5 posts / 0 new
ntompson
ABRP planner script broken?
Hi,
I've been using the script to keep live data on ABRP up to date with live data from OVMS. It's been working flawlessly until a couple of weeks ago. I'm getting SSL errors whenever it attempts to push out an update. Some months ago, I updated the script to the GitHub hosted version (https://github.com/iternio/ovms-link). Since then, I've changed nothing. I raised an issue on GitHub (https://github.com/iternio/ovms-link/issues/10), but thought I'd try here in case anyone has the answer.
Thanks,
Nick
jmariuse
You need to install a new CA
You need to install a new CA  certificate.
I added info about it as a github case a little while ago
Mariuws
Asen MILEV
I also sost connection
I also sost connection between OVMS and ABRP since 21.11.2024 and cannot restore it.
Can somebody can help me?
roadstone
update certificate
Try to update/replace the certificate: https://github.com/iternio/ovms-link/blob/dev/trustedca/README.md:
almacd64
ABRP now working again after latest firmware update
I had all sorts of problems getting the ABRP module to work, and just abandonned it in the end. Couldn't even get my GF who's a software QA engineer to look at it. Very frustrating.
Anyway after the latest OTA firmware update it just works, didn't do anything, it just magically started working, now errors in the console, nothing, van just appears in ABRP.
Fingers crossed it'll stay that way.
