Can you tell us what the proper "config set notify XXXX ????" incantation for enabling the alerting for 12 volt charging is?
I found the parameters in the documentation, and tried using the "*" settings as shown below, but to no avail -- no alerts occurred during the period of time when obviously looking at the 12volt history graph indicates there were times when the 12v battery charging kicked on:
OVMS# config list notify notify (readable writeable)
log.grid.storetime: 45
log.trip.storetime: 45
report.trip.enable: yes
vehicle.alert.12v.off: *
vehicle.alert.12v.on: *
vehicle.charge.12v.start: *
vehicle.charge.12v.stop: *
Currently running the latest edge image: 3.3.002-18-gc1d9dad8
I do this with pushover. The two events I use are:
vehicle.charge.start
Vehicle has started to charge
vehicle.charge.stop
Vehicle has stopped charging
I do this without pushover, as standard OVMS notifications work just fine out of the box.
All you need to have is a V2 server connection.
Hello,
Thanks in advance!
There is no standard notification on 12V charging, as that's a frequent standard operation. If you need that, add an event script to produce one.
12V deep discharge alerts are enabled by default, but won't normally occur on a vehicle with automatic 12V recharging.
