2 posts / 0 new
skaggetse
AZE0-2 Climate Control
I just recently puchased a 2017 Nissan Leaf AZE0-2.
When I realized that the App functionality from Nissan is no longer active sinze 3G is shut down, I came here.
I was disappointed to read this description about my model;
Remote climate control will only work when plugged in and actively charging on LEAF 2016-2017 models. This is because in 2016 Nissan moved the TCU from the EV CAN bus to the CAR CAN bus.
Is this information final? Is the climate control completely unavailable for this model, except during active charge?
Or can progress be made to add this functionality later on?
bb
It does work, at least in my
It does work, at least in my 2017, but requires you to disable the TCU by depinning the CAN lines (or cutting them), which can be challenging to do while in the footwell. Totally disconnecting the TCU also works, but breaks the microphone and possibly some other things.
