3 posts / 0 new
hksoftware
SoC and other data not updating
Hi,
I installed OVMS into my MG Zs EV a couple of days ago and followed the install instructions carefully.
Since installing, SOC has showed 103% ever since, despite me using the car and charging it back up, SOC did not change. Status also stayed as "Not charging"
This morning after I stopped charging, I saw that SOC is now correctly showing 79%.
I have just put it back on charge, bit it is still showing 79% and status is "Not charging"
Within the app, the odometer seems to be correct (12k miles) and it say's it's live with good cell signal.
From what I can see, everything seems to be set up correctly.
The location seems to work fine, although at one point it started showing as China, but then corrected itself.
Both these screenshots were just taken whilst the vehicle is on charge:
Result of 'metrics list' command in the shell:
OVMS# metrics list
m.egpio.input                            0,1,2,3,4,5,6,7,8,9
m.egpio.monitor
m.egpio.output                           3,4,5,6,7,8,9
m.freeram                                3471108
m.hardware                               OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
m.monotonic                              56043Sec
m.net.mdm.iccid                          8944501207218870133
m.net.mdm.mode                           LTE,Online
m.net.mdm.model                          LE20B03SIM7600M21-A_CUS_JT
m.net.mdm.netreg                         RegisteredRoaming
m.net.mdm.network                        EE Hologram
m.net.mdm.sq                             -59dBm
m.net.provider                           REDACTED
m.net.sq                                 -86dBm
m.net.type                               wifi
m.net.wifi.network                       REDACTED
m.net.wifi.sq                            -85.6dBm
m.serial
m.tasks                                  17
m.time.utc                               1648469640Sec
m.version                                3.3.002/ota_0/main (build idf v3.3.4-848-g1ff5e24b1b Mar  7 2022 07:33:16)
s.v2.connected                           yes
s.v2.peers                               1
s.v3.connected
s.v3.peers
v.b.12v.current
v.b.12v.voltage                          14.05V
v.b.12v.voltage.alert
v.b.12v.voltage.ref                      12.6V
v.b.c.temp
v.b.c.temp.alert
v.b.c.temp.dev.max
v.b.c.temp.max                           12,14,14,13,13,14,13,13,12°C
v.b.c.temp.min                           12,14,14,13,13,14,12,13,12°C
v.b.c.voltage
v.b.c.voltage.alert
v.b.c.voltage.dev.max
v.b.c.voltage.max                        3.993,3.996,3.991,3.991,3.995,3.991,3.992,3.993,3.995V
v.b.c.voltage.min                        3.985,3.984,3.88,3.986,3.987,3.986,3.987,3.985,3.987V
v.b.cac
v.b.consumption                          0Wh/km
v.b.coulomb.recd
v.b.coulomb.recd.total
v.b.coulomb.used                         0.020875Ah
v.b.coulomb.used.total
v.b.current                              0A
v.b.energy.recd
v.b.energy.recd.total
v.b.energy.used                          0.00944594kWh
v.b.energy.used.total
v.b.health
v.b.p.level.avg
v.b.p.level.max
v.b.p.level.min
v.b.p.level.stddev
v.b.p.temp.avg
v.b.p.temp.max                           14°C
v.b.p.temp.min                           12°C
v.b.p.temp.stddev
v.b.p.temp.stddev.max
v.b.p.voltage.avg
v.b.p.voltage.grad
v.b.p.voltage.max                        3.996V
v.b.p.voltage.min                        3.88V
v.b.p.voltage.stddev
v.b.p.voltage.stddev.max
v.b.power                                0kW
v.b.range.est                            179.4km
v.b.range.full                           263km
v.b.range.ideal                          207.813km
v.b.range.speed
v.b.soc                                  79.0164%
v.b.soh                                  96.04%
v.b.temp                                 14°C
v.b.voltage                              431V
v.c.12v.current
v.c.12v.power
v.c.12v.temp
v.c.12v.voltage
v.c.charging                             no
v.c.climit                               35.2A
v.c.current
v.c.duration.full                        0Min
v.c.duration.range                       0Min
v.c.duration.soc                         0Min
v.c.efficiency
v.c.kwh
v.c.kwh.grid
v.c.kwh.grid.total
v.c.limit.range                          0km
v.c.limit.soc                            95%
v.c.mode                                 standard
v.c.pilot                                no
v.c.power
v.c.state                                stopped
v.c.substate
v.c.temp
v.c.time                                 0Sec
v.c.timermode
v.c.timerstart
v.c.type                                 undefined
v.c.voltage
v.d.cp                                   no
v.d.fl
v.d.fr
v.d.hood                                 no
v.d.rl
v.d.rr
v.d.trunk
v.e.alarm
v.e.aux12v                               yes
v.e.awake                                yes
v.e.c.config
v.e.c.login                              no
v.e.cabinfan
v.e.cabinintake
v.e.cabinsetpoint                        22°C
v.e.cabintemp                            11.7°C
v.e.cabinvent
v.e.charging12v                          yes
v.e.cooling                              no
v.e.drivemode                            1
v.e.drivetime                            0Sec
v.e.footbrake                            0%
v.e.gear
v.e.handbrake                            no
v.e.headlights
v.e.heating
v.e.hvac                                 no
v.e.locked                               yes
v.e.on                                   no
v.e.parktime                             75412Sec
v.e.regenbrake
v.e.serv.range
v.e.serv.time
v.e.temp                                 12°C
v.e.throttle
v.e.valet
v.g.climit
v.g.current
v.g.duration.empty
v.g.duration.range
v.g.duration.soc
v.g.efficiency
v.g.generating
v.g.kwh
v.g.kwh.grid
v.g.kwh.grid.total
v.g.limit.range
v.g.limit.soc
v.g.mode
v.g.pilot
v.g.power
v.g.state
v.g.substate
v.g.temp
v.g.time                                 0Sec
v.g.timermode
v.g.timerstart
v.g.type
v.g.voltage
v.i.efficiency
v.i.power
v.i.temp                                 18°C
v.m.rpm                                  0
v.m.temp                                 19°C
v.p.acceleration
v.p.altitude                             26.7m
v.p.direction                            0°
v.p.gpshdop                              1
v.p.gpslock                              yes
v.p.gpsmode                              AA
v.p.gpsspeed                             0km/h
v.p.latitude                             53.173
v.p.location
v.p.longitude                            -2.71581
v.p.odometer                             20502km
v.p.satcount                             11
v.p.speed                                0km/h
v.p.trip
v.t.alert
v.t.health
v.t.pressure                             288,280,284,260kPa
v.t.temp                                 21,21,21.5,21.5°C
v.type                                   MGA
v.vin                                    PW7CB3FKZ247176
xmg.auth.bcm                             no
xmg.state.gwm                            0
xmg.state.poll                           3
xmg.task.bcm                             0
xmg.task.gwm                             0
xmg.v.bat.coolant.temp                   13.5°C
xmg.v.bat.error                          0
xmg.v.bat.resistance                     8190.5
xmg.v.bat.voltage.bms                    431V
xmg.v.bat.voltage.vcu                    431V
xmg.v.bms.cell.voltage.max               3.996V
xmg.v.bms.cell.voltage.min               3.881V
xmg.v.bms.mainrelay.b                    yes
xmg.v.bms.mainrelay.g                    yes
xmg.v.bms.mainrelay.p                    yes
xmg.v.bms.time                           28/03/22 16:17:16
xmg.v.dcdc.load                          0%
xmg.v.env.faceoutlet.temp                12.8°C
xmg.v.ignition.state                     2
xmg.v.m.coolant.temp                     18°C
xmg.v.m.torque                           0Nm
xmg.v.radiator.fan                       no
xmg.v.soc.raw                            74.8%
xmg.v.vcu.dcdc.input.current             0A
xmg.v.vcu.dcdc.input.voltage             19V
xmg.v.vcu.dcdc.mode                      0
xmg.v.vcu.dcdc.output.current            0A
xmg.v.vcu.dcdc.output.voltage            12.1V
xmg.v.vcu.dcdc.temp                      18°C
hksoftware
After contacting support,
After contacting support, they provided an easy fix.
I was using the EU ovms.dexters-web.de server.
I changed this to the global api.openvehicles.com server and since then it has been working great.
markwj
markwj's picture
It shouldn't matter which
It shouldn't matter which server you use, as they are equivalent. But you do need to make sure both the App and the Car module are set to use the same server.
