5 posts / 0 new
highvoltagebeetle
Dev environment on arm macs
The OVMS specific ESP-IDF doesn't seem have support for the arm based macs. Anyone used a more recent version of ESP-IDF or some other workaround? Or do I need to to keep my intel mac?
I've developed the initial module for the Zombieverter VCU used in EV conversions https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/tree/master/vehicle/OVMS.V3/components/vehicle_zombie_vcu and now want to updated.
highvoltagebeetle
https://github.com
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/756 I've found this to try
markwj
markwj's picture
I use Apple Silicon macs, and
I use Apple Silicon macs, and don't have any problems with the packages from the developer guide. But need to use those specific versions mentioned, and the download links provided. You can't substitute newer versions.
highvoltagebeetle
Well, after hours of trying
Well, after hours of trying to use the docker setup from the post above, I'm not able to compile still. I can build on my old mac, but wanting to move away from it.
In file included from /ovms/vehicle/OVMS.V3/components/ovms_cellular/src/ovms_cellular.h:43:0,
                 from /ovms/vehicle/OVMS.V3/main/ovms_peripherals.h:71,
                 from /ovms/vehicle/OVMS.V3/components/can/src/canlog_vfs.cpp:35:
/ovms/vehicle/OVMS.V3/components/ovms_cellular/src/gsmpppos.h:68:5: error: 'ppp_pcb' does not name a type
     ppp_pcb*     m_ppp;
fowi4hjte
Does the issue stay the same
Does the issue stay the same when you try using some better operating system on this apple silicon? https://asahilinux.org/
Have you tried it out with ESP-IDF 5? Some patches have been merged that could help with building it with more recent ESP-IDF.
