I installed the ABRP script a while back but have never been able to get it to work.
Though I'd have another crack at it and updated various things including the godaddy cert and gave it a new token from ABRP but same errors.
The console gives me the following.
E (390948177) ovms-duktape: [lib/abrp.js:175] TypeError: undefined not callable (property 'HasValue' of [object Object]) ……: at [anon] (duk_js_call.c:2919) internal ……: at isOvmsMetricSupported (lib/abrp.js:175) ……: at getOVMSMetric (lib/abrp.js:225) ……: at createTelemetry (lib/abrp.js:548) ……: at sendTelemetryIfNecessary (lib/abrp.js:619) ……: at callSubscriberWithImmediateExceptions (int/PubSub.js:1) strict ……: at deliverMessage (int/PubSub.js:1) strict ……: at c (int/PubSub.js:1) strict ……: at publish (int/PubSub.js:1) strict ……: at [anon] (int/PubSub.js:1) strict preventsyield
So, update on these errors, I updated to the latest firmware the 3.3.006-172 version that came as an OTA update.
The ABRP script suddenly works, live update straight into ABRP no leafspy needed. No errors on the OVMS console.
Pretty cool.
Only thing I notice is if you're not actually following a route the location in ABRP only updates every couple of minutes. Appear to update live once you've got a route loaded.
