7 posts / 0 new
phamd4
2016 Leaf S trim climate control
Hello
I'm new to the system. I got everything hooked up and connected. I got the lock and unlock working but I cannot seems to wake the car or get to the climate control setting. Can someone please guide me in the right direction?
I"ve also read the instruction but nothing mentioned about the climate control menu.
phamd4
Hello,
Hello,
I figured it out now.
THe AC climate only work with android app. the iPhone doesn't have that function.
Thank you
Alenux
How did you get the lock and
How did you get the lock and unlock to work? What'd you use for the pin?
phamd4
Hello,
Hello,
I think it works on certain Nissan Leaf models. My leaf is a base S model without any navigation or fancy electronic extra. it is the 2016 Nissan Leaf S 30kwH battery. I just plugged in and it worked. I guess I must be very lucky to buy the right model for this mod. However, the lock can unlock only the driver's side door. Lock car works with all doors.
stefou@gmail.com
Same issue
For some unknown reason my climate control doesn't work properly. I have to click on it several time in order to start it.
Also, I can start charging but can't stop it.
Leaf 2016 SL
Firmware 2.5.0-20191213
On Android OVMS App 3.16.1
phamd4
Hmm.
Hmm.
Mine worked at the moment I clicked it. It takes 2-3 seconds for the unit to receive the signal but it does work.
Maybe you need to upgrade your unit firmware? Mine is at . 3.2.011 the latest firmware is 3.2.012
stefou@gmail.com
Downgrade
I had issues with the newest version so I downgraded it.
Lately i'm when I type "Stats" on the console it only gives me battery charging status, batttery power and millage. I used to see alot more...
