Hello all,
thank you for your great work with this module.
I am trying to collect the GPS data with the data CAN-Bus data. The target is to use the data to simulate vehicle and calculate the consumption based on the road profile.
I have collected the data independently of each other. I would like to have one file create by the OVMS containing the GPS coordinates and the current, voltage and speed information.
Is this possible to do easily or does it require modification of source code?
Mayu
You're aware of the v2 protocol "L" server log containing GPS data + current speed & power + running totals of energy consumption & recuperation for a trip?
And of the option to raise the frequency for this log up to once per second using the streaming configuration?
