Hello,
I'm having trouble with my Twizy. It stopped working while driving, and got error on traction battery. I bought the OVMS to help troubleshoot the problem.
I opened the traction battery and found the 5A fuse blown. Replaced this, and tested: Still nogo. The fuse blew again.
Tested the 10A and 40A relays, they worked fine. 50A and 500A fuse is also ok.
I installed a 7.5A fuse instead of 5A. Now the sevcon started to report problems:
SEVCON Fault 0x5442 [Return to Base]: Calibration Fault
Info: Calibration settings in controller are out of range
Action: Controller requires recalibration in production
SEVCON Fault 0x5044 [Very Severe]: Dynamic Range Error
Info: At least one configuration object is out of dynamic range. This is where one objects range depends on another object.
Action: Check all dynamic range objects. Engineering DVT CLI window indicates type of object which is out of range.
SEVCON Fault 0x4f41 [Severe]: Internal Fault
Info: Internal software fault
Action: Internal software fault
SEVCON Fault 0x5441 [Return to Base]: Incompatible hardware version
Info: Detected controller hardware version incompatible with software
Action: Check correct software is programmed into controller. Reprogram if necessary
7m
SEVCON Fault 0x4581 [Warning]: Throttle Fault (Warn)
Info: Warning level throttle fault. Used for Renault Twizy
Action: Check throttle wiring and installation.
SEVCON Fault 0x4602 [Warning]: Device too hot
Info: High heatsink temperature (0x5100;4) has reduced power to motor
Action: Allow controller to cool down to normal operating temperature.
SEVCON Fault 0x4588 [Warning]: Analogue Output Short Circuit (warn)
Info: Contactor driver MOSFET short circuit detected
Action: Internal hardware fault
SEVCON Fault 0x4f54 [Severe]: Autozero range error
Info: Current sensor auto-zero current out of range
Is the sevcon broken beyond repair?
Using xrt dtc command i get this:
DTC report: 10 stored, 8 present
#01: 2/70 rev0 G1 MEM Ef @ 36881km -1kph SOC=86% BV=11V TC=0 IC=6
#02: 4/1 rev0 PRESENT(7x) G1 MEM @ 36881km -1kph SOC=86% BV=11V TC=0 IC=6
#03: 1/37 rev0 G1 INT MEM Ef @ 36881km -1kph SOC=86% BV=11V TC=0 IC=6
#04: 2/37 rev0 PRESENT(3x) G2 INT MEM Dc @ 36881km -1kph SOC=85% BV=11V TC=0 IC=5
#05: 2/90 rev0 PRESENT(3x) G2 INT MEM Ef @ 36881km -1kph SOC=85% BV=11V TC=0 IC=5
#06: 4/14 rev0 PRESENT(7x) G2 INT MEM Ef @ 36881km 0kph SOC=81% BV=14V TC=0 IC=0
#07: 4/13 rev0 PRESENT(6x) G1 INT MEM Ef @ 36881km 0kph SOC=81% BV=14V TC=0 IC=0
#08: 4/16 rev0 PRESENT(6x) G2 INT MEM Ef @ 36881km 0kph SOC=81% BV=14V TC=0 IC=0
#09: 4/62 rev0 PRESENT(6x) INT MEM Bt @ 36881km 0kph SOC=81% BV=14V TC=0 IC=0
#10: 4/81 rev0 PRESENT(6x) G2 MEM Ef @ 36881km 0kph SOC=81% BV=14V TC=0 IC=0
Any advice?
Removed it today... it was melted around the B- pin. Getting a new old one.
