5 posts / 0 new
twinwalk
CFG LOAD #0: Failed: SDO access failed / Activating profiles not possible
Hi,
today i installed my OVMSv3.3 module in my 2012 Twizy (80kmh version), connected it to dexters-web.de and the basic stuff seems to work (Dashboards, Apps etc.).
Unfortunately the tuning of my twizy isn't working or maybe I just don't know what to do. What i have done is putting the key in "before GO" position, connecting to the local AP, activated write-support and changed the profiles (settings are shown in Browser in "Drivemode-View"). I think till this point everything works well, but when i've tried to activate the profile I will get this error "CFG LOAD #0: Failed: SDO access failed". The error is similar when i try to activate profile 1,2 or 3. Am I doing something wrong? I tried to activate the profile via SHELL but i'm struggling with the syntax and had no luck with that.
Has someone got an idea?
twinwalk
Some additional information
Some additional information from the log:
2023-08-03 18:48:02.815 GMT I (31930695) webserver: HTTP POST /xrt/drivemode
2023-08-03 18:48:02.815 GMT I (31930695) v-twizy: CfgSwitchProfile: key=1
2023-08-03 18:48:02.815 GMT D (31930695) v-twizy: Sevcon login request: 1
2023-08-03 18:48:02.825 GMT V (31930705) canopen: ReadSDO: can1 node=1 adr=1018.02
2023-08-03 18:48:02.825 GMT V (31930705) canopen: ReadSDO result: OK
2023-08-03 18:48:02.825 GMT D (31930705) v-twizy: Twizy type 0 = Twizy80
2023-08-03 18:48:02.825 GMT V (31930705) canopen: ReadSDO: can1 node=1 adr=5000.01
2023-08-03 18:48:02.835 GMT V (31930715) canopen: ReadSDO result: OK
2023-08-03 18:48:02.835 GMT D (31930715) v-twizy: Sevcon login status: 1
2023-08-03 18:48:02.845 GMT V (31930725) canopen: WriteSDO: can1 node=1 adr=2920.01
2023-08-03 18:48:02.845 GMT D (31930725) events: Signal(vehicle.ctrl.loggedin)
2023-08-03 18:48:02.865 GMT D (31930745) canopen: WriteSDO #1 0x2920.01: InitDownload failed, CANopen error code 0x08000000
2023-08-03 18:48:02.865 GMT V (31930745) canopen: WriteSDO result: SDO access failed; General error
2023-08-03 18:48:02.865 GMT V (31930745) canopen: ReadSDO: can1 node=1 adr=5310.00
2023-08-03 18:48:02.885 GMT V (31930765) canopen: ReadSDO result: OK
2023-08-03 18:48:02.885 GMT D (31930765) v-twizy: Sevcon WriteSDO 0x2920.01 failed: SDO access failed; No error
And some details regarding my OVMS:
Last boot was 31715 second(s) ago
Time at boot: 2023-08-03 09:55:53 GMT
This is reset #0 since last power cycle
Detected boot reason: PowerOn (1/14)
Reset reason: Unknown/unset (0)
Crash counters: 0 total, 0 early
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
Firmware: 3.3.003/ota_0/main (build idf v3.3.4-848-g1ff5e24b1b Sep 3 2022 11:32:12)
Running partition: ota_0
Boot partition: ota_0
Factory image: 3.3.001-33-g58d01654
OTA_O image: 3.3.003
dexter
dexter's picture
That's typical for a locked SEVCON. Check the SEVCON firmware version:
https://docs.google.com/spreadsheets/d/1rDZG5xdG1586_4EUU1bMjicZremXJFHSDVT0XqJNtJY/edit?usp=sharing
Maybe the SEVCON was replaced for repair.
twinwalk
thanks for that quick
thanks for that quick response. Will check tomorrow
twinwalk
too bad….
Serialnumber: 2084860345
Devicename:  'Gen4 (Renault Twizy)Thu Jun 30 18:21:36'
HW: 0x00000103
SW: 0712.0003
So i have to stay with that…
