5 posts / 0 new
rroca
OVMS v3 wrong estimated range
Message status from OVMS v3 with e-Niro, now gives wrong estimated range:
Not charging
SOC: 56.0%
Ideal range: 237km
Est. range: 10924km
ODO: 16772.0km
CAC: 89.6Ah
SOH: 100%
(Estimated range can't be high as 10,924 kms being at 56%...)
Also while getting this message, the car has charging, might be related to
https://www.openvehicles.com/node/2331 ?
However by going to the website ( https://dexters-web.de ) there says that is charging (but still, extremly high estimated range)
timopen
Estimate range
The range is calculated from the 20 last trips. I think it will be better over time. Otherwise post here again.
Regards
Timo
rroca
it's random
Hi Timo,
We'll I've done those 20 trips after the EDGE upgrade (Oct-14).
Today was giving an estimation even crazy/higher (181622 kms!):
OVMS# stat
Not charging
SOC: 90.5%
Ideal range: 362km
Est. range: 181622km
ODO: 16949.0km
CAC: 144.8Ah
SOH: 100%
So after your comment, make me think, and I've tried one simple thing that I didn't: Reboot.
After the reboot I'm getting a quite more reasonable estimation:
OVMS# stat
Not charging
SOC: 90.5%
Ideal range: 370km
Est. range: 412km
CAC: 144.8Ah
SOH: 100%
I'll follow on the coming days to see how evolves... but really looks like this reboot in between those two readings helped ;)
Thanks!
timopen
Estimate range
Sound like a variable that was not initialized. I will check if I can find something in the code.
Regards
Timo
rroca
yes, looks like....
A week after, wrong estimation again, I've this.
Not charging
SOC: 81.5%
Ideal range: 319km
Est. range: 2975km
ODO: 17589.0km
CAC: 130.4Ah
SOH: 100%
After the rebooting the device:
Not charging
SOC: 81.5%
Ideal range: 319km
Est. range: 371km
ODO: 17591.0km
CAC: 130.4Ah
SOH: 100%
Same firmware:
Firmware: 3.2.005-64-geb3785f8/ota_1/eap (build idf v3.3-beta3-774-g6652269e1 Oct 14 2019 16:53:26)
