Hi
I have just setup and installed my OVMS and everything went fine.
But I do not get any GPS location data from the device on the server / app.
I have tryed to remove the antenna and putting it on again.
Is there somewhere I can se if the GPS is working or what the problem could be.
Thanks, Javaman (Kia E-Niro)
You can enable verbose logging on "gsm-nmea" to see the NMEA sentences in the log / shell.
If they look like this, the modem has no GPS signal:
Hi
Thanks for the quick reply, the GPS is active in the config, and I get this in the log:
I don't know how to check 2 and 3..
Which antenna do you use?
Hi, The one from (https://shop.openenergymonitor.com/ovms/)
That's the standard GPS antenna (active) and should work. You possibly have a hardware issue. The most typical source for this is the pigtail cable.
If you can't check the antenna and don't know how to check the voltage & pigtail cable, you'll need to send the kit back to OpenEnergyMonitor for a test / repairing / replacement.
Contact Glen for details.
No voltage from the gps
and the antenna cable is ok
You should see ~ 4V there. As your modem is working, the next thing to check would be the pigtail cable.
Open the module, trace the cable from the GPS socket to the modem PCB. Check if it's connected tightly on the PCB socket. Try disconnecting and reconnecting. Test if the cable is broken.
No problems with the cable from the print to the connector.
so the problem must be in the printboard.
I have created a support case with reference to this thread.
Can you help me how to get a new that works?
Best
Allan
As you bought the module from Glen, you should contact him first. Send him the link to your support case.
One comment on testing antenna connections, is that the following tests can be done with a mulitmeter:
Thanks for all the help, I have returned the OVMS Unit and GPS antenna. Hope to get a new soon :)
Regards, Allan
