Hi,
today i installed my OVMSv3.3 module in my 2012 Twizy (80kmh version), connected it to dexters-web.de and the basic stuff seems to work (Dashboards, Apps etc.).
Unfortunately the tuning of my twizy isn't working or maybe I just don't know what to do. What i have done is putting the key in "before GO" position, connecting to the local AP, activated write-support and changed the profiles (settings are shown in Browser in "Drivemode-View"). I think till this point everything works well, but when i've tried to activate the profile I will get this error "CFG LOAD #0: Failed: SDO access failed". The error is similar when i try to activate profile 1,2 or 3. Am I doing something wrong? I tried to activate the profile via SHELL but i'm struggling with the syntax and had no luck with that.
Has someone got an idea?
Some additional information from the log:
2023-08-03 18:48:02.815 GMT I (31930695) webserver: HTTP POST /xrt/drivemode
2023-08-03 18:48:02.815 GMT I (31930695) v-twizy: CfgSwitchProfile: key=1
2023-08-03 18:48:02.815 GMT D (31930695) v-twizy: Sevcon login request: 1
2023-08-03 18:48:02.825 GMT V (31930705) canopen: ReadSDO: can1 node=1 adr=1018.02
2023-08-03 18:48:02.825 GMT V (31930705) canopen: ReadSDO result: OK
2023-08-03 18:48:02.825 GMT D (31930705) v-twizy: Twizy type 0 = Twizy80
2023-08-03 18:48:02.825 GMT V (31930705) canopen: ReadSDO: can1 node=1 adr=5000.01
2023-08-03 18:48:02.835 GMT V (31930715) canopen: ReadSDO result: OK
2023-08-03 18:48:02.835 GMT D (31930715) v-twizy: Sevcon login status: 1
2023-08-03 18:48:02.845 GMT V (31930725) canopen: WriteSDO: can1 node=1 adr=2920.01
2023-08-03 18:48:02.845 GMT D (31930725) events: Signal(vehicle.ctrl.loggedin)
2023-08-03 18:48:02.865 GMT D (31930745) canopen: WriteSDO #1 0x2920.01: InitDownload failed, CANopen error code 0x08000000
2023-08-03 18:48:02.865 GMT V (31930745) canopen: WriteSDO result: SDO access failed; General error
2023-08-03 18:48:02.865 GMT V (31930745) canopen: ReadSDO: can1 node=1 adr=5310.00
2023-08-03 18:48:02.885 GMT V (31930765) canopen: ReadSDO result: OK
2023-08-03 18:48:02.885 GMT D (31930765) v-twizy: Sevcon WriteSDO 0x2920.01 failed: SDO access failed; No error
And some details regarding my OVMS:
Last boot was 31715 second(s) ago
Time at boot: 2023-08-03 09:55:53 GMT
This is reset #0 since last power cycle
Detected boot reason: PowerOn (1/14)
Reset reason: Unknown/unset (0)
Crash counters: 0 total, 0 early
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
Firmware: 3.3.003/ota_0/main (build idf v3.3.4-848-g1ff5e24b1b Sep 3 2022 11:32:12)
Running partition: ota_0
Boot partition: ota_0
Factory image: 3.3.001-33-g58d01654
OTA_O image: 3.3.003
That's typical for a locked SEVCON. Check the SEVCON firmware version:
https://docs.google.com/spreadsheets/d/1rDZG5xdG1586_4EUU1bMjicZremXJFHSDVT0XqJNtJY/edit?usp=sharing
Maybe the SEVCON was replaced for repair.
thanks for that quick response. Will check tomorrow
Serialnumber: 2084860345
Devicename: 'Gen4 (Renault Twizy)Thu Jun 30 18:21:36'
HW: 0x00000103
SW: 0712.0003
So i have to stay with that…
