2 posts / 0 new
Kristoffer
Modem looses connection to cellular provider, (shutting down hard...)
Hi!
This is my first post here, So I thought I should go in swinging with a large one laugh
First of all, I would like to express that I'm very greatful for such a wonderful product, the OVMS really tickle my inner nerd in a good way.
So, the reason for this post, is actually to share a pattern that I found during another fault finding activity that I had together with Michael over at Twizyforum.de - High cellular data usage/consumption, an issue that we most likely  solved or at least found the cause of - bad wifi in my garage.
So back to the findings and the pattern that I wanted to share and hopefully also find a solution to: My modem "resets" with an interesting interval/duration between resets.
Below we have a table with the session logging from Hologram, and the LENGTH of these sessions "exactly" matches the duration of time between the log file of the OVMS for when the system performs a reset of the modem, below log file example from OVMS is just an example, so the date/time stamps do not match with the time stamps from Hologram.
OVMS events from log:
2023-02-03 17:45 :57.668 CET D (6766128) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
2023-02-03 17:46:27.668 CET D (6796128) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
2023-02-03 17:46:57.668 CET D (6826128) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
2023-02-03 17:47:27.668 CET D (6856128) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
2023-02-03 17:47:57.668 CET D (6886128) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
2023-02-03 17:48:27.668 CET D (6916128) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
2023-02-03 17:48:57.668 CET W (6946128) cellular: 3 minutes since last MUX rx frame - assume MUX has failed
2023-02-03 17:48:57.668 CET I (6946128) gsm-ppp: Shutting down (hard)...
Hologram session log:
START TIMESTAMP END TIMESTAMP LENGTH Length Trimmed BYTES
2023-02-08 8:40:38 2023-02-08 9:38:00 0:57:22 0:57 0 B
2023-02-08 7:43:16 2023-02-08 8:40:38 0:57:22 0:57 0 B
2023-02-08 4:51:28 2023-02-08 7:43:16 2:51:48 2:51 1.48 KB
2023-02-08 3:00:06 2023-02-08 4:51:28 1:51:22 1:51 0 B
2023-02-08 1:08:44 2023-02-08 3:00:06 1:51:22 1:51 0 B
2023-02-07 22:23:21 2023-02-08 1:08:43 2:45:22 2:45 0 B
2023-02-07 21:25:57 2023-02-07 22:23:21 0:57:24 0:57 0 B
2023-02-07 20:55:53 2023-02-07 21:25:12 0:29:19 0:29 0 B
2023-02-07 19:58:32 2023-02-07 20:55:53 0:57:21 0:57 0 B
2023-02-07 19:01:14 2023-02-07 19:58:31 0:57:17 0:57 0 B
2023-02-07 18:03:52 2023-02-07 19:01:14 0:57:22 0:57 0 B
2023-02-07 12:36:29 2023-02-07 18:03:52 5:27:23 5:27 0 B
2023-02-07 11:39:07 2023-02-07 12:36:29 0:57:22 0:57 0 B
2023-02-07 7:59:44 2023-02-07 11:39:07 3:39:23 3:39 0 B
2023-02-07 7:02:22 2023-02-07 7:59:44 0:57:22 0:57 0 B
2023-02-07 7:01:52 2023-02-07 7:01:57 0:00:05 0:00 0 B
2023-02-07 6:04:30 2023-02-07 7:01:52 0:57:22 0:57 0 B
2023-02-07 4:12:38 2023-02-07 6:04:24 1:51:46 1:51 0 B
2023-02-07 4:12:08 2023-02-07 4:12:13 0:00:05 0:00 0 B
2023-02-07 3:14:46 2023-02-07 4:12:08 0:57:22 0:57 0 B
2023-02-07 2:17:24 2023-02-07 3:14:46 0:57:22 0:57 0 B
2023-02-07 0:26:01 2023-02-07 2:17:24 1:51:23 1:51 0 B
2023-02-06 22:34:39 2023-02-07 0:26:01 1:51:22 1:51 0 B
2023-02-06 22:34:09 2023-02-06 22:34:15 0:00:06 0:00 0 B
2023-02-06 20:42:47 2023-02-06 22:34:09 1:51:22 1:51 0 B
2023-02-06 16:08:11 2023-02-06 20:42:47 4:34:36 4:34 816 B
2023-02-06 15:10:51 2023-02-06 16:08:11 0:57:20 0:57 0 B
2023-02-06 14:13:30 2023-02-06 15:10:51 0:57:21 0:57 0 B
2023-02-06 13:16:21 2023-02-06 14:13:30 0:57:09 0:57 0 B
2023-02-06 12:19:27 2023-02-06 13:16:21 0:56:54 0:56 0 B
2023-02-06 11:22:01 2023-02-06 12:19:21 0:57:20 0:57 0 B
2023-02-06 10:25:06 2023-02-06 11:22:01 0:56:55 0:56 0 B
2023-02-06 9:28:11 2023-02-06 10:25:06 0:56:55 0:56 0 B
2023-02-06 8:31:16 2023-02-06 9:28:11 0:56:55 0:56 0 B
2023-02-06 7:34:21 2023-02-06 8:31:16 0:56:55 0:56 0 B
2023-02-06 6:36:59 2023-02-06 7:34:21 0:57:22 0:57 0 B
2023-02-06 5:39:37 2023-02-06 6:36:59 0:57:22 0:57 0 B
2023-02-06 4:42:15 2023-02-06 5:39:37 0:57:22 0:57 0 B
2023-02-06 2:50:53 2023-02-06 4:42:15 1:51:22 1:51 0 B
2023-02-06 1:53:31 2023-02-06 2:50:53 0:57:22 0:57 0 B
2023-02-06 0:02:09 2023-02-06 1:53:31 1:51:22 1:51 0 B
2023-02-05 23:04:52 2023-02-06 0:02:09 0:57:17 0:57 0 B
2023-02-05 22:07:30 2023-02-05 23:04:52 0:57:22 0:57 0 B
Durations or intervals between resets in the data set above:
Length hh:mm Frequency (how many times did the interval occur)
00:57 24
01:51 8
00:56 5
00:00 3
4:34 1
My setup:
  • OVMS V3.3
    • OVMS MDM V3.3
    • Firmware: 3.3.003-297-gae3bc7fd/ota_0/edge (build idf v3.3.4-849-g6e214dc335 Feb 4 2023 10:32:20)
      • Running an edge version by Dexter, specifically modified for trying to find the issue with the resets, but it's the same with main 3.3.003.
    • Powered via USB-adapter 2.5A
  • Vehicle: Renault Twizy
OVMS MODULE SUMMARY
Module
  Version:  3.3.003-297-gae3bc7fd/ota_0/edge (build idf v3.3.4-849-g6e214dc335 Feb  4 2023 10:32:20)
  Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
  12v:      0.0v
MODEM Status
  Model: SIM7600
  Network Registration: RegisteredRoaming
    Provider: Telia Hologram
    Signal: -73 dBm
    Mode: LTE,Online
  State: NetMode
    Ticker: 1151
    User Data: 0
  UART:
    FIFO overflows: 0
    Buffer overflows: 0
    Parity errors: 0
    Frame errors: 0
    Driver Buffer overflows: 0
  Mux: Status up
    Open Channels: 4
    Framing Errors: 0
    RX frames: 735
    TX frames: 145
    Last RX frame: 2 sec(s) ago
  PPP: Connected on channel: #2
     Connects: 1
  GPS: Connected on channel: #1
     Status: enabled
     Time: enabled
Configuration
  [auto]
    dbc: no
    egpio: no
    ext12v: no
    init: yes
    modem: yes
    obd2ecu:
    ota: no
    scripting: yes
    server.v2: yes
    server.v3: no
    vehicle.type: RT
    wifi.mode: apclient
    wifi.ssid.ap: NHH456
    wifi.ssid.client: LEDE
  [can]
  [dbc]
  [egpio]
    monitor.ports:
  [http.plugin]
  [http.server]
  [locations]
  [log]
    file.enable: yes
    file.path: /sd/logs/NHH456.log
    level: info
    level.cellular: debug
    level.gsm-nmea: debug
    level.gsm-ppp: info
    level.netmanager: info
  [modem]
    apn: hologram
    apn.password:
    apn.user:
    enable.gps: yes
    enable.gpstime: yes
    enable.net: yes
    enable.sms: yes
    pincode:
  [module]
    cfgversion: 2022121400
    init: done
  [network]
    dns: 8.8.8.8 8.8.4.4
  [notify]
    report.trip.enable: yes
    report.trip.minlength: 15
    xrt.gps.log: -
  [obd2ecu]
  [obd2ecu.map]
  [ota]
    auto.allow.modem: no
    auto.hour: 2
    http.mru: https://ovms.dexters-web.de/firmware/ota/v3.3/edge/ovms3.bin
    server: https://ovms.dexters-web.de/firmware/ota
    tag: edge
  [password]
    module: **redacted**
    server.v2: **redacted**
    server.v3: **redacted**
  [plugin]
  [plugin.disabled]
  [plugin.enabled]
  [plugin.repos]
  [power]
    12v_shutdown_delay: 30
    enabled: no
    modemoff_delay: 96
    wifioff_delay: 24
  [pushover]
  [sdcard]
  [server.v2]
    port:
    server: ovms.dexters-web.de
    tls: no
    updatetime.connected: 120
    updatetime.idle: 3600
  [server.v3]
    port:
    server:
    tls: no
    topic.prefix:
    updatetime.idle:
    user:
  [ssh.info]
    fingerprint: NBMMOzP3abQT82A7nQX1vZp2vpyOQTjkWPXqTE6GOwg
  [ssh.keys]
  [ssh.server]
    key: **redacted**
  [system.adc]
    factor12v: 192.4
  [tpms]
  [usr]
  [vehicle]
    12v.alert: 12.1
    12v.ref:
    accel.smoothing: 4
    batpwr.smoothing: 4
    brakelight.basepwr: 0
    brakelight.enable: no
    brakelight.ignftbrk: no
    brakelight.off: 0.7
    brakelight.on: 1.3
    brakelight.port: 1
    minsoc: 0
    name:
    stream: 0
    timezone: CET-1CEST,M3.5.0,M10.5.0/3
    timezone_region: Europe/Stockholm
    units.distance: K
  [wifi.ap]
    NHH456: **redacted**
  [wifi.ssid]
    LEDE: **redacted**
REPORT ENDS
Sorry for the wall of text.. But It's hard to describe without much detail... guaranteed, I also missed out on sharing something important...
Anyways, many thanks in advance for any tips!
Kind regards,
Kristoffer
dexter
dexter's picture
@Mark, adding another detail from Kristoffer's logs: all resets look the same and only need a single (!) power cycle to restart the modem. The modem is then identified in the same time as needed when started from the powered off state.
So this looks like the modem powers down by itself occasionally after some multiple of 55 minutes of uptime, and it does so without any message (i.e. no temperature or voltage warning received).
Complete RX loss & modem reset example:
2023-02-06 08:30:37.257 CET D (63028277) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ
2023-02-06 08:30:37.277 CET D (63028297) cellular: mux-rx-line #3: +CREG: 1,5
2023-02-06 08:30:37.277 CET D (63028297) cellular: mux-rx-line #3: +CGREG: 1,5
2023-02-06 08:30:37.277 CET D (63028297) cellular: mux-rx-line #3: +CEREG: 1,5
2023-02-06 08:30:37.277 CET D (63028297) cellular: mux-rx-line #3: +CCLK: "23/02/06,08:30:35+04"
2023-02-06 08:30:37.277 CET D (63028297) cellular: mux-rx-line #3: +CSQ: 16,99
2023-02-06 08:30:37.287 CET D (63028307) cellular: mux-rx-line #3: OK
2023-02-06 08:30:38.257 CET D (63029277) cellular: mux-tx #3: AT+CPSI?
2023-02-06 08:30:38.277 CET D (63029297) cellular: mux-rx-line #3: +CPSI: LTE,Online,240-01,0x0332,27847448,226,EUTRAN-BAND3,1471,4,4,-166,-1085,-711,8
2023-02-06 08:30:38.277 CET D (63029297) cellular: mux-rx-line #3: OK
2023-02-06 08:30:39.257 CET D (63030277) cellular: mux-tx #3: AT+COPS?
2023-02-06 08:30:39.267 CET D (63030287) cellular: mux-rx-line #3: +COPS: 0,0,"Telia Hologram",7
2023-02-06 08:30:39.277 CET D (63030297) cellular: mux-rx-line #3: OK
2023-02-06 08:31:01.647 CET D (63052667) cellular: mux-rx-line #3: +CSQ: 19,99
2023-02-06 08:31:01.647 CET I (63052667) cellular: Signal Quality is: 19 (-75 dBm)
2023-02-06 08:31:04.647 CET D (63055667) cellular: mux-rx-line #3: +CSQ: 16,99
2023-02-06 08:31:04.647 CET I (63055667) cellular: Signal Quality is: 16 (-81 dBm)
2023-02-06 08:31:07.257 CET D (63058277) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ
2023-02-06 08:31:08.257 CET D (63059277) cellular: mux-tx #3: AT+CPSI?
2023-02-06 08:31:09.257 CET D (63060277) cellular: mux-tx #3: AT+COPS?
2023-02-06 08:31:37.257 CET D (63088277) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ
2023-02-06 08:31:38.257 CET D (63089277) cellular: mux-tx #3: AT+CPSI?
2023-02-06 08:31:39.257 CET D (63090277) cellular: mux-tx #3: AT+COPS?
2023-02-06 08:32:07.257 CET D (63118277) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ
2023-02-06 08:32:08.257 CET D (63119277) cellular: mux-tx #3: AT+CPSI?
2023-02-06 08:32:09.257 CET D (63120277) cellular: mux-tx #3: AT+COPS?
2023-02-06 08:32:37.257 CET D (63148277) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ
2023-02-06 08:32:38.257 CET D (63149277) cellular: mux-tx #3: AT+CPSI?
2023-02-06 08:32:39.257 CET D (63150277) cellular: mux-tx #3: AT+COPS?
2023-02-06 08:33:07.257 CET D (63178277) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ
2023-02-06 08:33:08.257 CET D (63179277) cellular: mux-tx #3: AT+CPSI?
2023-02-06 08:33:09.257 CET D (63180277) cellular: mux-tx #3: AT+COPS?
2023-02-06 08:33:37.257 CET D (63208277) cellular: mux-tx #3: AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ
2023-02-06 08:33:38.257 CET D (63209277) cellular: mux-tx #3: AT+CPSI?
2023-02-06 08:33:39.257 CET D (63210277) cellular: mux-tx #3: AT+COPS?
2023-02-06 08:34:07.257 CET W (63238277) cellular: 3 minutes since last MUX rx frame - assume MUX has failed
2023-02-06 08:34:07.257 CET I (63238277) gsm-ppp: Shutting down (hard)...
2023-02-06 08:34:07.257 CET I (63238277) gsm-ppp: StatusCallBack: User Interrupt
2023-02-06 08:34:07.257 CET I (63238277) gsm-ppp: PPP is shutdown
2023-02-06 08:34:07.257 CET D (63238277) cellular: mux-tx #4: AT+CGPSNMEA=0
2023-02-06 08:34:07.257 CET D (63238277) cellular: mux-tx #4: AT+CGPSINFOCFG=0
2023-02-06 08:34:07.257 CET I (63238277) netmanager: MODEM down (with WIFI client up): staying with WIFI client priority
2023-02-06 08:34:07.357 CET D (63238377) cellular: mux-tx #4: AT+CGPS=0
2023-02-06 08:34:07.357 CET I (63238377) gsm-nmea: Shutdown (direct)
2023-02-06 08:34:07.357 CET I (63238377) gsm-mux: Stop MUX
2023-02-06 08:34:07.357 CET I (63238377) SIM7600: Power Cycle (SIM7600) 2000ms
2023-02-06 08:34:09.357 CET D (63240377) cellular: State transition NetMode => PoweringOn
2023-02-06 08:34:09.357 CET I (63240377) cellular: State: Enter PoweringOn state
2023-02-06 08:34:09.357 CET D (63240377) cellular: Remove old 'SIM7600' modem driver
2023-02-06 08:34:09.357 CET I (63240377) cellular: Set modem driver to 'auto'
2023-02-06 08:34:09.357 CET I (63240377) cellular-modem-auto: Power Cycle 2000ms
2023-02-06 08:34:11.357 CET D (63242377) cellular: tx-cmd: AT
2023-02-06 08:34:12.257 CET D (63243277) cellular: tx-cmd: AT
2023-02-06 08:34:13.257 CET D (63244277) cellular: tx-cmd: AT
2023-02-06 08:34:14.257 CET D (63245277) cellular: tx-cmd: AT
2023-02-06 08:34:15.257 CET D (63246277) cellular: tx-cmd: AT
2023-02-06 08:34:16.257 CET D (63247277) cellular: tx-cmd: AT
2023-02-06 08:34:17.257 CET D (63248277) cellular: tx-cmd: AT
2023-02-06 08:34:18.257 CET D (63249277) cellular: tx-cmd: AT
2023-02-06 08:34:19.257 CET D (63250277) cellular: tx-cmd: AT
2023-02-06 08:34:20.257 CET D (63251277) cellular: tx-cmd: AT
2023-02-06 08:34:21.257 CET D (63252277) cellular: tx-cmd: AT
2023-02-06 08:34:22.257 CET D (63253277) cellular: tx-cmd: AT
2023-02-06 08:34:23.257 CET D (63254277) cellular: tx-cmd: AT
2023-02-06 08:34:24.257 CET D (63255277) cellular: tx-cmd: AT
2023-02-06 08:34:25.057 CET I (63256077) cellular: State: Enter Identify state
2023-02-06 08:34:25.257 CET D (63256277) cellular: tx-cmd: AT+CGMM
2023-02-06 08:34:25.267 CET I (63256287) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600
Kristoffer also has the identical effect with two different providers.
My guess is some weird hardware fault with the modem.
