4 posts / 0 new
chrban
Unable to stop charging (leaf 2015)
I'm unable to stop/start charging from the app.
The display in the app says "stopping charge.. => failed"
Is this supposed to be working on the leaf 2015?
I have the soc working, as well as ac/heat control,
but start/stop charge will not work (as well as door unlock or gps location).
Also, I assumed that OVMS would be able to get the GPS signal from the car, but location is allways 0,0.
Ideally i would like to use the OVMS to stop charge automatically at 80%, if possible.
carloswlkr
did you ever get this to work?
I'm having the same problem with my LEAF 2013. Did you ever get a response? Did you get it to work the way you want?
chrban
I have not figured out the
I have not figured out the stop charge yet.
I got the GPS working by connecting a GPS antenna.
Alenux
OVMS currently doesn't
OVMS currently doesn't support stopping the charge on the Nissan Leaf, but it's being tested. See the GitHub issue here: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/287
