I have tried to install OVMS in my 2011 Nissan Leaf Can someone help me with the following questions:
When the car is fully charged the battery display on OVMS only shows 62% Should it not show the same as the car dashboard?
How do you turn on the climate control / heating? I have no icon showing that I can press?
The display shows correctly when I open a door, plug in or unplug the car and also the car location correctly, but the main reason was I bought OVMS was to turn on the heating in the mornings because Nissan turned off the telematics here in the uk.
Have I installed this correctly? for a 2011 Leaf? or is there some setting I need to change? Any help appreciated thanks
Hi leccybug,
which installation guide have you used? Did you choose correct model and battery config? https://docs.openvehicles.com/en/latest/components/vehicle_nissanleaf/docs/index.html
The following guide contains instruction for activating remote heating on the 2011 model https://mynissanleaf.com/threads/howto-connecting-tcu-to-ovms-for-2011-2012-ze0-leafs.32935/ I haven't tried it out as I have a 2016 model.
Regards
Another thoughts:
- Which app do you use? iOS vs. Android? If iOS, have a look at this post https://www.openvehicles.com/node/2903
- Have you tried to send message "climatecontrol on" to your car from the app using the "Messages" screen?
