5 posts / 0 new
Al Vinci
Notification mayham
Hi all!
I have some issues with my OVMS. I get notifications (that charging has stopped) while driving. Last night I got like 20 notifications on a 30 minutes drive. They all tells me the charging has stopped and after my last drive I figured it could have something to do with the cars regeneration when slowing down/breaking. It felt like I got a notification every time I stopped at a red light or at a 3 way intersection. I have asked in a local e-niro group on FB and I got one response telling me he had the same problem and his solution was to turn notifications off. That would be a temporary solution for me as I really need a notification if the charging actually stops.
I contacted the support and they told me to ask my question here. Any ideas?
Your notification records look like this:
2020-02-27 17:38:41.101327 +0800 msg push notification 'A12V Battery critical:
2020-02-27 22:39:53.161596 +0800 msg push notification 'IStandard - Charging^M232.0V/12.8A^MFull:
2020-02-28 09:43:47.440057 +0800 msg push notification 'AStandard - Charge
2020-02-28 10:23:19.127991 +0800 msg push notification 'INot charging^MSOC: 60.0%^MIdeal
2020-02-28 10:23:22.149041 +0800 msg push notification 'ANot charging^MSOC: 60.0%^MIdeal
2020-02-28 10:27:10.527828 +0800 msg push notification 'INot charging^MSOC: 59.0%^MIdeal
2020-02-28 10:27:33.580519 +0800 msg push notification 'ANot charging^MSOC: 59.0%^MIdeal
2020-02-28 10:37:48.941662 +0800 msg push notification 'INot charging^MSOC: 55.0%^MIdeal
2020-02-28 10:38:14.779824 +0800 msg push notification 'ANot charging^MSOC: 55.0%^MIdeal
2020-02-28 11:00:20.539369 +0800 msg push notification 'INot charging^MSOC: 45.5%^MIdeal
2020-02-28 11:01:12.849864 +0800 msg push notification 'ANot charging^MSOC: 45.5%^MIdeal
2020-02-28 11:06:08.680470 +0800 msg push notification 'INot charging^MSOC: 44.0%^MIdeal
2020-02-28 11:06:27.519346 +0800 msg push notification 'ANot charging^MSOC: 43.5%^MIdeal
2020-02-28 11:11:12.307131 +0800 msg push notification 'A12V Battery critical:
2020-02-28 16:02:12.426140 +0800 msg push notification 'A12V Battery restored:
2020-02-28 16:05:52.821440 +0800 msg push notification 'INot charging^MSOC: 43.0%^MIdeal
2020-02-28 16:05:54.140497 +0800 msg push notification 'ANot charging^MSOC: 43.0%^MIdeal
2020-02-28 16:12:57.824069 +0800 msg push notification 'INot charging^MSOC: 41.5%^MIdeal
2020-02-28 16:13:23.789355 +0800 msg push notification 'ANot charging^MSOC: 41.0%^MIdeal
2020-02-28 16:31:47.990304 +0800 msg push notification 'IPerformance - Charging^M364.8V/109.2A^MFull:
2020-02-28 17:00:26.829669 +0800 msg push notification 'ANot charging^MSOC: 62.0%^MIdeal
2020-02-28 17:02:03.696511 +0800 msg push notification 'INot charging^MSOC: 62.0%^MIdeal
2020-02-28 17:02:06.410717 +0800 msg push notification 'ANot charging^MSOC: 62.0%^MIdeal
2020-02-28 17:12:00.614029 +0800 msg push notification 'INot charging^MSOC: 59.0%^MIdeal
2020-02-28 17:12:27.651722 +0800 msg push notification 'ANot charging^MSOC: 59.0%^MIdeal
2020-02-28 17:19:52.740737 +0800 msg push notification 'INot charging^MSOC: 56.0%^MIdeal
2020-02-28 17:20:03.761655 +0800 msg push notification 'ANot charging^MSOC: 56.0%^MIdeal
2020-02-28 17:22:01.915040 +0800 msg push notification 'INot charging^MSOC: 56.0%^MIdeal
2020-02-28 17:22:10.639736 +0800 msg push notification 'INot charging^MSOC: 56.0%^MIdeal
2020-02-28 17:22:39.414298 +0800 msg push notification 'ANot charging^MSOC: 55.5%^MIdeal
2020-02-28 17:31:38.758601 +0800 msg push notification 'INot charging^MSOC: 51.5%^MIdeal
2020-02-28 17:32:04.042777 +0800 msg push notification 'ANot charging^MSOC: 52.0%^MIdeal
2020-02-28 17:36:34.757694 +0800 msg push notification 'INot charging^MSOC: 50.0%^MIdeal
2020-02-28 17:37:01.815057 +0800 msg push notification 'ANot charging^MSOC: 50.0%^MIdeal
2020-02-28 18:11:02.875154 +0800 msg push notification 'INot charging^MSOC: 31.5%^MIdeal
2020-02-28 18:11:41.763433 +0800 msg push notification 'ANot charging^MSOC: 31.5%^MIdeal
2020-02-28 18:15:12.608752 +0800 msg push notification 'A12V Battery critical:
2020-02-28 18:16:12.615175 +0800 msg push notification 'A12V Battery restored:
2020-02-28 18:16:50.814213 +0800 msg push notification 'IStandard - Charging^M231.0V/12.8A^MFull:
2020-02-28 20:29:43.757208 +0800 msg push notification 'AStandard - Charge
2020-02-28 20:42:12.753391 +0800 msg push notification 'A12V Battery critical:
2020-02-28 20:45:12.775801 +0800 msg push notification 'A12V Battery restored:
2020-02-28 20:45:32.905939 +0800 msg push notification 'INot charging^MSOC: 39.0%^MIdeal
2020-02-28 20:46:05.865398 +0800 msg push notification 'ANot charging^MSOC: 39.0%^MIdeal
2020-02-28 20:49:48.371058 +0800 msg push notification 'INot charging^MSOC: 38.0%^MIdeal
2020-02-28 20:50:35.373935 +0800 msg push notification 'ANot charging^MSOC: 38.0%^MIdeal
2020-02-28 20:50:59.830207 +0800 msg push notification 'INot charging^MSOC: 38.0%^MIdeal
Module summary below:
ovms> module summary
Vehicle Response:
OVMS MODULE SUMMARY
Module
Version: 3.2.008-101-ga8361db5/ota_0/main (build idf v3.3-beta3-774-g6652269e1 Dec 14 2019 12:02:50)
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
12v: 12.8v
SIMCOM Modem Status
Network Registration: RegisteredHome
Provider: halebop
Signal: -89 dBm
State: NetMode
Ticker: 62873
User Data: 0
HW FIFO overflows: 0
Buffer overflows: 0
Mux
Status: up
Open Channels: 4
Framing Errors: 0
Last RX frame: 0 sec(s) ago
RX frames: 298676
TX frames: 6381
PPP: Connected on channel: #2
GPS: Connected on channel: #1
Status: enabled
Time: enabled
Configuration
[auto]
modem: yes
server.v2: yes
vehicle.type: KN
wifi.mode: apclient
wifi.ssid.ap: JKP78P
wifi.ssid.client: Tidsmaskinen
[can]
[dbc]
[egpio]
[http.plugin]
[http.server]
[locations]
[log]
[modem]
apn: halebop.telia.com
apn.password:
apn.user:
enable.gps: yes
enable.gpstime: yes
enable.net: yes
enable.sms: yes
pincode:
[module]
cfgversion: 2018112200
init: done
[network]
dns:
[notify]
[obd2ecu]
[obd2ecu.map]
[ota]
server: ovms.dexters-web.de/firmware/ota
[password]
module: **redacted**
[power]
[pushover]
[sdcard]
[server.v2]
password: **redacted**
port: **redacted**
server: **redacted**
updatetime.connected: **redacted**
updatetime.idle: **redacted**
[server.v3]
[ssh.info]
fingerprint: AKDV1mhMYRrAoDvXWmfrFa5ZpFP7vwCvPMJouRE/xo8
[ssh.keys]
[ssh.server]
key: **redacted**
[system.adc]
factor12v: 195.7
[vehicle]
12v.alert:
12v.ref:
bms.alerts.enabled: no
timezone: CET-1CEST;M3.5.0;M10.5.0/3
timezone_region: Europe/Stockholm
units.distance: K
[wifi.ap]
JKP78P: **redacted**
[wifi.ssid]
Tidsmaskinen: **redacted**
[xkn]
REPORT ENDS
timopen
Hi Al
Hi Al
I never had this.
Looks like OVMS is stuck in charge state.
I will try to investigate.
Kiaeniro
I have the same problem, I
I have the same problem, I get notifications when I drive about every two minutes.
dar63
Hi,
Hi,
hopefully, I don't have this issue. My firmware version is : 3.2.008-155-g120f0284 downloaded from dexter-web.
Can you try ?
/David
timopen
Fixed
Hej Alvin and the rest of the gang
I have reproduced and fixed this issue.
It will be included in a future release.
For those of you that want to test it before it's released, here is a link to the binary:
https://drive.google.com/drive/folders/1ZayG3z_PDwvGcOwBqUIJbCaBSVU2gXY8?usp=sharing
Beware that I have some unreleased code to save tripdata to the sd-card, but you can disable this in the Features page on the webinterface or create a folder named Trip in the root of the sd-card.
/Timo
