4 posts / 0 new
phamd4
wakeup command to charge 12v batter or automatically wake up
Hello,
I’m currently driving a 2016 Nissan leaf and has been trying to get the wake-up command function or allow the car to automatically charge the 12v battery when the voltage dropped but couldn’t get it working. My climate control on function does work but I can’t get the wake up command work. Only one time it worked when I changed the server to dexter but after the first time it work it stopped working. Hope someone could guide me to the right direction
nile
I have some strange behaviour
I have some strange behaviour (works sometimes, possibly after many retries), too. This affects wake-up and climate control. So I tried via browser (shell) and I notice that it is same on shell. So I think it is a timing (CAN bus) issue...
phamd4
My climate control on and off
My climate control on and off work pretty consistent. May I ask if you have found a fix for it ? Are you currently at ovms or Dexter server ?
nile
I am at Dexter server, but I
I am at Dexter server, but I will set up an own server the next time. I do not have a fix at the moment, but it is car related. In shell I see error messages if the command fails (red colored warnings) if the commands fail and green ones if it is successful.
