On my OVMS module I can make the following request to a HTTPS test/demo Postman endpoint and it works perfect:
var req = HTTP.Request("https://postman-echo.com/get?foo1=bar1&foo2=bar2");
But when I try to do a similar request to my own API at "https://api.triggermouse.com/api/values" I get the following back:
"url": "https://api.triggermouse.com/api/values",
"done": function () { [ecmascript code] },
"fail": function () { [ecmascript code] },
"redirectCount": 0,
"error": "SSL error"
Reading through the docs it does mention the following for HTTP requests: "you may need to install a custom root CA certificate...". So I went ahead and got the .PEM from my web server, and did the following as described here: https://docs.openvehicles.com/en/latest/userguide/ssltls.html. But no luck. Anyone have any ideas why the Postman HTTPS request works, but why my web server does not? Thanks in advance!
-Jake
Jake,
you need the SNI bugfix from https://www.openvehicles.com/comment/6443#comment-6443 .
Update to the latest edge/eap release.
