3 posts / 0 new
umbjm
Help with troubleshooting
I'm having trouble with the server v2 not connecting. Server v3 appears to be fine. I see the following:
  • config list network shows dns: 192.168.1.1
  • Unbound sees zero queries from the module when V2 tries to connect
  • Cellular DNS resolves correctly via AT+CDNSGIP
  • V3 MQTT works fine over WiFi to local IP
TIA!
markwj
markwj's picture
Sounds like you configured your DNS to use your Wifi DNS, but that won't work when out of range of wifi and on cellular networks.
Suggest to set to standard DNS servers (1.1.1.1, 8.8.8.8, etc).
umbjm
Back in the country,
Back in the country, apologies for the delay. Thanks for your reply. That's now fixed, but I appear to have a timing issue during boot, specifically "netmanager: MODEM up (with WIFI client up): staying with WIFI client priority". Is this preventing the cellular from working at all?
E (24629) ovms-server-v2: mg_connect(api.openvehicles.com:6870) failed: cannot parse address
E (24629) ovms-server-v2: Status: Error: Connection failed
I (24639) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600
I (24639) cellular: Set modem driver to 'SIM7600'
I (24639) cellular: State: Enter PoweredOn state
W (24659) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 11/40
W (24659) ovms-duktape: EventScript: event 'egpio.output.0.high' delayed, queued at position 12/40
W (24659) ovms-duktape: EventScript: event 'egpio.output.0.low' delayed, queued at position 13/40
W (24669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 14/40
W (24669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 15/40
W (24669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 16/40
W (24679) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 17/40
W (24679) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 18/40
W (24679) ovms-duktape: EventScript: event 'ticker.10' delayed, queued at position 19/40
W (24689) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 20/40
W (24689) ovms-duktape: EventScript: event 'server.web.socket.opened' delayed, queued at position 21/40
I (24689) ovms-server-v3: Attempt connect: counter=15 need=15 jitter=5
I (24689) ovms-server-v3: Connection is 192.168.1.27:1883 BPOC27/bpoc27 topic ovms
I (24689) ovms-server-v3: Status: Connecting...
W (24699) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 22/40
W (24699) ovms-duktape: EventScript: event 'server.v2.waitreconnect' delayed, queued at position 23/40
W (24709) ovms-duktape: EventScript: event 'system.modem.installed' delayed, queued at position 24/40
W (24709) ovms-duktape: EventScript: event 'system.modem.poweredon' delayed, queued at position 25/40
W (24749) websocket: WebSocketHandler[0x3f8deeec]: job queue overflow detected
W (24769) websocket: WebSocketHandler[0x3f8deeec]: job queue overflow detected
W (24789) websocket: WebSocketHandler[0x3f8deeec]: job queue overflow resolved, 2 drops
I (25069) ovms-server-v3: Status: OVMS V3 MQTT login successful
I (25389) webserver: HTTP POST /shell
I (25389) webserver: HandleLogin: 'admin' logged in, sid bcd99033548d315e
I (25529) ovms-server-v3: Subscribe to MQTT topics
I (25529) ovms-server-v3: Transmit all metrics
I (25649) ovms-server-v3: Tx notify ovmsnotify/info/charge/started=Standard - Charging ……: 110.0V/6.4A |Charged: 1.1kWh ……: SOC: 65.0% ……: Ideal range: 44M ……: Est. range: 34M ……: ODO: 52822.0M ……: CAC: 51.7Ah ……: SOH: 83%
I (25709) webserver: HTTP GET /shell
I (25729) webserver: HTTP GET /menu
I (25769) ovms-server-v3: Subscription acknowledged
I (25799) ovms-server-v3: Message publishing acknowledged (msg_id: 208)
I (32529) cellular: State: Enter MuxStart state
I (32539) gsm-mux: Start MUX
I (32539) gsm-mux: Channel #0 is open
I (32539) gsm-mux: Channel #1 is open
I (32549) gsm-mux: Channel #2 is open
I (32549) gsm-mux: Channel #3 is open
I (32549) gsm-mux: Channel #4 is open
I (33529) cellular: State: Enter NetWait state
I (33529) gsm-nmea: Startup
I (40569) location: UpdateParkPosition: vehicle is parking @40.578751,-105.099876 gpslock=0 satcount=9 hdop=1.2 sq=66 invalid=1
I (40569) location: UpdateParkPosition: vehicle is parking @40.578827,-105.099892 gpslock=0 satcount=9 hdop=1.2 sq=66 invalid=0
I (43549) cellular: Network Registration status: RegisteredRoaming
I (44529) cellular: State: Enter NetStart state
I (44539) cellular: Network Mode: LTE,Online
I (45589) cellular: PPP Connection is ready to start
I (46529) cellular: State: Enter NetMode state
I (46529) gsm-ppp: Initialising...
I (46629) gsm-ppp: StatusCallBack: None
I (46629) gsm-ppp: status_cb: Connected
I (46629) gsm-ppp: our_ipaddr = 10.95.152.210
I (46629) gsm-ppp: his_ipaddr = 10.64.64.64
I (46629) gsm-ppp: netmask = 255.255.255.255
I (46629) gsm-ppp: DNS#0 = 8.8.8.8
I (46629) gsm-ppp: DNS#1 = 8.8.4.4
I (46629) gsm-ppp: our6_ipaddr = ::
I (46639) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
I (71529) ovms-server-v2: Connection is api.openvehicles.com:6870 BPOC27
I (71529) ovms-server-v2: Status: Connecting...
E (84629) ovms-server-v2: mg_connect(api.openvehicles.com:6870) failed: cannot parse address
E (84629) ovms-server-v2: Status: Error: Connection failed
W (84659) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 11/40
W (84659) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 12/40
W (84669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 13/40
W (84669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 14/40
W (84679) ovms-duktape: EventScript: event 'ticker.10' delayed, queued at position 15/40
W (84679) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 16/40
I (84679) cellular: Network Provider is: AT&T Hologram
W (84689) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 17/40
W (84689) ovms-duktape: EventScript: event 'server.v2.waitreconnect' delayed, queued at position 18/40
I (122549) housekeeping: System considered stable (RAM: 8b=71292-73336 32b=12132 SPI=3258068-3260860)
I (131529) ovms-server-v2: Connection is api.openvehicles.com:6870 BPOC27
I (131529) ovms-server-v2: Status: Connecting...
E (144629) ovms-server-v2: mg_connect(api.openvehicles.com:6870) failed: cannot parse address
E (144629) ovms-server-v2: Status: Error: Connection failed
W (144659) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 11/40
W (144669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 12/40
W (144669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 13/40
W (144669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 14/40
W (144679) ovms-duktape: EventScript: event 'ticker.10' delayed, queued at position 15/40
W (144679) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 16/40
W (144689) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 17/40
W (144689) ovms-duktape: EventScript: event 'server.v2.waitreconnect' delayed, queued at position 18/40
I (191529) ovms-server-v2: Connection is api.openvehicles.com:6870 BPOC27
I (191529) ovms-server-v2: Status: Connecting...
E (204629) ovms-server-v2: mg_connect(api.openvehicles.com:6870) failed: cannot parse address
E (204629) ovms-server-v2: Status: Error: Connection failed
W (204659) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 11/40
W (204669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 12/40
W (204669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 13/40
W (204669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 14/40
W (204669) ovms-duktape: EventScript: event 'ticker.10' delayed, queued at position 15/40
W (204679) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 16/40
W (204689) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 17/40
W (204689) ovms-duktape: EventScript: event 'server.v2.waitreconnect' delayed, queued at position 18/40
I (251529) ovms-server-v2: Connection is api.openvehicles.com:6870 BPOC27
I (251529) ovms-server-v2: Status: Connecting...
E (264629) ovms-server-v2: mg_connect(api.openvehicles.com:6870) failed: cannot parse address
E (264629) ovms-server-v2: Status: Error: Connection failed
W (264669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 11/40
W (264669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 12/40
W (264669) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 13/40
W (264679) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 14/40
W (264679) ovms-duktape: EventScript: event 'ticker.10' delayed, queued at position 15/40
W (264689) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 16/40
W (264689) ovms-duktape: EventScript: event 'ticker.1' delayed, queued at position 17/40
W (264699) ovms-duktape: EventScript: event 'server.v2.waitreconnect' delayed, queued at position 18/40
