2 posts / 0 new
rtw819
OVMS v3.3 Client Mode lacking support for HIDDEN WiFi SSIDs ?
Apparently, the client mode of the WiFi adapter configuration does not support hidden (non-broadcasting) 2.4GHz Wifi SSID's.  I found an old listserv post from 2017 mentioning this topic once, but it doesn't seem there's ever been a fix for it?  This problem is true for the base version 3.3.001 code and even the latest 3.3.001-282 edge build the same issue exists.
Anyone have thoughts other than enabling SSID broadcast on wifi routers I may not have control over?
markwj
markwj's picture
Can you try to 'force' the
Can you try to 'force' the connection, using the MAC address of the wifi access point?
wifi mode client <ssid> <bssid>
