2 posts / 0 new
Funkenkarl
Server V3 not working since Vers. 3.2.010-162-g4e063c45
Hello everybody!
I have a problem with Server V3.
The Server can`t connect.
I figured out that the problem isnt in the version 3.2.010-162-g4e063c45 or earlier. The Server connect immediately.
Every later version include the connect problem of the Server V3.(same settings)
Is there any way to fix it?
Please help
Thank you
markwj
markwj's picture
I'm using v3, latest firmware
I'm using v3, latest firmware, to v3 server (MQTT) without issue.
What is the error message you get from the module? Do you have TLS enabled, and if so do you have the trusted certificate authority in the OVMS module?
