5 posts / 0 new
sbwithers
Micro SD card won't 'lock' in the slot.
I received my OVMS v3 (EU GSM) module this morning. I connected to the OVMS wifi AP with OVMSinit. I reset the wifi ID and the password....and then reconnected.....and it asked me for an "old password". Hmmm.
What old password? I hadn't set one. Just the wifi SSID and password.
The unit no longer shows in the wifi......so I'm trying a factory reset via MicroSD with "factoryreset.txt" in the root. But now the MicroSD card can't / won't lock in the slot.....it just sits there loosely.....and falls out if you tip the box over. Guess I'll get the screwdriver out and the S2 method.
Not a great experience so far.  Anyone know what's up with the SD slot?
dexter
dexter's picture
The setup wizard doesn't ask for an "old password". Please compare your steps with Andrew Till's setup guide: https://youtu.be/Z9Fsbvd1Kfg?t=819
If you still get that question, provide screenshots of how you get there.
The SD slot is deep, you need to push the card in using a fingernail, screwdriver or similar. Push gentle until you feel & hear the click.
sbwithers
I was following the video....
I was following Andrews' video, but I suspect my choice of password was the problem. It failed 3 times and then the Module locked. Plus the terminalogy on the screen probably needs a graphical map to show the relationships. I did a factory reset using the Switch 2 method......and chose a different, shorter password with different special characters......and everything went just fine after that.
There is a wifi server.....but there is also the cloud server. The SSID was the vehicle ID and the cloud has a "vehicle ID". Coming in cold, these apparent ambiguities lead to confusion on my part.
sbwithers
Update....
I took the device out of the case. The SDcard ten can be inserted more easily. But I did the Switch 2 factory reset instead....and it worked fine. I think maybe OVSM didn't like the password I was trying to set. I used a shorter one with different special characters and it then worked just fine from there on.
sbwithers
Update....
