7 posts / 0 new
THUNK
Using OVMS to display tire pressures from TPMS
I have a THINK City and have set it up to run the latest OVMS version with the THINK City vehicle configuration.
Much of the time I've found the data coming from and displayed on OVMS of little value to me or the connectivity too poor that the data displayed is just stale.
One thing that would be cool is if the main vehicle display could include tire pressures.  On the THINK City, regular TPMS messages with pressure info are regularly received while driving.  It would be nice to display the pressures, but so far I don't see that this is done generally with the OVMS software stack.
Any thoughts on this?  I'm not interested in any big realtime data here, just that once up to speed and tire pressures stabilize, it would be good to capture and display them so the driver could see if a specific tire is getting low or if a particular TPMS sensor has gone South...
Thanks!
-Myles Twete
markwj
markwj's picture
I don't see any documentation
I don't see any documentation for Think City, and the vehicle support code doesn't mention TPMS, so I guess this is very new and has limited support.
THUNK
OVMS for THINK City --- anyone still using this?
Evidently none of the SW folks who worked on the earlier builds for the THINK City vehicle have supported it since 2023 and really not much since 2018.  The documentation was overlooked.  It is on my radar though---stay tuned.  At this point in time, I think I am the only THINK City owner who uses OVMS.  There were only ever a few folks and of those, 1 died, 1 sold all of his THINK cars, parts and tools and everyone else gave up on it because not enough was implemented to make it useful.  Adding TPMS pressures to display really makes me happy with it.
fowi4hjte
This use case of detecting a
This use case of detecting a fault sensor and solve the issue can be fully universal solved with: https://github.com/merbanan/rtl_433
Its decoding nearly any TPMS sensors RF data from any car manufacturer out there and show the values and the TPMS-ID that have been send from the sensors. Thanks to showing the signal quality, you can place the antenna strategic to know what tire have what ID.
markwj
markwj's picture
Interesting project, but
Interesting project, but requires high-end hardware (linux, mac, windows, etc). They mention maybe able to port to embedded, but seems to require external USB hardware (and USB stack support for that) for the actual radio.
OVMS typically works off what is on the CAN bus. The data is normally there, but sometimes hard to decode as manufacturers don't typically publish the coding.
THUNK
As of 11/2025, TPS pressures are now displayed in the OVMS Client App.  Still working on adding the alerts, but pressures are reliably displayed and very useful to identify a bad sensor vs just a low pressure tire.
fowi4hjte
No, it does not require high
No, it does not require high-end hardware. Here to run it on ESP32: https://github.com/NorthernMan54/rtl_433_ESP/releases
And here even some arduino: https://www.hackster.io/jsmsolns/arduino-tpms-tyre-pressure-display-b6e544
But using just a computer with the core rtl_433 is the quickest thing to check in just few minutes the TPMS values of your car. You are getting the values directly from the tires. It does not matter any more if your car itself have issues to read the TPMS values from the tires.
