2 posts / 0 new
LightningBolt
LightningBolt's picture
SIM Card Testing Modem APN Problems
Good Evening,
I am having issues connecting my Modem to the network.
This is as far as my test gets.
Network Registration: RegisteredRoaming
Provider: O2 - UK Hologram
Signal: -101 dBm
State: NetMode
PPP: Not connected
     Last Error: User Interrupt
GPS: Connected on channel: #
The Net status also continuously cycles between NetWait, NetStart and NetMode.
I have checked my connections are correct and also ensured I am plugged directly into a USB plug.
Can anyone enlighten me on my issue?
I have got the module summary here too.
OVMS MODULE SUMMARY
Module
  Version: 3.2.016/ota_0/main (build idf v3.3.4-846-ga5ee88178 Mar 5 2021 14:04:57)
  Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
  12v: 1.3v
SIMCOM Modem Status
  Provider: T-Mobile UK Hologram
  Signal: -93 dBm
  State: NetStart
    Ticker: 1
    User Data: 2
    HW FIFO overflows: 0
    Buffer overflows: 0
    State Timeout Goto: PowerOffOn (in 28 seconds)
  Mux
    Status: up
    Open Channels: 4
    Framing Errors: 0
    Last RX frame: 0 sec(s) ago
    RX frames: 1419
    TX frames: 261
  PPP: Not connected
  GPS: Connected on channel: #1
     Status: enabled
     Time: enabled
Configuration
  [auto]
    server.v2: yes
    vehicle.type: MG
    wifi.mode: apclient
    wifi.ssid.ap: HN21AKK
    wifi.ssid.client: Nostromo 5.0
  [can]
  [dbc]
  [egpio]
  [http.plugin]
  [http.server]
  [locations]
  [log]
  [modem]
    apn: hologram
    apn.password:
    apn.user:
    enable.gps: yes
    enable.gpstime: yes
  [module]
    cfgversion: 2020053100
    init: 5
  [network]
    dns:
  [notify]
  [obd2ecu]
  [obd2ecu.map]
  [ota]
    server: ovms.dexters-web.de/firmware/ota
  [password]
    module: **redacted**
    server.v2: **redacted**
  [power]
  [pushover]
  [sdcard]
  [server.v2]
    server: api.openvehicles.com
    tls: yes
  [server.v3]
  [ssh.info]
    fingerprint: bf25KooFcVqXu4ynLuIJGgE/+G9RE005BK1S9g6MZg4
  [ssh.keys]
  [ssh.server]
    key: **redacted**
  [system.adc]
  [tpms]
  [usr]
  [vehicle]
    units.distance: M
  [wifi.ap]
    HN21AKK: **redacted**
  [wifi.ssid]
    Nostromo 5.0: **redacted**
  [xmg]
REPORT ENDS
Many Thanks
LightningBolt
UPDATE:
UPDATE:
I have solved the issue by moving location. I must have simply had bad signal.
