2 posts / 0 new
MattyP
Using App on IOS
Hi guys
I m new here, I've had a look through the discussions but can’t find an answer. I am using the App on my iPhone connecting to a device I’ve set up for my 2021 ENV200. All looks good except I can’t see any charge points on the map nor get the climate control to turn on/off.
Is this what is expected? I noticed there’s a yellow tick on the supported vehicle list, but uncertain if this means something needs to happen in the settings or vehicle for this feature to work?
Any help or tips appreciated
Matt
markwj
markwj's picture
The two apps (iOS and Android
The two apps (iOS and Android) are maintained seperetely from two different code bases, and have different features.
If the function you want is not available in the UI, then most likely you need to do it via a command in the Messages tab.
