4 posts / 0 new
Javier Baena
Javier Baena's picture
Broken ovms module
Hi guys
At the Kia workshop, they broke my wifi antenna cable, and I knew it late.
Result: Wi-Fi doesn't work and I can't load the wizard.
No blue flash from the plate
The wizard indicates "time out"
Do you have a possible solution? buy a new one?
I buy the module separately and test your solution? https://www.fasttech.com/products/1230/10000001/9652893
Thank you very much to all.
dexter
dexter's picture
Broken ovms module
What exactly do you mean by broken Wifi antenna cable?
The Wifi antenna is a PCB antenna included on the ESP module. There is no cable you can break.
I suggest scanning for the Wifi network, connecting to the module via USB to see the boot log and possibly trying a factory reset.
Javier Baena
hi Dexter.
hi Dexter.
When I connect via usb, the blue led only turns on for a few seconds, then it turns off, losing the connection.
I've done a factory reset, loaded another new .bin, hit with a big hammer and washed in liquid acid and it doesn't work lol.
markwj
markwj's picture
Perhaps send a picture of
Perhaps send a picture of what is broken? The blue LED is on the modem board, so perhaps GPS or GSM antenna?
