12 posts / 0 new
dar63
Send live data to abrp
You probably know abetterrouteplanner.com
It is probably the best tool to plan a route, and to optimize where to charge.
It has a live function, which allows to adjust with the real consumption of the vehicle, by connecting an obd device and soft like EVNotify or Torque Pro.
Why not having this function with OVMS?
On abrp forum, it is explained how to send data:
https://forum.abetterrouteplanner.com/topic/97-submitting-live-data-thro...
What do you think?
Tobahc
Sounds like a great idea,
Sounds like a great idea, although I’m not the one who can contribute in programming, unfortunately.
When this works, does it mean I would get updated ABRP-data on my phone through the ABRP servers, or through direct communication between my phone and the OVMS plug?
dar63
It means once it will work,
It means once it will work, you can launch abrp on your phone, and follow your route and consumption and next stop to charge in this website- app like.
Tobahc
That is the functional answer
That is the functional answer. I was looking for the technical answer: what is the data flow, from where to where? Does the OVMS plug communicate with the ABRP server(s) or with the phone or tablet where ABRP is running?
dar63
Yes you're right.
Yes you're right.
Technically, OVMS box will send data directly to abrp server-side through 3g/4g link. No direct info from OVMS to the phone running client-side, as it is not an existing functionality I am aware of.
dar63
abrp live data using scripting ?
Maybe we could use scripting to do it?
We could use part of this java code: https://github.com/g4rb4g3/ABRPTransmitter/blob/master/app/src/main/java...
dar63
I finally found a way
Using the web plugin of OVMS web server, I am able in JavaScript to get vehicle data and send it to abrp.
I will test it tomorrow with a real travel to see how it works.
Unfortunately, it is not through the OVMS embedded script functionality.
dexter
dexter's picture
HTTP API
I just pushed the first implementation of a HTTP API:
https://docs.openvehicles.com/en/latest/userguide/scripting.html#http
Included in edge build version 3.2.008-147-g73ae2d19 on my server (dexters-web.de), will be in edge on openvehicles.com within 24 hours.
Testing & feedback is welcome.
dar63
something new to test
wonderfull :-) something new to test now.
I'll keep you informed, thank you
Ningaloo
Reference error
Hello dar63, thank you for your great work. I installed the script as descripted. Only i get the error indentifier 'abrp' undefined. Any idea how to resolve this?
Dimitrie
Hi, when your follow the
Hi, when your follow the instruction in the doc. https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/tree/ma...
And copy past the
add to /store/scripts/ovmsmain.js:
abrp = require("sendlivedata2arbp");
there is a typo, it should be:
abrp = require("sendlivedata2abrp");
Ningaloo
Typo
Yes, i deed find the typo too. When i fixed the typo. The error was gone. Thanks
