10 posts / 0 new
minionherder
ABRP Script Invalid Authentication
After setting up the https://docs.openvehicles.com/en/latest/plugin/abrp/README.html script to submit my car status to ABRP for live trip planning, I always receive the following error:
   {"status": "error", "metadata": {"frontend": "se-la-fe-01", "server": ""}, "message": "Invalid Authentication"}
I'm now trying to debug on my computer, and simply can't get any successful response (obviously tried getting new tokens etc).
Has the api_key been revoked or something (on the ABRP side)? Or is it something to do with my setup (perhaps ABRP isn't registering my api key properly when it generates)?
My (obviously incomplete url is) https://api.iternio.com/1/tlm/leaf24?api_key=32b2162f-9599-4647-8139-66e9f9528370&token=7bf16be3-4429-4286-8397-
Thanks
dar63
Hi,
Hi,
How did you get your own key, using the  "classic version" of abrp?
My OVMS box sends data as soon as I move, and I check, last position is ok when I launch abrp on my mobile.
I'll check if the procedure to get your own key has changed.
David
dar63
I had a look on your url
Why https? It should be http
Why tlm/leaf24?api_key=32b... it should be tlm/send?api_key...
/David
dar63
Quick guide to setup ABRP and OVMS plugin
Abetterroutplanner.com
It is advised to install abrp on the same phone than your OVMS app, to allow an easy setup (copy/paste will be used from one to the other to get your user key and to use it).
First of all, you have to connect to abrp, or create an account.
Here, after having displayed abetterrouteplanner.com :
Click on « Parameters », this will be displayed :
On the left side of the screen, the first time, you can add your own vehicle selecting « add my car ».
You will be here able to configure, using EVNotify template or Torque. Choose Torque
Click on ‘Next’
Click on ‘Next’
Click on ‘Next’
Here’s your user_token (field user email address) !!! Copy it, we’ll use it in OVMS app now.
(here we got 54c238a7-292d-40a6-bb6b-13697b2f7604)
OVMS app
In the ‘message tab’, you will write « config set usr abrp.user_token » and space and paste your key.
Exemple here :
config set usr abrp.user_token 54c238a7-292d-40a6-bb6b-13697b2f7604
you can check with the following command :
config list usr
Now you can start sending data with the command :
script eval abrp.send(1)
Result
After message sent to abrp, you should be able to see it :
Zone de Texte: Your place
Now enjoy abrp with live data !
KommyKT
i don't see pictures.
Liss Henriksson
Liss Henriksson's picture
abrp connect to OVMS - instructions pictures gone
Hello I can't see the pictures in this post , is there another link to get the instruction to connect? I have connect my OVMS module last year to abrp and it worked . Now it's time to travel again and I have start all up. How can I see that OVMS give my abrp live data ?
Liss Henriksson
dar63
abrp - ovms quick guide
Liss Henriksson
abrp connect to OVMS - I get error after follow your instruction
config set usr abpr.user_token d6e2188f-215c-405e-87f4-455d67f58a75
Parameter has been set.
usr (readable writeable)
  abpr.user_token: d6e2188f-215c-405e-87f4-455d67f58a75
ERROR: ReferenceError: identifier 'abrp' undefined
    at [anon] (duk_js_var.c:1236) internal
    at eval (eval:1) preventsyield (line 1)
What shall I do ? kindest Liss
markwj
markwj's picture
You have set 'abpr.user_token
You have set 'abpr.user_token', where the instructions ask for 'abrp.user_token'.
The guide is here: https://onedrive.live.com/?authkey=%21AGbzCRXYmJx6xCI&cid=692F40CA744EA8EF&id=692F40CA744EA8EF%21984&parId=692F40CA744EA8EF%21983&o=OneUp
