Hi,
I’m setting up an OVMS v3 (OVMS-33-7600G) module on a Nissan Leaf (2014) to replace Nissan’s original remote climate control service, which is no longer supported.
Goal: remote climate control / pre-heating
Vehicle module: OVMS v3 (ESP32)
Current status
Firmware updated successfully via microSD
→ now running 3.3.005 (OTA) -
Module works locally:
CAN data OK (SOC, ODO, GPS lock, etc.)
Web UI accessible via local WiFi (192.168.4.1)
Cellular modem:
SIM: Hologram global IoT SIM
Local operator: Elisa (Finland)
LTE online, PPP connected
DNS working (8.8.8.8 visible)
Hologram dashboard confirms SIM is active and data usage increases when OVMS is powered
Server settings:
Server:
api.openvehicles.com -
Port:
8883 -
TLS enabled
Username = OVMS user
Vehicle ID = code printed on the device label
Passwords consistent across module, server account and app
Problem
OVMS Server V3 never reaches “Connected”:
Status stays at “Connecting…”
Log shows: Launching OVMS Server V3 connection (oscv3)
Never transitions to Connected
OVMS App cannot connect either
What I have already tried
Firmware update + multiple reboots
Re-entered all credentials carefully
Verified Vehicle ID matches the physical device label
Restarted modem and network interfaces
Confirmed cellular data is flowing via Hologram dashboard
Questions
Any known issues or special requirements when using Hologram SIM with OVMS Server V3?
Anything specific to verify regarding TLS / MQTT on Server V3?
Any known problems with OVMS firmware 3.3.005 and Server V3?
Happy to provide logs or screenshots if needed.
Thanks in advance.
