11 posts / 0 new
schup011
How to get API token from dexters-web.de
Hi, I tried to get an API token for an openhab integration with the command:
curl --location --request POST 'https://ovms.dexters-web.de:6869/api/token?username=MYUSER&password=MYPASSWORD'
I get only
Authentication failed.
But username and password are correct. What am I doing wrong?
Thanks a lot for your help!
Greypeter
Hi, I found that I had to use a backslash before the & like this:
curl --location --request POST 'https://ovms.dexters-web.de:6869/api/token\?username=MYUSER\&password=MYPASSWORD'
markwj
markwj's picture
You are using the linux / osx
Assuming you are using the linux / osx command line, you will need to 'escape' the & and ? characters if you use the double quote marks around the URL. Using single quote marks should avoid having to do that (so long as neither your username nor password have single quote marks in them).
You can add the '-v' flag to curl to show the details of request sent, and response received.
dexter
dexter's picture
My server still runs the old (V2) OVMS server code, haven't had the time to do the upgrade yet.
So token auth isn't supported yet, only cookie auth.
Sorry for the inconvenience.
schup011
Thanks a lot and you don't
Thanks a lot and you don't have to apologize!!.
That explains the problems. I am now trying to implement cookie auth with the exec binding in openHAB with curl. Not so convenient, but it starts to work.
roki12
trying to migrate my vehicle from openvehicle server
based in HK to dexters in Germany...and after hours of struggling with api token... I found this topic:) surprise
tombaovms
I too was expecting the `/api
I too was expecting the /api/token endpoint to work, and only found this after searching.
Might be worth adding to the dexters-web FAQ?
Philsson
Exactly the same for me
Exactly the same for me actually. laugh
dexter
dexter's picture
I'll see if I can prioritize the token support.
dexter
dexter's picture
HTTP token auth should now work, please test & report results.
tombaovms
Thanks Michael!
Thanks Michael!
I just tested this OK using the methods outlined in the and the OVMS Requests and Authentication token maintenance docs and on Jaimyn Mayer's blog post, for example:
generate a token (response in italics):
​curl -X POST -F 'application=curl' -F 'purpose=testing' https://ovms.dexters-web.de:6869/api/token?username=<USERNAME>\&password=<PASSWORD>
{"application":"curl","owner":"<USERNAME>","permit":"auth","purpose":"testing","token":"<TOKEN>"}
get list of tokens (response in italics):
curl -X GET https://ovms.dexters-web.de:6869/api/token?username=<USERNAME>\&password=<TOKEN>
[{"application":"curl","created":"2023-06-20 10:43:10","lastused":"2023-06-20 10:43:10","owner":"<USERNAME>","permit":"auth","purpose":"testing","refreshed":"2023-06-20 10:43:10","token":"<TOKEN>"}]
delete a token (response in italics):
curl -X DELETE https://ovms.dexters-web.de:6869/api/token/<TOKEN>?username=<USERNAME>\&password=<TOKEN>
{"owner":"<USERNAME>","token":"<TOKEN>"}
One question...the OVMS documentation states that if the POST form includes 'permit=<permit>' then this field "...defines the list of rights granted to the user of this token...". When I issue the POST request with no permit field, I get a token returned with "permit":"auth" (as expected by looking at the source code)Q. Are the possible values of the 'permit' field documented anywhere or are API permissions not implemented? Reason I ask is that if there is way to create tokens with limited API permissions (for example, only allow access to /api/status or /api/charge, but not /api/location).
In any case, many thanks again for adding the token feature to dexters-web OVMS server. :-)
