Hello!
Having a minor problem getting the car to listen to stop charging requests. I have a basically brand new OVMS install v3.3 (with 4G daughter board and SIM) runing Edge version 3.3.001-282-gbd4919ca on a 2017 Nissan LEAF (USA) -- OVMS hardware still not 100% physically mounted (still testing) and the Android app. This is really exciting and so much better than the original OEM system!!
Additionally noteworthy that I recently disconnected my TCU Mini-USB (Power?) connection per recommendations from this forum and others. Only the white (CanBus + comms) connector and the Red and Blue (Antenna x2?) connectors remain plugged into the TCU. Oddly, I got the typical NIssan stopped charging notifications at the very tail end of the test/experience (on 2/21, prior to the shutdown). Since I got a couple Nissan EV&Services text messages (still) with the mini-usb TCU connector unplugged, I wonder if those messages were somehow caused with having been stuck in a queue before they shutdown the 3G Network, or if I must've missed something about disabling the TCU? Those Nissan messages probably will no longer be seen after 2/22 anyway. I thought only the gray/brownish (assumed power?) connector needed to be disconnected on the TCU itself, leaving the multi-pin white cable still connected in order to avoid some CAN bus errors otherwise?
At any rate, prior to this manual charging test/exercise a couple of days ago now, prior to that I had set a desired "SOC Stop Value" option which worked sucessfully the other day set at 80% and stopped the charge on the money exactly as expected, but then while working on more a more permanent install I unplugged the TCU power connector prior to starting the charge session and attempting this "manual stop charging" button test to try to get it to work), the "Stop" button on neither the OVMS Web UI Dashboard, the LEAF charge monitor plug-in I grabbed and installed, there seems to be no way to manually make the OVMS app "stop" the charging session (though I didn't try the command line/API for this yet). Everything else seems to be working with the OVMS, including TPMS reporting, Remote HVAC on/off, lights, doors, etc. but there were a bunch of similar series of messages thrown into the log that seems to pertain to "stop charging" manually but to no avail -- I had to "stop" the charge on the EVSE side of things. In the logs, there seems to be a recurring man-in-the-middle (?) logged theme in the messaging, see below. Maybe there's some setting I'm missing or there is something else obvious I may need to tweak?
Thanks in advance for any help or guidance. Anywhere, here is a snippet of the logs for the attempted "stop charge" I also still have this source log file from more than just this section if it might help. Location masked to protect the innocent.
2022-02-21 22:33:43.086 EST I (939106) webserver: HTTP GET /menu
2022-02-21 22:33:43.096 EST I (939116) webserver: HTTP GET /cfg/vehicle
2022-02-21 22:33:45.006 EST I (941026) ovms-server-v2: Send MP-0 S65.0,M,220,27.27,charging,standard,86,61,27,95,0,1,3,1,0,0,0,0,0.00,104,0,0,80,-1,0,0,0,0,44,95,0,5.80,374.50,81,6.00,100.00,-15.50,0.0
2022-02-21 22:33:45.016 EST I (941036) ovms-server-v2: Send MP-0 D28,0,5,11.6667,12.7778,11,0,216150,0,939,11,0,1,1,13.13,0,12.6,16,0,0,13.8889
2022-02-21 22:33:45.016 EST I (941036) ovms-server-v2: Send MP-0 L39.XXXXXX,-83.XXXXXX,0,269.9,1,1,0,0,0,-5.805,0,0,0,100,AA,13,0.8,0.0
2022-02-21 22:33:48.176 EST I (944196) webserver: HTTP GET /chargemon
2022-02-21 22:33:51.146 EST I (947166) webserver: HTTP POST /api/execute
2022-02-21 22:33:51.156 EST I (947176) webcommand: HttpCommandStream[0x3f8b6058]: 3456704 bytes free, executing: charge stop
2022-02-21 22:33:51.156 EST I (947176) v-nissanleaf: CommandStopCharge - MITM method
2022-02-21 22:33:51.156 EST I (947176) v-nissanleaf: RemoteCommandHandler
2022-02-21 22:33:51.156 EST I (947176) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.256 EST I (947276) v-nissanleaf: RemoteCommandTimer 24
2022-02-21 22:33:51.256 EST I (947276) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.256 EST I (947276) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.256 EST I (947276) v-nissanleaf: Stop Charging
2022-02-21 22:33:51.346 EST I (947366) v-nissanleaf: MITM attempted off
2022-02-21 22:33:51.346 EST I (947366) v-nissanleaf: MITM turned off
2022-02-21 22:33:51.356 EST I (947376) v-nissanleaf: RemoteCommandTimer 23
2022-02-21 22:33:51.356 EST I (947376) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.356 EST I (947376) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.356 EST I (947376) v-nissanleaf: Stop Charging
2022-02-21 22:33:51.436 EST I (947456) v-nissanleaf: MITM attempted off
2022-02-21 22:33:51.436 EST I (947456) v-nissanleaf: MITM turned off
2022-02-21 22:33:51.456 EST I (947476) v-nissanleaf: RemoteCommandTimer 22
2022-02-21 22:33:51.456 EST I (947476) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.456 EST I (947476) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.456 EST I (947476) v-nissanleaf: Stop Charging
2022-02-21 22:33:51.546 EST I (947566) v-nissanleaf: MITM attempted off
2022-02-21 22:33:51.546 EST I (947566) v-nissanleaf: MITM turned off
2022-02-21 22:33:51.556 EST I (947576) v-nissanleaf: RemoteCommandTimer 21
2022-02-21 22:33:51.556 EST I (947576) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.556 EST I (947576) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.556 EST I (947576) v-nissanleaf: Stop Charging
2022-02-21 22:33:51.646 EST I (947666) v-nissanleaf: MITM attempted off
2022-02-21 22:33:51.646 EST I (947666) v-nissanleaf: MITM turned off
2022-02-21 22:33:51.656 EST I (947676) v-nissanleaf: RemoteCommandTimer 20
2022-02-21 22:33:51.656 EST I (947676) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.656 EST I (947676) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.656 EST I (947676) v-nissanleaf: Stop Charging
2022-02-21 22:33:51.736 EST I (947756) v-nissanleaf: MITM attempted off
2022-02-21 22:33:51.736 EST I (947756) v-nissanleaf: MITM turned off
2022-02-21 22:33:51.756 EST I (947776) v-nissanleaf: RemoteCommandTimer 19
2022-02-21 22:33:51.756 EST I (947776) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.756 EST I (947776) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.756 EST I (947776) v-nissanleaf: Stop Charging
2022-02-21 22:33:51.846 EST I (947866) v-nissanleaf: MITM attempted off
2022-02-21 22:33:51.846 EST I (947866) v-nissanleaf: MITM turned off
2022-02-21 22:33:51.856 EST I (947876) v-nissanleaf: RemoteCommandTimer 18
2022-02-21 22:33:51.856 EST I (947876) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.856 EST I (947876) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.856 EST I (947876) v-nissanleaf: Stop Charging
2022-02-21 22:33:51.946 EST I (947966) v-nissanleaf: MITM attempted off
2022-02-21 22:33:51.946 EST I (947966) v-nissanleaf: MITM turned off
2022-02-21 22:33:51.956 EST I (947976) v-nissanleaf: RemoteCommandTimer 17
2022-02-21 22:33:51.956 EST I (947976) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:51.956 EST I (947976) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:51.956 EST I (947976) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.036 EST I (948056) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.036 EST I (948056) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.056 EST I (948076) v-nissanleaf: RemoteCommandTimer 16
2022-02-21 22:33:52.056 EST I (948076) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.056 EST I (948076) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.056 EST I (948076) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.146 EST I (948166) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.146 EST I (948166) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.156 EST I (948176) v-nissanleaf: RemoteCommandTimer 15
2022-02-21 22:33:52.156 EST I (948176) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.156 EST I (948176) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.156 EST I (948176) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.236 EST I (948256) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.236 EST I (948256) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.256 EST I (948276) v-nissanleaf: RemoteCommandTimer 14
2022-02-21 22:33:52.256 EST I (948276) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.256 EST I (948276) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.256 EST I (948276) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.336 EST I (948356) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.336 EST I (948356) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.356 EST I (948376) v-nissanleaf: RemoteCommandTimer 13
2022-02-21 22:33:52.356 EST I (948376) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.356 EST I (948376) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.356 EST I (948376) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.446 EST I (948466) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.446 EST I (948466) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.456 EST I (948476) v-nissanleaf: RemoteCommandTimer 12
2022-02-21 22:33:52.456 EST I (948476) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.456 EST I (948476) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.456 EST I (948476) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.536 EST I (948556) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.536 EST I (948556) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.556 EST I (948576) v-nissanleaf: RemoteCommandTimer 11
2022-02-21 22:33:52.556 EST I (948576) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.556 EST I (948576) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.556 EST I (948576) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.646 EST I (948666) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.646 EST I (948666) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.656 EST I (948676) v-nissanleaf: RemoteCommandTimer 10
2022-02-21 22:33:52.656 EST I (948676) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.656 EST I (948676) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.656 EST I (948676) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.746 EST I (948766) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.746 EST I (948766) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.756 EST I (948776) v-nissanleaf: RemoteCommandTimer 9
2022-02-21 22:33:52.756 EST I (948776) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.756 EST I (948776) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.756 EST I (948776) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.836 EST I (948856) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.836 EST I (948856) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.856 EST I (948876) v-nissanleaf: RemoteCommandTimer 8
2022-02-21 22:33:52.856 EST I (948876) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.856 EST I (948876) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.856 EST I (948876) v-nissanleaf: Stop Charging
2022-02-21 22:33:52.946 EST I (948966) v-nissanleaf: MITM attempted off
2022-02-21 22:33:52.946 EST I (948966) v-nissanleaf: MITM turned off
2022-02-21 22:33:52.956 EST I (948976) v-nissanleaf: RemoteCommandTimer 7
2022-02-21 22:33:52.956 EST I (948976) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:52.956 EST I (948976) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:52.956 EST I (948976) v-nissanleaf: Stop Charging
2022-02-21 22:33:53.036 EST I (949056) v-nissanleaf: MITM attempted off
2022-02-21 22:33:53.036 EST I (949056) v-nissanleaf: MITM turned off
2022-02-21 22:33:53.056 EST I (949076) v-nissanleaf: RemoteCommandTimer 6
2022-02-21 22:33:53.056 EST I (949076) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:53.056 EST I (949076) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:53.056 EST I (949076) v-nissanleaf: Stop Charging
2022-02-21 22:33:53.146 EST I (949166) v-nissanleaf: MITM attempted off
2022-02-21 22:33:53.146 EST I (949166) v-nissanleaf: MITM turned off
2022-02-21 22:33:53.156 EST I (949176) v-nissanleaf: RemoteCommandTimer 5
2022-02-21 22:33:53.156 EST I (949176) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:53.156 EST I (949176) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:53.156 EST I (949176) v-nissanleaf: Stop Charging
2022-02-21 22:33:53.246 EST I (949266) v-nissanleaf: MITM attempted off
2022-02-21 22:33:53.246 EST I (949266) v-nissanleaf: MITM turned off
2022-02-21 22:33:53.256 EST I (949276) v-nissanleaf: RemoteCommandTimer 4
2022-02-21 22:33:53.256 EST I (949276) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:53.256 EST I (949276) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:53.256 EST I (949276) v-nissanleaf: Stop Charging
2022-02-21 22:33:53.336 EST I (949356) v-nissanleaf: MITM attempted off
2022-02-21 22:33:53.336 EST I (949356) v-nissanleaf: MITM turned off
2022-02-21 22:33:53.356 EST I (949376) v-nissanleaf: RemoteCommandTimer 3
2022-02-21 22:33:53.356 EST I (949376) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:53.356 EST I (949376) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:53.356 EST I (949376) v-nissanleaf: Stop Charging
2022-02-21 22:33:53.436 EST I (949456) v-nissanleaf: MITM attempted off
2022-02-21 22:33:53.436 EST I (949456) v-nissanleaf: MITM turned off
2022-02-21 22:33:53.456 EST I (949476) v-nissanleaf: RemoteCommandTimer 2
2022-02-21 22:33:53.456 EST I (949476) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:53.456 EST I (949476) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:53.456 EST I (949476) v-nissanleaf: Stop Charging
2022-02-21 22:33:53.546 EST I (949566) v-nissanleaf: MITM attempted off
2022-02-21 22:33:53.546 EST I (949566) v-nissanleaf: MITM turned off
2022-02-21 22:33:53.556 EST I (949576) v-nissanleaf: RemoteCommandTimer 1
2022-02-21 22:33:53.556 EST I (949576) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:53.556 EST I (949576) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:53.556 EST I (949576) v-nissanleaf: Stop Charging
2022-02-21 22:33:53.646 EST I (949666) v-nissanleaf: MITM attempted off
2022-02-21 22:33:53.646 EST I (949666) v-nissanleaf: MITM turned off
2022-02-21 22:33:53.656 EST I (949676) v-nissanleaf: RemoteCommandTimer 0
2022-02-21 22:33:59.456 EST I (955476) webserver: HTTP POST /api/execute
2022-02-21 22:33:59.456 EST I (955476) webcommand: HttpCommandStream[0x3f8b4a68]: 3459020 bytes free, executing: charge stop
2022-02-21 22:33:59.456 EST I (955476) v-nissanleaf: CommandStopCharge - MITM method
2022-02-21 22:33:59.466 EST I (955486) v-nissanleaf: RemoteCommandHandler
2022-02-21 22:33:59.466 EST I (955486) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:59.576 EST I (955596) v-nissanleaf: RemoteCommandTimer 24
2022-02-21 22:33:59.576 EST I (955596) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:59.576 EST I (955596) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:59.576 EST I (955596) v-nissanleaf: Stop Charging
2022-02-21 22:33:59.666 EST I (955686) v-nissanleaf: MITM attempted off
2022-02-21 22:33:59.666 EST I (955686) v-nissanleaf: MITM turned off
2022-02-21 22:33:59.676 EST I (955696) v-nissanleaf: RemoteCommandTimer 23
2022-02-21 22:33:59.676 EST I (955696) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:59.676 EST I (955696) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:59.676 EST I (955696) v-nissanleaf: Stop Charging
2022-02-21 22:33:59.766 EST I (955786) v-nissanleaf: MITM attempted off
2022-02-21 22:33:59.766 EST I (955786) v-nissanleaf: MITM turned off
2022-02-21 22:33:59.776 EST I (955796) v-nissanleaf: RemoteCommandTimer 22
2022-02-21 22:33:59.776 EST I (955796) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:59.776 EST I (955796) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:59.776 EST I (955796) v-nissanleaf: Stop Charging
2022-02-21 22:33:59.866 EST I (955886) v-nissanleaf: MITM attempted off
2022-02-21 22:33:59.866 EST I (955886) v-nissanleaf: MITM turned off
2022-02-21 22:33:59.876 EST I (955896) v-nissanleaf: RemoteCommandTimer 21
2022-02-21 22:33:59.876 EST I (955896) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:59.876 EST I (955896) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:59.876 EST I (955896) v-nissanleaf: Stop Charging
2022-02-21 22:33:59.966 EST I (955986) v-nissanleaf: MITM attempted off
2022-02-21 22:33:59.966 EST I (955986) v-nissanleaf: MITM turned off
2022-02-21 22:33:59.976 EST I (955996) v-nissanleaf: RemoteCommandTimer 20
2022-02-21 22:33:59.976 EST I (955996) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:33:59.976 EST I (955996) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:33:59.976 EST I (955996) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.066 EST I (956086) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.066 EST I (956086) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.076 EST I (956096) v-nissanleaf: RemoteCommandTimer 19
2022-02-21 22:34:00.076 EST I (956096) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.076 EST I (956096) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.076 EST I (956096) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.166 EST I (956186) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.166 EST I (956186) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.176 EST I (956196) v-nissanleaf: RemoteCommandTimer 18
2022-02-21 22:34:00.176 EST I (956196) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.176 EST I (956196) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.176 EST I (956196) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.266 EST I (956286) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.266 EST I (956286) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.276 EST I (956296) v-nissanleaf: RemoteCommandTimer 17
2022-02-21 22:34:00.276 EST I (956296) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.276 EST I (956296) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.276 EST I (956296) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.366 EST I (956386) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.366 EST I (956386) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.376 EST I (956396) v-nissanleaf: RemoteCommandTimer 16
2022-02-21 22:34:00.376 EST I (956396) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.376 EST I (956396) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.376 EST I (956396) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.466 EST I (956486) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.466 EST I (956486) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.476 EST I (956496) v-nissanleaf: RemoteCommandTimer 15
2022-02-21 22:34:00.476 EST I (956496) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.476 EST I (956496) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.476 EST I (956496) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.566 EST I (956586) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.566 EST I (956586) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.576 EST I (956596) v-nissanleaf: RemoteCommandTimer 14
2022-02-21 22:34:00.576 EST I (956596) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.576 EST I (956596) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.576 EST I (956596) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.666 EST I (956686) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.666 EST I (956686) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.676 EST I (956696) v-nissanleaf: RemoteCommandTimer 13
2022-02-21 22:34:00.676 EST I (956696) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.676 EST I (956696) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.676 EST I (956696) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.766 EST I (956786) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.766 EST I (956786) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.776 EST I (956796) v-nissanleaf: RemoteCommandTimer 12
2022-02-21 22:34:00.776 EST I (956796) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.776 EST I (956796) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.776 EST I (956796) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.866 EST I (956886) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.866 EST I (956886) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.876 EST I (956896) v-nissanleaf: RemoteCommandTimer 11
2022-02-21 22:34:00.876 EST I (956896) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.876 EST I (956896) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.876 EST I (956896) v-nissanleaf: Stop Charging
2022-02-21 22:34:00.966 EST I (956986) v-nissanleaf: MITM attempted off
2022-02-21 22:34:00.966 EST I (956986) v-nissanleaf: MITM turned off
2022-02-21 22:34:00.976 EST I (956996) v-nissanleaf: RemoteCommandTimer 10
2022-02-21 22:34:00.976 EST I (956996) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:00.976 EST I (956996) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:00.976 EST I (956996) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.066 EST I (957086) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.066 EST I (957086) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.076 EST I (957096) v-nissanleaf: RemoteCommandTimer 9
2022-02-21 22:34:01.076 EST I (957096) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.076 EST I (957096) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.076 EST I (957096) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.166 EST I (957186) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.166 EST I (957186) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.176 EST I (957196) v-nissanleaf: RemoteCommandTimer 8
2022-02-21 22:34:01.176 EST I (957196) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.176 EST I (957196) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.176 EST I (957196) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.266 EST I (957286) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.266 EST I (957286) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.276 EST I (957296) v-nissanleaf: RemoteCommandTimer 7
2022-02-21 22:34:01.276 EST I (957296) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.276 EST I (957296) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.276 EST I (957296) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.366 EST I (957386) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.366 EST I (957386) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.376 EST I (957396) v-nissanleaf: RemoteCommandTimer 6
2022-02-21 22:34:01.376 EST I (957396) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.376 EST I (957396) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.376 EST I (957396) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.466 EST I (957486) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.466 EST I (957486) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.476 EST I (957496) v-nissanleaf: RemoteCommandTimer 5
2022-02-21 22:34:01.476 EST I (957496) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.476 EST I (957496) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.476 EST I (957496) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.566 EST I (957586) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.566 EST I (957586) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.576 EST I (957596) v-nissanleaf: RemoteCommandTimer 4
2022-02-21 22:34:01.576 EST I (957596) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.576 EST I (957596) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.576 EST I (957596) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.666 EST I (957686) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.666 EST I (957686) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.676 EST I (957696) v-nissanleaf: RemoteCommandTimer 3
2022-02-21 22:34:01.676 EST I (957696) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.676 EST I (957696) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.676 EST I (957696) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.766 EST I (957786) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.766 EST I (957786) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.776 EST I (957796) v-nissanleaf: RemoteCommandTimer 2
2022-02-21 22:34:01.776 EST I (957796) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.776 EST I (957796) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.776 EST I (957796) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.866 EST I (957886) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.866 EST I (957886) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.876 EST I (957896) v-nissanleaf: RemoteCommandTimer 1
2022-02-21 22:34:01.876 EST I (957896) v-nissanleaf: New TCU on CAR Bus
2022-02-21 22:34:01.876 EST I (957896) v-nissanleaf: Sending Wakeup Frame
2022-02-21 22:34:01.876 EST I (957896) v-nissanleaf: Stop Charging
2022-02-21 22:34:01.966 EST I (957986) v-nissanleaf: MITM attempted off
2022-02-21 22:34:01.966 EST I (957986) v-nissanleaf: MITM turned off
2022-02-21 22:34:01.976 EST I (957996) v-nissanleaf: RemoteCommandTimer 0
Hope that all made sense, it's getting late here and I didn't get this posted yesterday. This logged behavior pattern somehow doesn't seem quite right. Any thoughts?
Again, thanks in advance,
rtw819
Some very odd combinations of things happening here. Prior to doing any physical work in the dash to get to the TCU the Automatic SoC charge stopped at 80% just like it was supposed to. I could not get the OVMS remote climate control to start/stop with the TCU plugged in.
Fast forward a few days to when I pulled out the glovebox to get to the TCU, disconnected it via what I believe was the TCU power connection (just a USB Mini connector?) and I discovered that at that point (as expected) the remote climate control stop/start options work, however, what I didn't expect was that when I went to charge the car up later the next day, the battery SoC desired stop charging setting at 80% didn't work, I had to manually tell my Juicebox to stop the charging after it had managed to get to 90%. Very odd change in behaviors. I plan to do some more testing this weekend if time permits.
Anyone else experience anything similar?
It took multiple tries, but I eventually got to the 2/20/22 edge version of the 3.3 firmware. I just started testing/installing OVMS yesterday, and it was auto-finding a December version. The newest version is where the "allowed SOC drop" appeared. Wasn't in the December firmware. It also made the auto stop charging at a set percentage work (with CAN writes enabled) as well as manual start/stop charging with the app. I have NOT disconnected any of the TCU connectors yet (2017 30kwh SL, with 40kwh warranty battery on-order by local Nissan dealer)
3.3.001-285-g601f2a70/ota_0/edge (build idf v3.3.4-848-g1ff5e24b1 Feb 20 2022 00:04:30)
