Hello,
I just received my OVMS and walked through the setup.
I am running firmware 3.3.003-264-g54094e50/ota_1/edge (build idf v3.3.4-849-g6e214dc33 Jan 28 2023 00:06:58)
Like another post in this forum, I can only see the 12v battery status. I do not get any SOC or Voltage data with the ignition on. If I attempt to run bmsdiag from the shell I get "No BMS status data available," and occasionally the terminal will scroll with:
E (98142) can: can2: intr=154279 rxpkt=154365 txpkt=0 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (98192) can: can2: intr=154299 rxpkt=154385 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (98532) can: can2: intr=154421 rxpkt=154561 txpkt=0 errflags=0x23001001 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (98572) can: can2: intr=154421 rxpkt=154562 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (98942) can: can2: intr=154509 rxpkt=154676 txpkt=0 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (98942) can: can2: intr=154509 rxpkt=154677 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (99502) can: can2: intr=154630 rxpkt=154835 txpkt=0 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (99502) can: can2: intr=154630 rxpkt=154836 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (99532) can: can2: intr=154644 rxpkt=154872 txpkt=0 errflags=0x23001001 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (99532) can: can2: intr=154644 rxpkt=154873 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
I appreciate any help that can be given.
E (1088432) can: can1: intr=43659 rxpkt=0 txpkt=0 errflags=0x804016 rxerr=128 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1088432) can: can1: intr=43675 rxpkt=0 txpkt=0 errflags=0x8040a2 rxerr=128 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
OVMS# obd can1 req dev 79B 7BB 2142
79b[7bb] 2142: ERROR: timeout waiting for poller/response
E (1088472) can: can1: intr=44167 rxpkt=0 txpkt=0 errflags=0x804016 rxerr=128 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
Hi, can you check if you have enable canwrite?
Hello,
canwrite was enabled, but I stepped through your suggestions and below is the output:
E (1707492) can: can2: intr=1487818 rxpkt=1486195 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1707492) can: can2: intr=1487819 rxpkt=1486196 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1707632) can: can2: intr=1487936 rxpkt=1486314 txpkt=0 errflags=0x80001080 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1714172) can: can2: intr=1493609 rxpkt=1491979 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1714172) can: can2: intr=1493610 rxpkt=1491980 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1715392) can: can2: intr=1494669 rxpkt=1493040 txpkt=0 errflags=0x80001080 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1715392) can: can2: intr=1494670 rxpkt=1493041 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1715872) can: can2: intr=1495080 rxpkt=1493453 txpkt=0 errflags=0x80001080 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1727592) can: can2: intr=1505251 rxpkt=1503609 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1727592) can: can2: intr=1505252 rxpkt=1503610 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1727792) can: can2: intr=1505426 rxpkt=1503786 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1727792) can: can2: intr=1505427 rxpkt=1503787 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1728272) can: can2: intr=1505835 rxpkt=1504198 txpkt=0 errflags=0x80001080 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
I (1729422) webserver: HTTP POST /api/execute
I (1729432) webcommand: HttpCommandStream[0x3f8ba8fc]: 3477652 bytes free, executing: config set xse canwrite yes
OVMS# config set xse canwrite yes
Parameter has been set.
E (1730792) can: can2: intr=1508023 rxpkt=1506383 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1730792) can: can2: intr=1508024 rxpkt=1506384 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1730992) can: can2: intr=1508191 rxpkt=1506554 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1730992) can: can2: intr=1508192 rxpkt=1506555 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1731412) can: can2: intr=1508546 rxpkt=1506911 txpkt=0 errflags=0x80001080 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1742192) uart_events: uart event type: 4
I (1745712) webserver: HTTP POST /api/execute
I (1745712) webcommand: HttpCommandStream[0x3f8ba8fc]: 3475428 bytes free, executing: config list xse
OVMS# config list xse
xse (readable writeable) canwrite: yes doorlock.port: 9 doorstatus.port: 6 doorunlock.port: 8 egpio_timout: 5 gpio_highlow: no ignition.port: 7 lockstate: no notify.trip: yes rangeideal: 135 reboot: soc_rsoc: no
E (1753272) can: can2: intr=1527536 rxpkt=1525864 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1753272) can: can2: intr=1527537 rxpkt=1525865 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1753612) can: can2: intr=1527834 rxpkt=1526164 txpkt=0 errflags=0x81001001 rxerr=1 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
E (1753612) can: can2: intr=1527835 rxpkt=1526165 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
then i need output of
and
OVMS# can can1 status
CAN: can1
Mode: Active
Speed: 500000
DBC: none
Interrupts: 33
Rx pkt: 0
Rx ovrflw: 0
Tx pkt: 0
Tx delays: 0
Tx ovrflw: 0
Tx fails: 0
Err flags: 0x00804ca2
Rx err: 128
Tx err: 0
Rx invalid: 0
Wdg Resets: 0
Wdg Timer: 5 sec(s)
Err Resets: 0
I (41458275) webserver: HTTP POST /api/execute
I (41458275) webcommand: HttpCommandStream[0x3f8b6a60]: 3473752 bytes free, executing: can can1 status
HttpCommandStream[0x3f8c3304]: 3474756 bytes free, executing: metrics list v.
OVMS# metrics list v.
v.b.12v.current v.b.12v.voltage 11.86V v.b.12v.voltage.alert v.b.12v.voltage.ref 12.6V v.b.c.temp v.b.c.temp.alert v.b.c.temp.dev.max v.b.c.temp.max v.b.c.temp.min v.b.c.voltage v.b.c.voltage.alert v.b.c.voltage.dev.max v.b.c.voltage.max v.b.c.voltage.min v.b.cac v.b.consumption 0mi/kWh v.b.coulomb.recd v.b.coulomb.recd.total v.b.coulomb.used v.b.coulomb.used.total v.b.current v.b.energy.recd v.b.energy.recd.total v.b.energy.used v.b.energy.used.total v.b.health v.b.p.level.avg v.b.p.level.max v.b.p.level.min v.b.p.level.stddev v.b.p.temp.avg v.b.p.temp.max v.b.p.temp.min v.b.p.temp.stddev v.b.p.temp.stddev.max 32°F v.b.p.voltage.avg v.b.p.voltage.grad v.b.p.voltage.max v.b.p.voltage.min v.b.p.voltage.stddev v.b.p.voltage.stddev.max 0V v.b.power v.b.range.est v.b.range.full v.b.range.ideal v.b.range.speed v.b.soc v.b.soh v.b.temp v.b.voltage v.c.12v.current v.c.12v.power v.c.12v.temp v.c.12v.voltage v.c.charging v.c.climit v.c.current v.c.duration.full v.c.duration.range v.c.duration.soc v.c.efficiency v.c.kwh v.c.kwh.grid v.c.kwh.grid.total v.c.limit.range 0M v.c.limit.soc 0% v.c.mode v.c.pilot v.c.power v.c.state v.c.substate v.c.temp v.c.time 0Sec v.c.timermode v.c.timerstart v.c.type v.c.voltage v.d.cp v.d.fl v.d.fr v.d.hood v.d.rl v.d.rr v.d.trunk v.e.alarm v.e.aux12v v.e.awake v.e.c.config v.e.c.login v.e.cabinfan v.e.cabinintake v.e.cabinsetpoint v.e.cabintemp v.e.cabinvent v.e.charging12v no v.e.cooling v.e.drivemode v.e.drivetime 0Sec v.e.footbrake v.e.gear v.e.handbrake v.e.headlights v.e.heating v.e.hvac v.e.locked v.e.on no v.e.parktime 87987Sec v.e.regenbrake v.e.serv.range v.e.serv.time v.e.temp v.e.throttle v.e.valet v.g.climit v.g.current v.g.duration.empty v.g.duration.range v.g.duration.soc v.g.efficiency v.g.generating v.g.kwh v.g.kwh.grid v.g.kwh.grid.total v.g.limit.range v.g.limit.soc v.g.mode v.g.pilot v.g.power v.g.state v.g.substate v.g.temp v.g.time 0Sec v.g.timermode v.g.timerstart v.g.type v.g.voltage v.i.efficiency v.i.power v.i.temp v.m.rpm v.m.temp v.p.acceleration v.p.altitude v.p.direction v.p.gpshdop v.p.gpslock v.p.gpsmode v.p.gpsspeed v.p.gpssq v.p.gpstime v.p.latitude v.p.location v.p.longitude v.p.odometer v.p.satcount v.p.speed v.p.trip v.t.alert v.t.health v.t.pressure v.t.temp v.type SE v.vin xse.hv.off.time 41494Sec xse.mybms.hv.contact.cycles.left xse.mybms.hv.contact.cycles.max xse.v.b.12v.voltage 0V xse.v.b.c.capacity xse.v.b.c.capacity.dev.max xse.v.b.c.capacity.max xse.v.b.c.capacity.min xse.v.b.energy.used.reset 0kWh xse.v.b.energy.used.start 0kWh xse.v.b.hv.active no xse.v.b.p.capacity.as.average xse.v.b.p.capacity.as.maximum xse.v.b.p.capacity.as.minimum xse.v.b.p.capacity.avg xse.v.b.p.capacity.combined.quality xse.v.b.p.capacity.max xse.v.b.p.capacity.max.cell xse.v.b.p.capacity.min xse.v.b.p.capacity.min.cell xse.v.b.p.capacity.quality xse.v.b.p.capacity.stddev xse.v.b.p.capacity.stddev.max 0 xse.v.b.p.hv.lowcurrent xse.v.b.p.hv.off.time xse.v.b.p.last.meas.days xse.v.b.p.ocv.timer xse.v.b.p.voltage.max.cell xse.v.b.p.voltage.min.cell xse.v.b.real.soc 0% xse.v.bus.awake no xse.v.c.active no xse.v.display.accel 50% xse.v.display.coast 50% xse.v.display.const 50% xse.v.display.ecoscore 50% xse.v.display.time 0Min xse.v.display.trip.reset 0M xse.v.display.trip.start 0M xse.v.nlg6.amps.cablecode 0A xse.v.nlg6.amps.chargingpoint 0A xse.v.nlg6.amps.setpoint 0A xse.v.nlg6.dc.current 0A xse.v.nlg6.dc.hv 0V xse.v.nlg6.dc.lv 0V xse.v.nlg6.main.amps xse.v.nlg6.main.volts xse.v.nlg6.pn.hw xse.v.nlg6.present no xse.v.nlg6.temp.coolingplate 32°F xse.v.nlg6.temp.reported 32°F xse.v.nlg6.temp.socket 32°F xse.v.nlg6.temps xse.v.pos.odometer.start 0M
Hello,
I do not believe I'm getting any data back after performing these steps.
I (50910775) webserver: HTTP POST /api/execute
OVMS# log level none
Logging level for * set to none
I (50910785) webcommand: HttpCommandStream[0x3f8b6b38]: 3473064 bytes free, executing: log level none
OVMS# log level verbose canlog-monitor
Logging level for canlog-monitor set to verbose
I (50934255) canlog-monitor: Now logging CAN messages to monitor
OVMS# can log start monitor crtd 512
CAN logging to MONITOR active: Type:monitor Format:crtd(discard) Filter:512 Vehicle:SE Note: info logging is at debug log level, frame logging is at verbose, and errors as usual
D (50934265) canlog-monitor: 1675527637.401993 CXX OVMS CRTD ……: 1675527637.401993 CVR 3.1
I plugged in my BMSdiag box into the OBD and was able to connect and pull the data from the car:
11:25:35.911 USB device detected
11:25:37.064 Connected to CH34x device
11:25:37.072 ^G%ZYU[^]�[]EY^U^AB�
11:25:38.714 7�^T!BCA�l]EYUes��A�P�^E�YUe]E�����2����
11:25:43.618 Disconnected
11:25:52.846 Connected to CH34x device
11:25:52.847 �
11:25:54.482 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:25:54.484 ‑‑‑ ED Battery Management Diagnostics ‑‑‑
11:25:54.487 ‑‑‑ v1.0.5 ‑‑‑
11:25:54.492 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:25:54.495
11:25:54.495 Connect to OBD port ‑ Waiting for CAN‑Bus
11:25:54.499 .CONNECTED
11:25:55.502 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:25:56.641 ........Reading data....................OK
11:26:00.968 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:00.971 Battery VIN: WMEEK9AA8DK679667
11:26:00.974 Time [hh:mm]: 11:24, ODO : 104635 km
11:26:00.976 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:00.982 Battery Status : OK
11:26:00.982
11:26:00.982 Battery Production [Y/M/D]: 2013/2/4
11:26:00.987 Battery‑FAT date [Y/M/D]: 2013/2/5
11:26:00.990 Rev.[Y/WK/PL] HW:2012/38/0, SW:2014/18/0
11:26:00.993 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:00.995 SOC : 99.0 %, realSOC: 96.1 %
11:26:00.998 HV : 378.5 V, ‑5.94 A, ‑2.25 kW
11:26:01.001 LV : 14.9 V
11:26:01.004 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.006 CV mean : 4077 mV, dV = 33 mV
11:26:01.009 CV min : 4050 mV
11:26:01.012 CV max : 4083 mV
11:26:01.012 OCVtimer: 51836 s
11:26:01.015 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.018 Last measurement : 30 day(s)
11:26:01.020 Measurement estimation: 0.752
11:26:01.023 Actual estimation : 0.372
11:26:01.026 CAP mean: 17972 As/10, 49.9 Ah
11:26:01.028 CAP min : 17029 As/10, 47.3 Ah
11:26:01.031 CAP max : 17731 As/10, 49.3 Ah
11:26:01.034 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.039 HV contactor state ON, low current: 0 s
11:26:01.042 Cycles left : 278019
11:26:01.045 of max. cycles: 300000
11:26:01.045 DC isolation : 64256 kOhm, OK
11:26:01.047 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.053 Temperatures Battery‑Unit /degC:
11:26:01.056 module 1: 3.3, 4.8, 4.6
11:26:01.058 module 2: 3.7, 5.2, 4.4
11:26:01.058 module 3: 3.7, 4.8, 4.1
11:26:01.061 mean : 4.3, min : 3.3, max : 5.2
11:26:01.064 coolant : 2.9
11:26:01.067 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.069 # ;mV ;As/10
11:26:01.072 01;4076;17884
11:26:01.072 02;4076;17797
11:26:01.076 03;4077;17840
11:26:01.076 04;4076;17753
11:26:01.078 05;4078;17840
11:26:01.078 06;4078;17840
11:26:01.081 07;4072;17884
11:26:01.081 08;4077;17928
11:26:01.081 09;4078;17840
11:26:01.083 10;4079;17840
11:26:01.083 11;4074;17797
11:26:01.086 12;4078;17972
11:26:01.086 13;4077;17840
11:26:01.089 14;4080;17753
11:26:01.089 15;4076;17884
11:26:01.094 16;4078;17710
11:26:01.094 17;4079;17797
11:26:01.094 18;4082;17884
11:26:01.094 19;4075;17797
11:26:01.097 20;4082;17840
11:26:01.097 21;4083;17753
11:26:01.100 22;4076;17624
11:26:01.100 23;4083;17884
11:26:01.100 24;4080;17667
11:26:01.103 25;4079;17624
11:26:01.103 26;4077;17455
11:26:01.105 27;4083;18062
11:26:01.105 28;4080;17884
11:26:01.109 29;4076;17840
11:26:01.109 30;4079;17928
11:26:01.110 31;4073;17797
11:26:01.110 32;4078;17928
11:26:01.114 33;4075;17884
11:26:01.114 34;4076;17884
11:26:01.116 35;4077;17928
11:26:01.116 36;4078;17753
11:26:01.119 37;4077;18017
11:26:01.119 38;4076;17667
11:26:01.121 39;4082;17928
11:26:01.121 40;4079;17840
11:26:01.121 41;4078;17840
11:26:01.125 42;4083;17884
11:26:01.125 43;4076;17884
11:26:01.127 44;4081;17753
11:26:01.127 45;4082;17797
11:26:01.131 46;4083;17797
11:26:01.131 47;4083;17624
11:26:01.132 48;4082;17797
11:26:01.132 49;4080;17413
11:26:01.135 50;4082;17928
11:26:01.135 51;4083;18017
11:26:01.138 52;4083;17753
11:26:01.138 53;4083;17840
11:26:01.141 54;4084;17710
11:26:01.141 55;4078;17840
11:26:01.141 56;4082;17753
11:26:01.143 57;4082;17840
11:26:01.143 58;4083;17840
11:26:01.149 59;4076;17582
11:26:01.149 60;4074;17582
11:26:01.150 61;4076;17582
11:26:01.150 62;4078;17753
11:26:01.152 63;4079;17884
11:26:01.152 64;4075;17582
11:26:01.155 65;4074;17753
11:26:01.155 66;4073;17710
11:26:01.157 67;4080;17797
11:26:01.157 68;4073;17753
11:26:01.160 69;4071;17753
11:26:01.160 70;4076;17753
11:26:01.163 71;4074;17667
11:26:01.163 72;4077;17624
11:26:01.163 73;4077;17797
11:26:01.165 74;4077;17797
11:26:01.165 75;4078;17753
11:26:01.169 76;4075;17884
11:26:01.169 77;4076;17840
11:26:01.171 78;4077;17884
11:26:01.171 79;4078;17884
11:26:01.173 80;4082;17928
11:26:01.173 81;4076;17710
11:26:01.177 82;4074;17797
11:26:01.177 83;4079;17840
11:26:01.179 84;4078;17797
11:26:01.179 85;4075;17797
11:26:01.182 86;4051;17624
11:26:01.182 87;4074;17797
11:26:01.182 88;4076;17710
11:26:01.184 89;4076;17840
11:26:01.184 90;4074;17710
11:26:01.187 91;4077;17710
11:26:01.187 92;4080;17667
11:26:01.190 93;4076;17667
11:26:01.190 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.196 Individual Cell Statistics:
11:26:01.199 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.201 CV mean : 4078 mV, dV= 33 mV, s= 4.13 mV
11:26:01.204 CV min : 4051 mV, # 86
11:26:01.207 CV max : 4084 mV, # 54
11:26:01.209 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.212 CAP mean: 17791 As/10, 49.4 Ah
11:26:01.215 CAP min : 17413 As/10, 48.4 Ah, # 49
11:26:01.217 CAP max : 18062 As/10, 50.2 Ah, # 27
11:26:01.221 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.236 Voltage Distribution (dV= 33 mV):
11:26:01.239 *‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑>‑‑‑‑‑‑[=|==]‑‑‑‑*
11:26:01.242 4051 00 > [4076; 4078; 4080] < 00 4084
11:26:01.246 min [p25; median; p75] max
11:26:01.250 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.254 Reading data....OK
11:26:01.564 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.566 Status OBL Charger‑Unit:
11:26:01.569 User selected : 16 A
11:26:01.572 Cable maximum : 204 A
11:26:01.572 AC L1: 238.1 V, 0.6 A
11:26:01.574 DC HV: 378.1 V, 0.0 A
11:26:01.577 DC LV: 15.1 V
11:26:01.577 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.583 Temperatures Charger‑Unit /degC:
11:26:01.586 Reported : 1
11:26:01.586 Cooling plate : 2
11:26:01.588 Inlet socket : NA
11:26:01.591 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:01.594 Reading data.OK
11:26:06.709 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:06.710 Status Cooling‑ and Subsystems:
11:26:06.713 Temperature : ‑0.6 degC
11:26:06.716 Cooling fan : 0.0 %
11:26:06.719 Cooling pump : 59.2 %, 2 degC
11:26:06.721 : 14.6 V, 1.4 A
11:26:06.724 OTR:
11:26:06.724 Cooling fan : 114 h
11:26:06.727 Cooling pump : 10922 h
11:26:06.727 Battery heater: 0 h, OFF
11:26:06.730 Vaccum pump : 89.509 h
11:26:06.732 Pressure 1, 2 : ‑646 mbar, ‑648 mbar
11:26:06.735 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:06.738
11:26:06.741
11:26:06.741 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:06.743 Battery VIN: WMEEK9AA8DK679667
11:26:06.746 Time [hh:mm]: 11:24, ODO : 104635 km
11:26:06.749 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:06.754 SOC : 99.0 %, realSOC: 96.1 %
11:26:06.754 HV : 378.5 V, ‑5.94 A, ‑2.25 kW
11:26:06.760 LV : 14.9 V
11:26:06.760 ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑
11:26:06.762 ENTER command... (? for help)
11:26:06.767 CMD >>
I noticed my OVMS cable has a label on it that says NL. I do know that the Australian I bought this from on ebay had intended to use it with a Nissan Leaf. Do you think I need a different OBD cable? If so, can you suggest the cable and a supplier who is willing to ship to the USA? (I bought this OVMS off ebay because no supplier in the USA would respond to inquiry)
Thank you!
See here:
Smart ED requires "OBD-II to DB9 Data Cable for OVMS (1441200 right, or 1139300 left)". The NL cable you have is a different pinout. Cable documentation is here:
Changing to the standard OB-L or OB-R cables should resolve your problem. Alternatively, if you DIY capable, you can cut the cable you have and re-wire it correctly for your car.
I ordered a Generic OBD II cable from the OVMS store... hopefully this will solve my problem.
Hi,
the OBD NL cable is diffrend to the OBD Left or Right cable.
Pinout: NL
J1962-M DB9-F Signal
4 3 Chassis/Power GND
6 5 CAN-H (alternate CAN)
14 4 CAN-L (alternate CAN)
13 7 CAN-H (primary CAN)
12 2 CAN-L (primary CAN)
16 9 +12V Vehicle Power
Pinout: OB-L
6 7 CAN-H (primary CAN)
14 2 CAN-L (primary CAN)
13 5 CAN-H (alternate CAN)
12 4 CAN-L (alternate CAN)
