5 posts / 0 new
EU17VMA
iPhone app not connecting
Hi, have had the OVMS app on my iPhone for over 5 years with no problems connected to my Nissan Leaf. Stopped working a few days ago. I have reset the the module in the car and setup as a new vehicle. Can get everything to work and see the car reporting on OVMS dashboard and on the Dexter’s server. But whatever I try I can’t get the Apple OVMS app to connect. Has anyone else had a recent problem with the app?
paulgab
I am experiencing the same
I am experiencing the same issue with a Nissan Leaf. Logging in the OVMS hardware, it is reporting "OVMS V2 login successful, and crypto channel established". The ABRP module is also uploading telemetry.
I too have attempted to re-add the car a new vehicle in the iOS app, no joy.
markwj
markwj's picture
If you are using Dexter's
If you are using Dexter's server, have you changed the iOS settings (Open Vehicles App) to match that server (it defaults to api.openvehicles.com).
paulgab
I have been using api
I have been using api.openvehicles.com. I'm not sure what happened but yesterday the iOS app started working again after about a week of it not.
markwj
markwj's picture
For those with this problem,
For those with this problem, I suggest you check iOS Settings App, search for 'Open Vehicles' and make sure server is set to 'api.openvehicles.com'. I helped someone recently who had it set to 'tmc.openvehicles.com' (which was deprecated a decade ago).
