3 posts / 0 new
Dirk H.
OVMS Module disturb radio reception
Hello,
I just installed the OVMS module on my Hyunday Kona (2019).
Every works fine, but when I swiched on my radio, the radio reception is disturebed.
Specially the DAB+ stations can't be received.
(174 MHz ... 230 MHZ 1,5 GHz (L-Band).
Do anybody has the same problem and know how to fix it?
Best Regards
Dirk H.
mld
Yes, I am also seeing this
Yes, I am also seeing this issue. DAB stations cut in and out.
With the modem card installed, even strong DAB stations are difficult to receive. Unplug the OVMS and the problems goes away.
With the modem card removed, strong DAB stations can be received OK but week DAB are difficult to receive. Again, unplug the OVMS  and the problem goes away.
Ferrite cores on the ODB cable do not fix the problem.
Mark
markwj
markwj's picture
As mentioned elsewhere,
As mentioned elsewhere, please check routing of cables and placement of antenna. They should not be in close proximity.
