10 posts / 0 new
EdLaPoignee
How to use the Twizy CFG function?
Hi everybody,
I have an Issue with the Twizy CFG function, until now I am not able to execute any of these.  I am not sure what I do wrong maybe someone can give me a tip.
That is how I proceed:
I Flashed the “V2_RT_production.hex” Firmware. (VERSION 2.6.5/RT3.2.0/V2)
I set MODULE to “RT” confirmation was OK.
Module:
VehicleID:xxxxxxxx
VehicleType:RT
Units:K
Notification:SMSIP
I set “FEATURE 15 1”
Feature has been set.
I installed the OVMS in the Twizy and I get some SMS like GPS? STAT? Efficency, etc…
I turned the Twizy to ON but not in GO mode.
I send “CFG SPEED 90” No response/reaction
Turn ignition off-on nothing!
I tried this several times with no success.
A few thinks are not clear to me:
What about the Car Bits FEATURE 14. I set it to 0 to get every SMS is that correct?
Pre-operational state is part of the "CFG SPEED" macro?
Thanks for any help.
Stéphane
Itester
Hi Stéphane,
Hi Stéphane,
where did you download the firmware?
I tried it on Github but it opens the file... for now i copy paste the content and saved it as a .hex file but i'm not sure if this is right.
Itester
i downgraded to v2.5 now and
i downgraded to v2.5 now and i have this same problem, every cmd works only on CFG commands i don't get a reply, also did FEATURE 15 1 first to enable can bus writing....
EdLaPoignee
Firmware Download Link
Hi,
I downloaded the .hex file from here: http://www.idleloop.com/tesla/ovms/ right click on the
V2 Renault Twizzy -> store target under etc... This seems to be the GitHub Firmware however, this .hex was OK!
But on this Firmware the Twizy extension seem not to work...
Example: I send "CFG SPEED 95 100" the module seems to push this SMS to my Android APP without action. Sending a "Hello" give the same result... :-)
I think we need a Firmware with active Twizy extensions or a way to get them active!
Itester
it works now
i uploaded the latest firware again incl writing the eeprom.
when i dont do this i keep getting permission denied failures.
i did the following txt's to the module:
REGISTER OVMS =>
Your phone has been registrated as the owner
MODULE "MYvehicleID" K SMSIP RT =>
MOdule:
VehicleID: XXXXX
VerhicleType: RT
Units: K
Nitofications: SMSIP
Version? =>
2.6.6/RT3.4.0/V2
FEAUTURE 15 1 =>
Feauture has been set
CFG SPEED 100 =>
CFG SPEED: LOGIN FAILED ERROR 004B
i tried again:
CFG SPEED: LOGIN FAILED ERROR 0043
than i thought lets turn it on GO:
CFG SPEED: ERROR 0020 SDO 0x5110.00: 0x0005
than i thought, maybe it's beacuase the Twizy is on the charger, i removed the power cable and turned the Twizy on ignition but not on GO =>
CFG SPEED: OK, power cycle to activate!
fwd=9061 wrn 8050
PwrLo: 12182W / 55.000Nm @ 23.3kph
PwrHi: 13.000W / 19.312Nm @ 70.8kph
Now ready for a testdrive ;)
EdLaPoignee
Download Link
can you share the download link for this Firmware?
Thanks
Itester
i received it from the ovms
i received it from the ovms staf but they included a link:
http://www.vectrix-forum.de/index.php?option=com_kunena&Itemid=72&func=v...
Itester
Itester
testdrive done
top speed is now limited to 99 and acceleration goes a bit faster to ( also did CGF POWER 110 )
the only thing i have my concerns about it that the stop sign turns on after passing 93 kpn? is this a real warning or can you just keep going?
Itester
the stop sign was just a
the stop sign was just a warning, i changes it into CFG SPEED 110 100 and now the warning comes at 100
i reached a top speed op 109kph now.
settings now made:
CFG power 120 100 100
CFG SPEED 110 100
i notice that when you unplug the module you have to perform a REGISTER OVMS every time, if you don't you won't get a reply back after sending a CFG command.
