Hi, I'm trying to get the ABRP script working following the instructions: https://docs.openvehicles.com/en/latest/plugin/abrp/README.html
I've successfully created `/store/scripts/sendlivedata2abrp.js` and `/store/scripts/ovmsmain.js` and inserted my ABRP token and car model into the script.
However, when I try to run the script with
`script eval abrp.info()`
I get the
`ERROR: ReferenceError: identifier 'abrp' undefined (line 1)`
Any idea what I'm doing wrong? I'm running the exact script copy and pasted from the docs.
I'm running OVMS firmware 3.2.013
i think the problem in '/store/scripts/ovmsmain.js' on your board:
- not added "
abrp = require("sendlivedata2abrp");
" to it-
not restarted after the file change the OVMS module or "Reload JS Engine"Reload JS Engine: open OVMS web interface tools menu - Editor and now see the button
Thanks a lot, I missed the step add ovmsmain.js and to reboot the OVMS module after installing the script.
The docs are a bit confusing since the section to test the script is before the section which mentions modifying ovmsmain,js
Thanks a lot for your help. This is such a great integration. If possible it should be integrated into OVMS as standard and configured via the GUI.
I've enabled using 'script eval abrp.send(1)', however data seems to just get sent to ABRP once. Is there an extra step to get it to post periodically? I can see from the script it should be every 60s
so script eval abrp.send(1) will enable sending data every 60 seconds however, the script checks to see if certain parameters have changed and does not send data to ABRP if they have not.
Data will be sent if any of these parameters change:
It is also worth noting that you will not see any notification of subsequent data being sent.
Finally, I committed some minor fixes to the script yesterday so you might want to update your script.
Mike.
Hi, as per Glyn Hudson's post above at 6 July, 2020 - 00:26, I've done the same, i.e.
I get the
ERROR: ReferenceError: identifier 'exports' undefined
at [anon] (duk_js_var.c:1236) internal
at eval (eval:308) preventsyield (line 308)
Any idea what I'm doing wrong? I'm running the exact script copied and pasted from the docs.
I'm running OVMS firmware 3.3.002
Thanks!
Sorry that should have read, "I'm running OVMS firmware 3.2.002"
Apologies if this posts multiple times, I seem to be having problems with recaptcha ...
What I'm trying to post is, my firmware version should have read 3.3.002
Thanks
The script content referenced in the OVMS plugin docs are well out of date. https://www.openvehicles.com/node/3294 is a relevant post that you might want to consider regarding a hot off the press version 2.0 release. I'll be contributing a PR to the OVMS docs once the new version of the plugin makes its way into the ABRP (Internio) github repository.
Does one need to be a premium subscription user for ABRP for v2 to work? I've installed it and there is no change to the stops in the map when I use ABRP. It's saying I can get to San Francisco with 1 charge when I know that my car only has 16 miles on the Guess-o-Meter and it would take at least 2 stops to charge on the way.
