57 posts / 0 new
Roald Nakstad
HV battery broken ?!?
*H*E*L*P*
My Smart ED3 have been left undriven for 3 weeks. During that period I watched cell voltage dropping uneven, and now when trying to recharge it won't start to charge !?!
I tried to run 'bms reset', but the Alerts returns emidiately when connecting charge cable again:
Voltage: SD=67mV !1:-120mV !2:-101mV !3:-50mV !4:-293mV !29:-52mV !30:-438mV !31:-130mV !63:-206mV !64:-88mV
Temperature: SD=0.4C OK
OVMS# bms status
Voltage:
    Average: 3.503V [3.064V - 3.544V]
  Deviation: SD  67.10mV [max 67.10mV], 17 warnings, 9 alerts
Temperature:
    Average:   9.9C [  9.3C -  10.7C]
  Deviation: SD   0.39C  [max 0.40C], 0 warnings, 0 alerts
Cells:
  1 | 3.382V |   9.8C |
  2 | 3.401V |  10.1C |
  3 | 3.452V |  10.7C |
  4 | 3.209V |   9.3C |
  5 | 3.515V |   9.5C |
  6 | 3.504V |   9.7C |
  7 | 3.505V |   9.8C |
  8 | 3.512V |  10.0C |
  9 | 3.502V |  10.2C |
 10 | 3.501V |  -0.0C |
 11 | 3.510V |   1.0C |
 12 | 3.514V |  -0.0C |
 13 | 3.528V |   2.0C |
 14 | 3.514V |   0.0C |
 15 | 3.516V |   9.8C |
 16 | 3.514V |  10.1C |
 17 | 3.518V |  10.7C |
 18 | 3.513V |   9.3C |
 19 | 3.520V |   9.5C |
 20 | 3.507V |   9.7C |
 21 | 3.490V |   9.8C |
 22 | 3.512V |  10.0C |
 23 | 3.527V |  10.2C |
 24 | 3.502V |  -0.0C |
 25 | 3.519V |   1.0C |
 26 | 3.509V |  -0.0C |
 27 | 3.507V |   2.0C |
 28 | 3.498V |   0.0C |
 29 | 3.450V |   9.8C |
 30 | 3.064V |  10.1C |
 31 | 3.372V |  10.7C |
 32 | 3.493V |   9.3C |
 33 | 3.502V |   9.5C |
 34 | 3.526V |   9.7C |
 35 | 3.527V |   9.8C |
 36 | 3.533V |  10.0C |
 37 | 3.541V |  10.2C |
 38 | 3.527V |  -0.0C |
 39 | 3.530V |   1.0C |
 40 | 3.517V |  -0.0C |
 41 | 3.519V |   2.0C |
 42 | 3.525V |   0.0C |
 43 | 3.536V |  -0.1C |
 44 | 3.535V |   0.2C |
 45 | 3.523V |   0.8C |
 46 | 3.532V |  -0.6C |
 47 | 3.539V |  -0.4C |
 48 | 3.526V |  -0.2C |
 49 | 3.534V |  -0.1C |
 50 | 3.529V |   0.1C |
 51 | 3.543V |   0.3C |
 52 | 3.544V |  -0.0C |
 53 | 3.543V |   1.0C |
 54 | 3.515V |  -0.0C |
 55 | 3.519V |   2.0C |
 56 | 3.516V |   0.0C |
 57 | 3.517V |   0.0C |
 58 | 3.517V |   0.0C |
 59 | 3.506V |   0.0C |
 60 | 3.517V |   0.0C |
 61 | 3.505V | 68169720922112.0C |
 62 | 3.496V | -169296593500958770697728504251457470464.0C |
 63 | 3.296V |   1.0C |
 64 | 3.414V |  -0.0C |
 65 | 3.477V |   2.0C |
 66 | 3.532V |   0.0C |
 67 | 3.525V |   1.0C |
 68 | 3.539V |   1.0C |
 69 | 3.522V |   0.0C |
 70 | 3.519V | 71859503208318044733440.0C |
 71 | 3.532V | 264479218549703835648.0C |
 72 | 3.538V | 71561207286999159930880.0C |
 73 | 3.537V |   0.0C |
 74 | 3.539V |   1.0C |
 75 | 3.534V |   0.0C |
 76 | 3.532V | 71430716706035219338123284578304.0C |
 77 | 3.518V | 18178671951207061558369630289920.0C |
 78 | 3.525V |   1.0C |
 79 | 3.533V |   0.0C |
 80 | 3.527V |   2.4C |
 81 | 3.542V |   0.0C |
 82 | 3.529V |   0.0C |
 83 | 3.526V |   0.0C |
 84 | 3.517V |  -0.0C |
 85 | 3.533V |   1.0C |
 86 | 3.529V |  -0.0C |
 87 | 3.526V |   2.0C |
 88 | 3.528V |   0.0C |
 89 | 3.530V |   1.0C |
 90 | 3.501V |   1.0C |
 91 | 3.508V |   0.0C |
 92 | 3.511V | 71859503208318044733440.0C |
 93 | 3.521V | 71426891664741958651414514237440.0C |
IS MY HV-BATTERY BROKEN ?!?!?
gtwibell
Roald,
Roald,
I feel your pain. I went through the same a year and a half ago. HV battery failed and DC/DC converter to charge the 12v service battery also failed.
Please do check your 12v battery. Allowing it to run down is a known HV battery killer. In my case it ran down as it was no longer being charged correctly by the car and I was distracted by other, more important things in my life at the time.
Roald Nakstad
12V is not drained totaly. My
12V is not drained totaly. My OVMS runs on it an reports 11.5V now.
Roald Nakstad
gtwibell,  Did you get it
gtwibell,  Did you get it fixed, or did you need to replace the complete HV-battery?
gtwibell
I was covered by the Battery
I was covered by the Battery Assurance Program at the time. Dealer fitted new 12v battery, HV battery and DC/DC converter under warranty. I think I was very lucky but I did have to wait 8 months for the HV battery from Germany. Battery Assurance has now run out. It is my problem now if it fails again. Be sure I have a 12v battery monitor on the dashboard now!
Dimitrie
HV-BATTERY BROKEN
That does not sound good.
Your 12V battery may be bad and the Smart always tried to recharge it. This can lead to the HV battery being deeply discharged and now broken. If you do not have access to a star diagnosis. Can you read out at most the fault memory with an Autel AP200. Unfortunately, I can't help you much. You can also use the "xse bmsdiag" command to call up a battery diagnosis that is more meaningful.
Roald Nakstad
Dimitrie,  As you can see
Dimitrie,  As you can see only cell 30 is at 3v rest is at approx 3,4v is that deep discharge?
Roald Nakstad
OVMS# xse bmsdiag
OVMS# xse bmsdiag
---- ED Battery Management Diagnostics ----
----         OVMS Version 1.0          ----
Battery VIN: WMEEJ9AAXEK733054
Time [hh:mm]: 16:56,   ODO : 24319km
Battery Status   : DEGRADED: 00110001
Battery Production [Y/M/D]: 2013/7/17
Battery-FAT date   [Y/M/D]: 2013/7/17
Rev.[Y/WK/PL] HW:2012/38/0, SW:2014/18/0
SOC : 0.0%, realSOC: 4.0%
HV  : 10.0 V, 0.00 A, 0.00 kW
LV  : 11.8 V
CV mean :  3503 mV, dV = 67.12 mV
CV min  :  3064 mV
CV max  :  3544 mV
OCVtimer: 8795 s
Last measurement      : 23 day(s)
Measurement estimation: 0.740
Actual estimation     : 0.418
CAP mean: 18482 As/10, 51.3 Ah
CAP min : 18068 As/10, 50.2 Ah
CAP max : 19029 As/10, 52.9 Ah
HV contactor state OFF, for: 2 s
Cycles left   : 289980
of max. cycles: 300000
DC isolation  : 11636 kOhm, OK
Temperatures Battery-Unit /degC:
module 1: 9.9, 10.0, 10.7
module 2: 9.4, 9.3, 9.7
module 3: 9.8, 9.8, 10.2
   mean : 9.9, min : 9.3, max : 10.7
coolant : 10.2
 # ;mV   ;As/10
  1; 3300; 14610
  2; 3320; 14610
  3; 3370; 14863
  4; 3127; 14129
  5; 3433; 17265
  6; 3423; 17301
  7; 3423; 17372
  8; 3430; 17229
  9; 3420; 17372
 10; 3419; 17408
 11; 3429; 17301
 12; 3433; 17408
 13; 3445; 17408
 14; 3432; 17265
 15; 3435; 17301
 16; 3432; 17301
 17; 3436; 17408
 18; 3432; 17408
 19; 3438; 17372
 20; 3426; 17408
 21; 3408; 14863
 22; 3430; 17408
 23; 3445; 17408
 24; 3419; 17372
 25; 3437; 17301
 26; 3427; 17408
 27; 3425; 17408
 28; 3417; 17408
 29; 3368; 14900
 30; 2982; 13932
 31; 3290; 14575
 32; 3411; 14975
 33; 3421; 14975
 34; 3444; 17301
 35; 3445; 17229
 36; 3451; 17301
 37; 3459; 17265
 38; 3445; 17408
 39; 3448; 17265
 40; 3435; 17408
 41; 3437; 17408
 42; 3444; 17408
 43; 3455; 17301
 44; 3453; 17408
 45; 3441; 17301
 46; 3450; 17336
 47; 3457; 17265
 48; 3444; 17372
 49; 3452; 17408
 50; 3447; 17408
 51; 3462; 17408
 52; 3462; 17444
 53; 3461; 17408
 54; 3434; 17408
 55; 3436; 17301
 56; 3434; 17265
 57; 3436; 17301
 58; 3435; 17265
 59; 3424; 14937
 60; 3436; 17194
 61; 3423; 17229
 62; 3414; 14975
 63; 3214; 14229
 64; 3333; 17194
 65; 3395; 14975
 66; 3450; 17301
 67; 3443; 17229
 68; 3457; 17372
 69; 3440; 17229
 70; 3437; 17301
 71; 3451; 17229
 72; 3457; 17229
 73; 3456; 17229
 74; 3457; 17408
 75; 3453; 17229
 76; 3451; 17265
 77; 3436; 17301
 78; 3443; 17408
 79; 3451; 17301
 80; 3445; 17444
 81; 3460; 17372
 82; 3447; 17517
 83; 3444; 17444
 84; 3435; 17408
 85; 3451; 17408
 86; 3447; 17444
 87; 3445; 17336
 88; 3446; 17372
 89; 3448; 17229
 90; 3419; 14975
 91; 3426; 17159
 92; 3429; 17124
 93; 3439; 17159
Individual Cell Statistics:
CV mean : 3421 mV, dV= 480 mV, s= 67.12 mV
CV min  : 2982 mV, # 30
CV max  : 3462 mV, # 51
CAP mean: 16908 As/10, 47.0 Ah
CAP min : 13932 As/10, 38.7 Ah, # 30
CAP max : 17517 As/10, 48.7 Ah, # 82
MineCooky
MineCooky's picture
The lower final charge
The lower final charge voltage is at 3,2V, so yes, cell 4 & 30 is deep discharged, cell 63 is close to it. The rest looks fine. I'm guessing you now have got the well known P18051C error.
If you won't get a new battery by the dealer, you have to open the battery, charge cell 4, 30 and 63 to >3200mV and let somebody reset the BMS for you. The whole process would take about 4-8 weeks.
Roald Nakstad
MineCooky, oh shit. That was
MineCooky, oh shit. That was not good new. Is there realy no other way around this ?
Roald Nakstad
Is it possible to read out
Is it possible to read out error code with OVMS, or do I need a diagnostic tool to check for P18051C ?
Dimitrie
You need a diagnosis tool to
You need a diagnosis tool to check for P18051C
gtwibell
There is I believe a company
There is I believe a company in Ukraine that can diagnose and fix battery management problems. But I do not know where you are located.  https://gosmart.com.ua/
Roald Nakstad
Thanks for the tip, but I'm
Thanks for the tip, but I'm in Norway so Ukraine is far away.
MineCooky
MineCooky's picture
I would recomment to bring
I would recomment to bring the smart to the next smart/mercedes dealer. Simply to confirm if we are right and to get feedback if maybe the pay for the new battery, it's worth a try.
They guy in Ukraine only needs to reset the BMW, that's small enough that you can send it via DHL. Opening and recharging the cells isn't too hard, somebody near you should be able to do that.
Roald Nakstad
Towing and regenerate?
Yes, first thing after holidays is tho bring it to the local Smart-dealer. But i'm afraid their conclution is damaged hv battery and no warranty. And a new one cost way over the cars value..
So most likely ending up trying to fix this by myself. And someone on other forum-posts has sugested that by towing the car it is possible to regenerate power so the cells are charged over minimum again without disassembling it. But stil BMS need to be reset i supose?
gtwibell
I would suggest spending some
I would suggest spending some time reading the 451ED threads on the smartcarofamerica.com group forum. You will need to sign up. There were many 451EDs sold in the US and there is much discussion around failed HV batteries. https://www.smartcarofamerica.com/forums/smart-fortwo-electric-drive.170/
MineCooky
MineCooky's picture
Towing the smart won't work
Towing the smart won't work as the smart is not "turning on" the battery any more. Nether for charging, nor for driving.
Did I get that right?
You are in holidays. So how did you notice it won't charge anymore?
Personally, I would bring it right now to the dealer to confirm the error and check if they are going to repair it for free. Somethimes they are quiet generous with US-imports. Also, if it's confirmed, that they aren't going to fix it for free, you should start recharging the cells now. They won't get any better, if you wait for them to discharge even more...
Roald Nakstad
By holiday I ment easter
By holiday I ment easter weekend and everything is closed. In Norway It starts now and last to next wednesday. So there vill be another week before I can bring it to them. I have put a external charger on 12V battery, just ensure that the 12V battery isn't draining the hv battery even more. The lowest cell reads now 2.933V...
NYEngineer
NYEngineer's picture
Towing the smart won't work ?
Why wouldn't it work for recharging the battery? What do you think regen does when you are coasting and or put on the brakes? I beleive I did read somewhere that towing over a certain speed and time was not recommended as it would and could over heat the battery. I think I may have read 30mph max towing speed? Anyhow if you have a good 12 volt battery and towing the car for a short distance, you should see some kind of results. I know when I am going down a long steep hill, I can see about a needle width of increase of available charge. You should hopefully see simular results. Keep us posted.
Roald Nakstad
Contactors
Not sure but i think when BMS decide that HV battery is malfunctioning, it will not engage the HV contactors(relays), and there is no connection where current can flow to/from the battery.
But perhaps turning ignittion on/off repeatedly during towing might work, since the connectors seems to be engaged for a second or two when ignition is turned on?
Roald Nakstad
*W*A*R*N*I*N*G*
I have been reading through logs from ovms since I last parked 2020-03-11 19:04:36 and did some interesting findings:
To keep the car awake an able to monitor it I have been using the ignition on/off function often, also to ensure that 12V battery was OK, since there are a lot of warnings about dead 12V batteries.
But since I have increased the ignition timer to 10 mins, the total time with ignition on is summed up to be for hours I realised now :-(
That was my first stupidity, but it didn't stop there because I received the first Alert:
2020-04-02 20:03: 5844899 A  Voltage: SD=9mV !30:-63mVTemperature: SD=0.2C OK
Without knowledge of the seriousity of this, I continued to turn ignition on/off, until I was not able to bring up the hv meter in ovms dashboard.
I was just focusing on that high voltage meter, and since it was in middle of yellow, far from red, I thaught there would be no harm yet, until:
2020-04-07 16:06:0559501A  Voltage: SD=65mV !1:-119mV !2:-99mV !3:-50mV !4:-288mV !29:-52mV !30:-426mV !31:-129mV !63:-203mV !64:-87mVTemperature: SD=0.8C OK
Then the needle did not stay, only pike up to yellow and down and ignition was automatically immediately turned off. I understood that charging now was needed.
But it was too late. Now I'm unable to charge, and the dash brings up message about engine disabled when ignition turned on.
SO TO OTHER READERS, THIS IS A WARNING: DONT LEAVE IGNITION ON WHEN HV BATTERY IS LOW/NEARLY AT ZERO. YOU COULD END UP BRICKING YOUR HV BATTERY!!
EVEN WITH MIDLE HIGH VOLTAGE IN THE YELLOW AND RealSOC ABOVE 5%, GET IT CHARGED!!
(I still do have a little hope that this is a security function that is turned on to prevent permanent battery damage caused by discharging, and the Smart-dealer might be able to bring it allive again..)
gtwibell
I do not know if this is
I do not know if this is useful information or not. When my HV battery failed the car was at the main dealers for a service and investigation for a phantom six amp discharge of the 12v battery. When I left the car at the dealer it had around 35% SOC remaining. The next day they ran diagnostics and phoned me to report HV and 12v battery failures, and a module which had also failed - I'm guessing the DC/DC converter which must have been causing the phantom discharge of the 12v battery. I reckon they felt obliged to replace the batteries as the car was in their care when it went wrong.
Roald Nakstad
I got the car scanned with
I got the car scanned with Bosh ESI Tronic diagnose. There were multiple errorcodes on warious components, (Engine, charger, HV battery, steering assistance++) many of them about problem with CAN-bus (?). I was able to erase all but two on the HV-battery: U01A2FA and P0DE6FB. First one is about CAN-bus and the other low cell voltage. They return immediately when trying to start charging. I'm preparing dismantling HV battery now for cell by cell recharge.
gtwibell
This thread will help you I
JMK2020
Attention your are close to problems but you have a chance
I would tell you you have not to run in danger.
First of all you not have the Deep unload case which needs the the P18051C issue, but you need aware what you are doing.
Home you did not make mor damage then initial.
First of all you need to have a running 12V Supply all the time when you try to bring the batterie up.
You need fast, otherwise the Cellmanagment will kill your Batterie stacks in reality and you really run in the BMS issue.
In my understanding if you not reach the status that a lot of cells get unloaded and dem CMS is switched of the BMS would set failure but not set P18051C which cause the big issue.
A smart repare shop should have the possibility to aktivate a emergency charge procedure, which allow to recarge the battery without take it out or open it.
So think twice what you are dowing. The CAN Bus failure come from the connect of the OVMS to the system. they are resetable.
Only the  PODE6FB is an issue and this could overdriven in the diagnostic mode. By this your Contactor of the Battery could be closed and the Charger should work in lowest power mode.
IF you really need to open it pay attention where you connect to the cells. there is a currentsensor close to the BMS linked by a LIN bus. if the BMS is not powered a current flowing over this sensor cause damage to the device.
Roald Nakstad
12V or not ?
JMK2020 - thanks for good advices :-) I'm a little confused about the 12V. Others is advicing me to disconnect 12V completely, to prevent damage to HV-battery (?!). I first put on a 12V maintenance charger, but now i totaly dissconnected it. Should I connect it again? How quick will the Cellmanagment kill the Batterie stacks if no 12V applied?
And to the U01A2FA CAN-bus issue. My OVMS is now disconnected but stil unable to erase it with Bosch ESI-tronic.But maybee a MB/Smart-dealer will do?
I agree with you; It make sense there is a inbuildt security-feature that shuts off HV-battery when deep discharge and one/some cells go dangerous low to prevent even more damage. And to get out of this 'lockdown' only a MB/Smart-dealer can get it fixed.
gtwibell
Disconnecting the 12v battery
Disconnecting the 12v battery will most certainly kill the HV battery for good. This is believed to be a safety precaution for when cars finish up in a junkyard. The first thing junkyard operators do when they get a car is remove the 12v battery.
JMK2020
Good statement. I read this
Good statement. I read this also, but i could not believe because if the car is parked for several time the KL15 is switched off, which means the BMS controller should be in off either.
If there is no communication to the cell management the work for them alone. But the not start the balancing never the less the drain some minor current from the cells.
this happen independed to the supply of the BMS part of the battery.
In my view the wear out of the 12V battery and the soc 0% HV  battery cause the additional access and discharge of the cells.
JMK2020
12V or not 12V is the question :-)
OK if you run low with the 12V, it seems to me the BMS trigger during wearout time by time the cellmanagement with uncharge the HV cells. If the cells run as low they not switch offe cellmanagement will kill the battery even further. So worst seems to be an half charged or damaged battery.
For sure if there is no 12V the bms would not work and could not trigger the cellmanagement. Never the less the cellmanagement will empty the cells.
So should not wait rescue your battery before you get the P18051C, because then you need to replace it and send your BMS to repairshop if you have no access to somebody which could flash the firmware new to reset the failure memory in parallel. The P18051C could not be reset with normal failure reset procedure.
To be honest i do not know what the cellmanagement would do in the meantime the 12V battery is totally of. in my view the wearout cause the discharge of the HV cells till the cells go too deep.
If you plan not to by a replacement in case of emergency and what open the battery, then also be fast to charge the single cells to minimum and afterward install it fast in the car again to reset the BMS after powerup and charge to nominal value.
Some approach tried to load the whole stacks. If you do this and pay attention to the current sensor you run in the problem, that the cms do not make a balancing and the good cells get to full. there is also a failure cells to high. then you need to uncharge them without drive the low to deep. Challanging
Try to speak to a dealer if he can rescue your battery fast without let it run deeper. if he only wand exchange the battery take it fast home open the batterie und load the empty chells.
If you get a P18051C then every thing get very expensive.
Roald Nakstad
Tear apart tomorow or wait 4 days until dealer opens at tuesday?
So, instead of tearing apart HV battery tomorow an start charging cell by cell, it wont get unreversible in 4 days until tursday when the MB/Dealer first opens again? My 12 V battery has never, I repeat, NEVER been flat. Thats not the root cause of my problem like many others. So for now, should I connect it again an hook up a 12V charger until or is it best to continue have it completely dissconnected for 4 days?
JMK2020
Rescue the HV Battery
OK your problem has another root case as usual of the long time without charging but now the question is how safe your HV battery.
First of all when switched on your ignition, and load the whole system to the 12V bus, in the same moment when the ignition was on, the BMS controller activate the DC/DC Charger which supply at least 200W even in standby to the 12V battery. If some more loads are active, there will a higher power flow from HV Battery via DC/DC converter to the 12V bus.
I am not sure but normaly the drive funkction will slow down and on the empty point you could have a last start ignition to rescue the car from danger situations on road for a few 100m, and than you can't drive anymore. But never the less the main contactor would be switched on and discharge the 200w for the DC/DC converter as the ignition is on.
Ths cause the discharge of the HV battery below normal minimal charge value.
If you go on you come to the point the BMS will stop by some cells will be below the lower threshold. This cause your situation.
At moment you could not pass the HV main contactor in both direction.
The cellmanagement will discharge your cells ongoing.
So for me the solution must be pay attention your 12V battery is connected and charged external and don't switch on ignition because this will cause a additional load on the battery.
Did you check the posibility to be already connected to wallbox and then reset plugged the failure codes in the BMS? AS i know if there is a current flowing the contactor is only opend in emergency case, so maybe this will short close the contacts and allow to switch on the charger.
Also i am the opinion that it is possible to switch the contactor in diagnostic mode with xentry if a P18051C is not yet active.
So what are the options. I do not believe that the cells will get empty without load within 4 days that you reach 2,5V of the lowest cell. Even then it is not real a problem to slowly charge the cell to minimum to start the charger. The big problems are if you have several cells close to 0V and the stack switch of the cellmonitoring this seems to me one reason for a P18051C.
I would wait and prepare everything in case they could not help. Only risk would be the possible P18051C. This will cause the action with the difficult reset procedure.
Connect a full battery and hold it charged that the KL30 is always ok. My personal opinion without any garanty.
Roald Nakstad
1.5V the point of no return?
I found this:  https://batteryuniversity.com/learn/article/low_voltage_cut_off
..'Do not boost lithium-based batteries back to life that have dwelled below 1.5V/cell for a week or longer.'..
So to me it sounds like there is good chanse for getting it back to life as my lowes cell is 2,7V now.
JMK2020
Point oft difficult return
Hey,
the guys in Aschaffenburg (batteryuniverse) talk about cells in general. When you check the details von the ED3 battery there are some nice descriptions in the web which show even a rescue Form close to 0V. But this could be an issue von the performance of the cell. Also the P18051C failure code is a major issue. So be fast before it get deeper.
It is all a question of additional effort which will be needed in other case.
So the battery git from beyond 3V to 2.7V without 12Volt connected. Maybe you could check the status also in a few hours with 12V connected and can report. This will bring the resultiert what is Bettler for HV in this case.
Roald Nakstad
Car at workshop now
Hi all
Got transport to a workshop with the right equipment today. The battery will be removed tomorow. It is now resting with 12V disconnected. Temperature in workshop is 18-20c. Here in Norway the outside temp is 3-4c. How is this temperature rise affecting cell voltage?
JMK2020, I found you in a German forum. My username there is kaNor. Trying to send you a PM there.
JMK2020
Communications shifted AS here no PNs possible
Results will be played back.
But the 1.5v is not the big Problem. If one of your stacks getting too low, Moore failure occur which are not as easy to reset.
Before you run into P18051C which seems very difficult for the most.
Roald Nakstad
Update
HV Battery disassembled today. Disconnected current sensor lead. 6 cells below 3,2v charged to 3,3v. The lowest was 2,438v messaured with OVMS just before starting dismounting. Still no errorcode P18051C. So there is hope ;-) Will give new update after assembling and test tomorrow.
JMK2020
Great news
Real great news.
Hope the current sensors survive but if you charge the single cells there should no reason for a damage. Only if you charge with current over the sensor, i am the opinion to pull the connector would not help not rescue it. But there are too less information about the damage von the device and rootcause available.
We will see. Cross the fingers for you.
You would be the first lucky guy which catch the rootcause before you got in bigger trouble.
Hope you have documented the tasks. This would help a lot after you facing similar situatuons.
I discuss with Dimitrie an approach for a integration of OVMS without OBD.
Wie will see if there is soon an branch in this direction. At moment my OVMS seems to have an issue. Rebooting failure, no start of the GPS and GSM. Crazy but as challenging as your tasks.
Roald Nakstad
YEEEESSSS!!! :-D
My smart is charging again!! It has raiset from death ;-D Thanks to all giving me advices. Spesial thanks to GoSmart Service in Ukrainia who has answered all my questions on WhatsApp during the hole weekend. They know what they are talking about ;-)
JMK2020
Great success
Hi Roald,
after install of the battery again, you need to delete the P0DE6FB and any thing was ok?
Or did you need to do additional actions? P18051C was never appearing, great.
Could you share some pictures and more information of your steps you have done?
You should start some balancing cycles to bring your system in good shape again. It seems to me the few cells which run in deep discharge should be become closer to the whole stack again.
Seems my messages to you are not pass the allowence in the GE Forum. you should accept ingoing PNs :-)
gtwibell
Roald,
Roald,
Many congratulations on reviving your Smart ED battery. It gives us some hope that there is a fix and we don't have to junk our cars if the battery fails.
I am so pleased for you to hear this news.
Roald Nakstad
Cell balancing
Hi again
Does anybody know for sure how cells balancing is performed? Stay connected to the mains at 100% SOC, or drive below 20% and do a full charge to 100% for a cupple of times?
What is the upper cell voltage limit? Does charging automatically stop before cell voltage go to high and cells get damaged now that my cells are not balanced?
I stopped charging at SOC 98% when OVMS gave me alert of V-deviation over 50mV , and then the highest cell was 4.211V  (!?)
Answers::
The error-codes U01A2FA and P0DE6FB both was reset autamatically after 6 cells below 3,2V was individual charged to 3,3V and HV-battery remountet into car.
I have taken some pictures during the process. Planning to share those on Google disk and write down som tips into a document. So stay tuned ;-)
JMK2020
Balancing
Hello Roald,
seems my last answer get lost. i also answered you by PN in the GE forum.
To trigger the measurement of the capacity process, it is a little bit special for ED3. You need to discharge below 20% SoC and let you car without charging for at least 30 min.
After you could plug in and the system will start a new capacity measurement cycle.. This could be on reason for the special values below.
Balancing will always be done if you plugged in and charge, otherwise the balancing could you not prevent for upper cell damage :-)
So the battery will stop charging or slow down if on cell reach the upper limit.
This sometimes cause the wrong idea of charger defect.
It also depend on the charger. Do you own a 3,6 KW or 22KW charger. If you use the 22KW, this cause some issues with the balancing if you often charge short and not let the balancing circuit work.
So better to run a full cycle from below of 20% SoC with limited charging current or better 3,6 KW charger kabel. This will allow the system to balance in a better way.
Reason for this is the very easy implementation within the SMART ED3. If one of the cells goes to high, in parallel a resistor will be switched on. Never the less the charging current of a 22KW charger push much faster energy into the battery. So the system switch of before  all cells are full. This is also the reason the 22KW charger reconfigurate internally and reduce the current.
So slow charging will help to not let the cells drift too much from each other. Never the less if there is one cell with les capacity this will define the overall capacity as the car need normally to switch off in 3,2V threshold. (If not you let the ignition on allowing to pull the heater to empty the HV-Battery and after the DC/DC converter pull 200W to empty the HV battery below threshold;-) Lessons learned :-))
Roald Nakstad
Best charging: Lowest current and keep it connected?
So for best battery health;
Drive to slighly below 20% SoC.
Park for min. half hour.
Start charging and at lowest current awailable. (My charging cable has 6A as minimum.)
Let charging cable stay connected to the mains also after 100% SoC.
Seems ok?
JMK2020
Let the balancing work
Yes,
but with this approach you also trigger the BMS internal calculation of the available Battery capacity. Sometime to charge slowly will help the BMS and CMS to do let their balancing work do. Do this 1-2 times after your event and you will get some feedback about your cell capacity.
Roald Nakstad
BUG IN OVMS ??
I see now that OVMS 'bms status' reports 0.1V higher cell voltage than 'xse bsmdiag'
Whitch is correct ?
OVMS# bms status
Voltage:
    Average: 4.142V [4.106V - 4.182V]
  Deviation: SD   9.59mV [max 11.27mV], 3 warnings, 0 alerts
Temperature:
    Average:   7.0C [  5.9C -   8.5C]
  Deviation: SD   0.89C  [max 1.06C], 0 warnings, 0 alerts
Cells:
  1 | 4.147V |   6.5C |
  2 | 4.147V |   8.5C |
  3 | 4.136V |   7.2C |
  4 | 4.173V |   6.0C |
  5 | 4.139V |   8.1C |
  6 | 4.141V |   6.4C |
  7 | 4.129V |   5.9C |
  8 | 4.140V |   7.6C |
  9 | 4.128V |   6.3C |
 10 | 4.130V |  -0.0C |
 11 | 4.137V |   1.0C |
 12 | 4.139V |  -0.0C |
 13 | 4.142V |   2.0C |
 14 | 4.136V |   0.0C |
 15 | 4.140V |   6.5C |
 16 | 4.141V |   8.5C |
 17 | 4.142V |   7.2C |
 18 | 4.141V |   6.0C |
 19 | 4.141V |   8.1C |
 20 | 4.134V |   6.4C |
 21 | 4.135V |   5.9C |
 22 | 4.139V |   7.6C |
 23 | 4.140V |   6.3C |
 24 | 4.136V |  -0.0C |
 25 | 4.139V |   1.0C |
 26 | 4.133V |  -0.0C |
 27 | 4.141V |   2.0C |
 28 | 4.136V |   0.0C |
 29 | 4.106V |   6.5C |
 30 | 4.182V |   8.5C |
 31 | 4.144V |   7.2C |
 32 | 4.139V |   6.0C |
 33 | 4.140V |   8.1C |
 34 | 4.145V |   6.4C |
 35 | 4.147V |   5.9C |
 36 | 4.150V |   7.6C |
 37 | 4.144V |   6.3C |
 38 | 4.145V |  -0.0C |
 39 | 4.146V |   1.0C |
 40 | 4.140V |  -0.0C |
 41 | 4.142V |   2.0C |
 42 | 4.147V |   0.0C |
 43 | 4.148V |  -0.4C |
 44 | 4.148V |   1.6C |
 45 | 4.147V |   0.3C |
 46 | 4.145V |  -1.0C |
 47 | 4.145V |   1.1C |
 48 | 4.142V |  -0.6C |
 49 | 4.149V |  -1.1C |
 50 | 4.146V |   0.6C |
 51 | 4.148V |  -0.6C |
 52 | 4.148V |  -0.0C |
 53 | 4.147V |   1.0C |
 54 | 4.147V |  -0.0C |
 55 | 4.146V |   2.0C |
 56 | 4.146V |   0.0C |
 57 | 4.146V |   0.0C |
 58 | 4.147V |   0.0C |
 59 | 4.144V |   0.0C |
 60 | 4.136V |   0.0C |
 61 | 4.142V | 68169720922112.0C |
 62 | 4.143V | -169296593500958770697728504251457470464.0C |
 63 | 4.162V |   1.0C |
 64 | 4.112V |  -0.0C |
 65 | 4.112V |   2.0C |
 66 | 4.143V |   0.0C |
 67 | 4.142V |   1.0C |
 68 | 4.146V |   1.0C |
 69 | 4.142V |   0.0C |
 70 | 4.144V | 71859503208318044733440.0C |
 71 | 4.143V | 264479218549703835648.0C |
 72 | 4.146V | 71561207286999159930880.0C |
 73 | 4.146V |   0.0C |
 74 | 4.146V |   1.0C |
 75 | 4.146V |   0.0C |
 76 | 4.145V | 71430716706035219338123284578304.0C |
 77 | 4.141V | 18178671951207061558369630289920.0C |
 78 | 4.141V |   1.0C |
 79 | 4.148V |   0.0C |
 80 | 4.141V |   2.4C |
 81 | 4.148V |   0.0C |
 82 | 4.142V |   0.0C |
 83 | 4.141V |   0.0C |
 84 | 4.141V |  -0.0C |
 85 | 4.138V |   1.0C |
 86 | 4.142V |  -0.0C |
 87 | 4.144V |   2.0C |
 88 | 4.133V |   0.0C |
 89 | 4.145V |   1.0C |
 90 | 4.135V |   1.0C |
 91 | 4.140V |   0.0C |
 92 | 4.137V | 71859503208318044733440.0C |
 93 | 4.118V | 71426891664741958651414514237440.0C |
OVMS# xse bmsdiag
Time [hh:mm]: 11:20,   ODO : 24324km
Battery Status   : DEGRADED: 00110011
SOC : 92.0%, realSOC: 82.0%
HV  : 377.1 V, -0.70 A, -0.26 kW
LV  : 14.4 V
CV mean :  4142 mV, dV = 11.27 mV
CV min  :  4106 mV
CV max  :  4182 mV
OCVtimer: 20057 s
Last measurement      : 25 day(s)
Actual estimation     : 0.404
HV contactor state ON, low current: 3 s
Cycles left   : 289841
DC isolation  : 65534 kOhm, OK
module 1: 6.5, 8.5, 7.2
module 2: 6.0, 8.1, 6.4
module 3: 5.9, 7.6, 6.3
   mean : 7.0, min : 5.9, max : 8.5
coolant : 5.1
 # ;mV   ;As/10
  1; 4048; 14610
  2; 4048; 14610
  3; 4037; 14863
  4; 4074; 14129
  5; 4040; 17265
  6; 4042; 17301
  7; 4030; 17372
  8; 4041; 17229
  9; 4029; 17372
 10; 4031; 17408
 11; 4038; 17301
 12; 4040; 17408
 13; 4043; 17408
 14; 4037; 17265
 15; 4041; 17301
 16; 4042; 17301
 17; 4043; 17408
 18; 4042; 17408
 19; 4042; 17372
 20; 4035; 17408
 21; 4036; 14863
 22; 4040; 17408
 23; 4041; 17408
 24; 4037; 17372
 25; 4040; 17301
 26; 4034; 17408
 27; 4042; 17408
 28; 4037; 17408
 29; 4007; 14900
 30; 4083; 13932
 31; 4045; 14575
 32; 4040; 14975
 33; 4041; 14975
 34; 4046; 17301
 35; 4048; 17229
 36; 4051; 17301
 37; 4045; 17265
 38; 4046; 17408
 39; 4047; 17265
 40; 4041; 17408
 41; 4043; 17408
 42; 4048; 17408
 43; 4049; 17301
 44; 4049; 17408
 45; 4048; 17301
 46; 4046; 17336
 47; 4046; 17265
 48; 4043; 17372
 49; 4050; 17408
 50; 4047; 17408
 51; 4049; 17408
 52; 4049; 17444
 53; 4048; 17408
 54; 4048; 17408
 55; 4047; 17301
 56; 4047; 17265
 57; 4047; 17301
 58; 4048; 17265
 59; 4045; 14937
 60; 4037; 17194
 61; 4043; 17229
 62; 4044; 14975
 63; 4063; 14229
 64; 4013; 17194
 65; 4013; 14975
 66; 4044; 17301
 67; 4043; 17229
 68; 4047; 17372
 69; 4043; 17229
 70; 4045; 17301
 71; 4044; 17229
 72; 4047; 17229
 73; 4047; 17229
 74; 4047; 17408
 75; 4047; 17229
 76; 4046; 17265
 77; 4042; 17301
 78; 4042; 17408
 79; 4049; 17301
 80; 4042; 17444
 81; 4049; 17372
 82; 4043; 17517
 83; 4042; 17444
 84; 4042; 17408
 85; 4039; 17408
 86; 4043; 17444
 87; 4045; 17336
 88; 4034; 17372
 89; 4046; 17229
 90; 4036; 14975
 91; 4041; 17159
 92; 4038; 17124
 93; 4019; 17159
CV mean : 4043 mV, dV= 76 mV, s= 9.59 mV
CV min  : 4007 mV, # 29
CV max  : 4083 mV, # 30
JMK2020
Any update?
Hi Roald,
any update on your story..
We try to identify how fast the HV battery get empty. Also the number of left contactor operation would be interesting between your ovms read out approaches.
Roald Nakstad
Description with pictures
High all
Finaly got some spare time to make a document with pictures that describe how I did recover the HV-battery.
Here is link to the google doc: https://docs.google.com/document/d/1F7XOSEJQZX2qtZLliR7thsWDvq9FPbdtNUiz4YzOvp0/edit?usp=sharing
I hope you understand my 'Norwegianenglish' ;-)
br
kaNor
JMK2020
Really nice work
Yes we understand you Nowegianenglish very well. :-)
When i use my mobile the German auto correction introduce time by time really crazy wordings :-)
I will take you link an forward it into the German forum as a best practice to rescue your car.
Looking forward for the reports on the BMSDIAG on the improved status of your battery. Some slow charging approaches giving the balancing circuit the change to work will hopefully help.
BR
Jochen
P.S: Please take my details in the german forum in the PNs you not read till now :-)
Roald Nakstad
DEGRADED ??
Hi again
After 3 full slow (6A) charge-cycles, cells have got better balance and seems in good shape. OVMS status says SOH 94.9%, the highest I ever has seen :-)
Anybody who knows what battery status: DEGRADED: 00111011 means?
It have always reported degreaded, also before my deep discharge episode. Does it have someting to do with poor estimation factor? Has cold weather something to say?
OVMS# xse rptdata
---       Battery Status Report       ---
Time [hh:mm]: 11:42,   ODO : 24511km
Battery Status   : DEGRADED: 00111011
Battery verified   [Y/M/D]: 2013/7/17
realSOC          : 96.0%
SOC              : 99.5%
Charged capacity : 49.4 Ah, min. Cell# 30
BMS estimate     : 49.6 Ah, value @25degC
Measurement done : 0 day(s) ago
Estimation factor: 0.689, poor!
*** Don't trust and redo measurement! ***
OCV timer        : 21548 s, @8.2 degC
OCV state        : HV ON, can't meas. OCV
DC isolation     : 65534 kOhm OK
OVMS# xse bmsdiag
SOC : 99.5%, realSOC: 96.0%
HV  : 10.5 V, 0.00 A, 0.00 kW
LV  : 12.2 V
CV mean :  4233 mV, dV = 4.40 mV
CV min  :  4210 mV
CV max  :  4236 mV
OCVtimer: 21548 s
Last measurement      : 0 day(s)
Measurement estimation: 0.689
Actual estimation     : 0.675
CAP mean: 18531 As/10, 51.5 Ah
CAP min : 17857 As/10, 49.6 Ah
CAP max : 18926 As/10, 52.6 Ah
HV contactor state ON, low current: 5 s
Cycles left   : 289799
module 1: 7.6, 8.8, 8.4
module 2: 7.5, 8.8, 8.1
module 3: 7.5, 8.7, 8.2
   mean : 8.2, min : 7.5, max : 8.8
coolant : 6.9
 # ;mV   ;As/10
  1; 4134; 18018
  2; 4135; 18242
  3; 4136; 18300
  4; 4136; 17908
  5; 4136; 18502
  6; 4136; 18561
  7; 4134; 18531
  8; 4135; 18679
  9; 4134; 18473
 10; 4134; 18620
 11; 4135; 18502
 12; 4134; 18531
 13; 4136; 18590
 14; 4136; 18502
 15; 4134; 18444
 16; 4135; 18620
 17; 4136; 18561
 18; 4134; 18531
 19; 4137; 18502
 20; 4136; 18620
 21; 4136; 18415
 22; 4135; 18590
 23; 4136; 18679
 24; 4136; 18531
 25; 4135; 18590
 26; 4134; 18531
 27; 4136; 18620
 28; 4136; 18531
 29; 4114; 18502
 30; 4135; 17772
 31; 4136; 18046
 32; 4135; 18502
 33; 4136; 18444
 34; 4135; 18531
 35; 4136; 18590
 36; 4135; 18590
 37; 4136; 18649
 38; 4135; 18709
 39; 4136; 18620
 40; 4136; 18561
 41; 4135; 18561
 42; 4136; 18620
 43; 4135; 18649
 44; 4136; 18590
 45; 4136; 18444
 46; 4135; 18649
 47; 4137; 18620
 48; 4135; 18649
 49; 4137; 18590
 50; 4136; 18620
 51; 4136; 18739
 52; 4135; 18679
 53; 4136; 18739
 54; 4135; 18473
 55; 4134; 18473
 56; 4135; 18473
 57; 4136; 18502
 58; 4134; 18502
 59; 4135; 18415
 60; 4135; 18620
 61; 4134; 18415
 62; 4135; 18357
 63; 4134; 17880
 64; 4111; 18590
 65; 4113; 18531
 66; 4135; 18649
 67; 4137; 18620
 68; 4136; 18769
 69; 4135; 18531
 70; 4136; 18709
 71; 4134; 18561
 72; 4136; 18649
 73; 4134; 18620
 74; 4134; 18679
 75; 4136; 18620
 76; 4134; 18561
 77; 4135; 18531
 78; 4134; 18531
 79; 4137; 18649
 80; 4135; 18709
 81; 4136; 18769
 82; 4134; 18709
 83; 4137; 18709
 84; 4136; 18649
 85; 4135; 18649
 86; 4135; 18679
 87; 4135; 18649
 88; 4135; 18649
 89; 4135; 18649
 90; 4135; 18415
 91; 4135; 18415
 92; 4136; 18444
 93; 4122; 18590
CV mean : 4134 mV, dV= 26 mV, s= 4.31 mV
CV min  : 4111 mV, # 64
CV max  : 4137 mV, # 19
CAP mean: 18538 As/10, 51.5 Ah
CAP min : 17772 As/10, 49.4 Ah, # 30
CAP max : 18769 As/10, 52.1 Ah, # 68
Dimitrie
Hi,
Hi,
Please ignore the status degraded at the moment, we don't know what it actually means.
The battery looks pretty good.
To get a better measurement factor, drive under 20% soc. Then show under xse rptdata OVC State time how long you should wait before you start charge the battery to 100%.
A good measurement estimate factor is 0.8 and higher.
