I've been using OVMS for about 4 months now. I've tried many firmwares, but so far "3.3.005-1-geed58d6f" is probably the best. However, it's not perfect, it restarts two or three times a day and sometimes it freezes so much that only removing the battery helps.
What is your experience? Which version should I use?
I have a 2018 40kwh ZE1.
Thanks
I have a 2015 24kwh US Leaf S. I don't see this firmware version in the web interface, just one from 2022: 3.3.003/ota_1/main (build idf v3.3.4-848-g1ff5e24b1 Sep 1 2022 08:40:30)
Under that, "Available" only shows 3.3.003. Is there some other way?
Update: I did the web update through the web interface. All went well according to the window. I restarted but nothing had changed. What am I missing?
