Hi all!
can you explain what is the meaning of these settings, I mean when they trigger ?
Connected, idle, on, charging, awake, sendall
I clearly understand the "on" and "charging" settings but the other ones are a little bit confusing.
Thanks in advance
In order of descending priority:
"Sendall" defaults to disabled, if enabled (set > 0) it forces a full retransmission of all metrics in the given interval, regardless of the vehicle and client state.
Thank you so much!
