4 posts / 0 new
rtw819
OVMS v3.3 USB Serial Port connection settings?
I'm connected via USB cable to the virtual device COM3 (based on Device Manager settings) to the OVMS board at 115.2K Baud, 8 Data bits, 1 Stop bit, No Parity, and I DO see messages coming across the console.  However, this appears to be read-only/display-only?  I have an OVMS> prompt, but my keypresses don't seem to be getting registered or seen by the OVMS board.  Is this serial interface a view only USB console interface??  Am I missing something obvious? There doesn't appear to be much out there on this topic.
Thanks in advance!
dexter
dexter's picture
rtw819
Thanks.  Yep, I had already
Thanks.  Yep, I had already figured out the 115.2kbaud rate and all, guessed at 8N1 (missing from the docs), and as I mentioned I even got the "OVMS>" prompt (via USB using PuTTY with the driver), but no outbound characters were being received/recognized/displayed and not being echoed by the unit.  I tried no flow control, and a few other flow control selections to no avail.  FWIW - I started out using 300 baud modems back before the internet was "cool" -- so I've learned a thing or two about serial ports over the years.  :)  The interface was just acting oddly (output only), and I wondered if anyone had experienced anything similar.
rtw819
Problem solved? (no action taken)
Not sure what might have happened, or why, but it's working now after a few reboots and having added an SD card.
