3 posts / 0 new
doudoune42
Taillights blinking with OVMS connected
HI all,
I noticed that the taillights are blinking on the e-niro when the parking brake is turned on and the ovms box is connected. This happens at 2-3 Hz. I guess this is when the OVMS wakes up the vehicle.
Is there any way around this issue? At night it can be quite disturbing.
doudoune42
zoupy
Hello,
Hello, did you find a solution to this problem? I have the same problem as you, so I can't use OVMS, it drains my autonomy unnecessarily thank you if you have any feedback
Narcis STRATICA
Narcis STRATICA's picture
I have KIA Niro model 2020
I have KIA Niro model 2020 and I use OVMS from V2 without any problem with the lights!
Instead, I have a (possible) problem (I don't know yet!) if anyone has checked the temperatures on the 4 columns... from command "bms status"
I have on 1: 14 degrees C, on 2: 13 degrees C, on 3: 16 degrees C and on 4: 14 degrees C.
This problem, that goes to column 3 up to 5 degrees C difference (plus +5 degrees C) compared to the lowest temperature on other columns (or rather the lowest temperature on the columns).
Thanks în advance.
