I just received my OVMS box and configured it for my e-Nero. That part works fine, but I have trouble getting the iPhone app working.
I understand that I have to fill in some information in ‘settings’ of the phone first, but it is rather confusing to me what information is to be filled in where. I couldn’t find any instructions and the different fields here and in the app use other names than those used in the online settings at openvehicles.com. It would be helpful if the same thing was called by the same name everywhere.
IN IPHONE SETTINGS
1. In the settings on my phone I have to fill in the server. It say now ‘tmc.openvihicles.com’, but I had to make an account at dexters-web.de. What is the correct server address here?
2. What is the correct port number that should be used?
3. Then the head ‘www.openvihicles.com’ (settings) it asks for ‘username’ and ‘password’. Rather confusing: the un/pw of openvihicles.com, the main account on dexters-web or the cars account on dexters-web?
IN THE OVMS APP
There are four fields to fill in when entering a new car, but since the names ‘vehicle ID’ and ‘Vihicle label’ are different from the field names in dexters-web online, I don’t know what to use where.
Sorry if I missed any instructions that describe this. I’ve looked ‘everywhere’ and tried many options but gave up. There are too many possibilities.
Help would be very much appreciated.
And maybe someone can make an instruction somewhere so other users can find the right way to do this?
You should use the same settings as you entered into the vehicle module itself.
If you are using Dexter's EU server, the name is
ovms.dexters-web.de
Leave port at default (6867).
In www.openvehicles.com section you should put in the username and password for the server you are using (in your case Dexter's web).
Then in the App, Settings/New you enter:
Vehicle ID: The vehicle ID you put into the module
Vehicle Label: Whatever you want as the nickname of your vehicle
OVMS Server Password: The password you set in the module for the OVMS v2 server
OVMS Module Password: The password you set in the module for the module itself
Can I get some more details here. I've been trying to get the iPhone app going with no luck.
Let me confirm a few points:
Now for clarity, in the iPhone settings for OVMS Server - Ive entered "api.openvehicles.com"
In the www.openvehicles.com section, ive tried both my username & password to log into the www.openvehicles.com site, and also I've tried putting the vehicleID and the server password.
No matter what I've tried to enter, when I go to the app, settings, and click the <new> ... I can only select a vehcle photo, I get no page to enter any parameters.
Where I am I going astray ?
Thanks.
Got it working. Thanks
There is a problem with the iOS App under iOS 14 in light mode. We have a revised version under testing at the moment.
Can you try to change to dark mode (in iOS settings) and then going into OVMS App again? You should then see the fields required. You can switch back to light mode once the setup is complete.
Thanks Mark !
That was indeed the blocking issue.
Now connected and moving data.
Thanks - and Woohoo !
But my settings are "light mode" and the map is very dark. Also I am missing the 12V Battery history that is available under android
I'm having the same problem too with the iPhone app. Everything is set up and I can see data from the car, but I don't see the AC option on the "Car" screen like I do on Android
The there’s a great alternative app
At-a-Glance Dashboard:
Monitor your State of Charge (SoC), estimated range, odometer, charging status, and live power usage on a clean, modern dashboard.
Interactive Vehicle View:
Visualize your vehicle's status with an interactive top-down view. Instantly see open doors, trunk, hood, charge port status, and active headlights. Get detailed TPMS data for each tyre overlaid directly on the visual.
Commands:
Go beyond the basics. In addition to standard commands like lock/unlock and climate control, you can create, save, and manage your own custom commands for anything your vehicle supports.
Configurable Dashboard Actions:
Pin your most-used standard or custom commands directly to the main dashboard for lightning-fast access to the features you care about most.
Live Map & Tracking:
Track your EV in real-time on a live map. View your car's location, your phone's location, and see a history of your trail.
Deep-Dive Telemetry:
For the true data enthusiast! Dive into detailed screens for every aspect of your vehicle:
HV Battery: View cell-level voltage and temperature graphs, SoH, and more.
12V System: Monitor the health and charging status of your auxiliary battery.
Charging & Inverter: Analyze charging sessions, power, efficiency, and temperatures.
Trip Data: Track energy used, regenerated, and average consumption.
And more: Location, Network, System, and Vehicle-Specific Metrics.
The Hacker's Console:
For ultimate control, drop into a full command-line terminal to interact directly with your OVMS module. View command history and raw responses.
Real-Time Notifications:
Get instant push notifications for important vehicle alerts when connected to a compatible push-enabled broker (like turboserv.0-c.de).
Looks good, but be aware it has specific server requirements and uses MQTT (v3) API - so data usage much higher than the usual v2.
