slowly with max 3,7 KW. The display of the battery In the OVMS app is not quite right.
- In the green to the left it says 8 KWh. I assume this is the used power from full. So it should be on the other side, as the green area with 70% represents around 13 KWh of power remaining. However, the numbers don’t add up.
- to recharge fully I will need over 1 hr. But the app only estimates 16 mins. How can I change that?
The problem was resolved in a private message in the German forum. There was a display error in the iOS app.
